Question about Gestetner Office Equipment & Supplies
Ihave Gestetner 5327 an having a problem with the master removal. It will not eject the master from the drum. Do I need a repair person or do I need the parts.
Check out the website www.arico1.com. They do repair on duplicator machine drums.
Posted on Jun 07, 2010
Gestetner 5450 sc05-52
SC05-52
Clamper open
position sensor
remains on when
opening the
clamper
At the master clamper open
timing, the sensor is not deactivated
for more than 4
seconds after the clamper motor
on signal is generated.
• Defective sensor
• Defective motor
• Jammed drum guide
drive
• Defective 2nd drum
position sensor
In short check the sensor
input checks SP
4-042 Master Set Sensor
4-043 Master End Sensor
4-044 Master Edge Sensor
4-046 Platen Release Sensor
Dec 03, 2009 | Gestetner Office Equipment & Supplies
The getsetner drum was left out over night and now is "dry"
may i know whats you copyprinter model?
do some force in simolation to pump ink on to the drum so that master will stick to the drum
Sep 15, 2009 | Gestetner Copier
A05-304 error & Top section of page cutting off
the thing might be down to an old master stuck to the drum this could cause the faint copies and the missing print.. pull the drum out check under the master.this would also cause the paper to jam on exit. the error is for no master eject check the calmp is free where it grips the master and also the path for the master eject to the waste bin
Jun 12, 2009 | Riso RZ220 Duplicator
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Problem to print
hi!!!
i have one copier i have the same problem
clean the drum with the tissue "warning don't clean with the wet cloth or wet tissue
just use only dry!!! it may cause the drum damage on it
clean it with the dry tissue
or
replaced the drum
my be the drum expired due to ther amout of copies
Jul 19, 2008 | Gestetner DSm645 Digital Imaging System
Changing the drum on a Gestetner dsm735 copier.
Hi , when you get a new drum unit you should be fine , the cleaning blade drum and everything you will need would be in there already , you can just slide in the new one
Jun 03, 2008 | Gestetner DSm645 Digital Imaging System
Gestetner CP6123 giving error E12
You should check the all paper sensor, there must be a pieces of paper in some sensor and make the sensor in wrong direction. You should remove all and off the power for a while and the start to use it.
May 11, 2008 | Gestetner - AO40 Wide Format Copier Copier
151 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
