Question about HP Computers & Internet
Monitor shows no image, but the computer keep processing apparently by the log on sounds. Julio
  • 784 Answers
It maybe some memory modul faulty, LCD inverter fault or Video chip fault.
Posted on Mar 18, 2011
The Computer won't get to the Desktop Screen. It stops the process of logging in at a screen that shows a loading bar that keeps repeating.
You will need to either, re install the operating system or do a system restore. The latter is available on the F8 screen (press at computer start.)
Aug 16, 2013 | Computers & Internet
Christmas URGENCY: monitor/viewfinder: blue screen, lines of white dashes
remove the tape and just test that whether its recording or not and try to change the tape and then try
Dec 23, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
It keeps cutting of after a few seconds of logging on it will show the acer logo and then some of the program and then cut off.
Could you provide more detail? Is this happening when you turn on the computer, turn on the monitor, or when you log into Windows? If it's happening when you power on your monitor, it is likely not selecting the correct input. If your monitor has a button labeled "source" or "input" try pressing it.
Mar 16, 2011 | Acer Computers & Internet
Toshiba satellite P505-S8980 laptop "A
Solution 1) Set the system cooling policy to "active"
Windows has two approaches to fan control - "active" or "passive". The default option is passive, but if you switch it to active instead then the fan will turn on more frequently. You can do this by following these steps:
  1. Left click the battery icon in the bottom-right corner of the screen (See image)
  2. Left click More power options (See image)
  3. Click Change plan settings next to the Balanced power settings (See image)
  4. Click Change advanced power settings (See image)
  5. Click the + next to Processor Power Management (See image)
  6. Click the + next to System Cooling Policy (See image)
  7. Change Passive to Active for both Plugged in and On battery (See image)
  8. Do the same for any other modes you use, such as power saving mode
  9. Restart the computer
Solution 2) Keep Toshiba PC Health Monitor open
Some of the comments below sing the praises of PC Health Monitor. Apparently, the laptop fan will work harder when PC Health Monitor is open.
PC Health Monitor is already preinstalled on Toshiba computers. To open the program, just press the Windows key to open the Start menu, start typing "PC Health Monitor", and the program should appear in the search results. Click on it to open it.
Apr 07, 2017 | Computers & Internet
Monitor blinks the log on screen and then goes black
If possible you should try and connect the monitor to a different computer and see if you experience the same issue (or connect a different monitor to your computer and see if the same issue occurs). Sometimes the issue is with the graphics card not pushing the signal strength with enough power to keep the image on. If it is indeed the monitor that is bad, I would suggest buying a new one unless the monitor is still under warranty. You can get a decent size monitor from $150-300 and there are plenty of great deals out right now.
Nov 27, 2009 | Samsung 206BW Monitor
Problm with viewsonic va712b
sounds like the operating mode is at a frequency or refresh rate that is outside the viewsonic operating specifications when in normal mode. possible solution: in safe mode access control panel, system, devices (hardware) and look for display. do a right click and uninstall. repeat right click and "scan for hardware changes". That might reset the monitor operating modes but it also gives you a chance to reinstall drivers. If this does not work, try other monitor crt/lcd to see what happens.
May 29, 2009 | ViewSonic VA721 17" LCD Monitor
Black screen- undock the computer message
go to safe mode and return the settings back to day when it was all working fine. Use system restore.
Oct 30, 2007 | Dell E173FP 17" LCD Monitor
Severe gradient issues / problems with darker grays
So your sure when you go into the monitor settings, and color, it is set to like 9300k or something? It probably isn't the monitor, because the video games you said display just fine.
Dec 19, 2006 | Dell M992 19" CRT Monitor
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
