Question about Uniden BC72XLT Handheld Scanner
Cant get any frequencies to program - Uniden BC72XLT Handheld Scanner
  • 391 Answers
Hi select a bank ,Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears. 2. Use the number keys and to enter the frequency (including the decimal point) you want to store. 3. Press E to store the frequency into the channel. Notes: • If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency. • The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475. • When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning
Posted on Mar 19, 2011
How do i program 404 scanner to pick up cell phone frequencies
it wouldn't matter if you could, (scanners have these frequencies blocked out) as these are digitally encoded signals that run on proprietary spread spectrum systems that scanners cant decode
Feb 26, 2015 | Radio Communications
I cant seem to be able to program a frequencies into my scanner. I have a list of local frequencies but the numbers are to large to enter into the scanner to accept. it only holds up to six numbers but...
Frequencies in the range you mention may be part of a trunked system that your scanner cannot follow, but you can still enter and monitor the frequency. Yes, your BC340CRS will handle frequencies with up to five decimal places, as long as the last two digits are 25, 50, 0r 75 (see page 16 of the BC340CRS Owner's Manual). The best programming instructions for your scanner are also in that manual. If you don't have a copy, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC340CRSom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Mar 01, 2011 | Uniden BC340CRS Base Scanner
I HAVE A UNIDEN BC80XL HAED HELD SCANER RADIO. MAYBE IM STIPID BUT I CANT GET IT PROGRAMED FOR ANY FREQ. i NEED SOME REALL HELP THANKS
Your first step is to compile a list of active frequencies in your area. You can find a very good database at:
Next, mark or highlight the frequencies that you want to program, making sure that they will work with your scanner. See your scanner manual for a list of covered frequency ranges. The BC80XLT will hold 50 frequencies.
Once you have the desired frequencies, you're ready to begin:
- Power the scanner ON.
- Press the MANUAL key.
- Enter the channel number that you want to program (01 - 50). If you're going to program the entire scanner for the first time, start with channel 01.
- Use the keypad to enter the desired frequency, including the decimal point (e.g., 146.075). Zeros at the end of the listed frequency need not be entered (e.g., 805.25000 should be entered as 805.25).
- Press the E key to save your program information.
- Press MANUAL to advance to the next channel, then start by entering the frequency.
More detailed instructions are in the factory manual. If you don't have a copy you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC80XLTom.pdf
Bill B.
Feb 08, 2011 | Uniden BC60XLT-1 Handheld Scanner
Cant get know help to program my scanner
Programming the BC60XLT is simple and straightforward:
- Select the frequency to program.
- Select the channel that you wish to program it into. You can press MAN and the channel number, followed by MAN, or just repeatedly press MAN until the desired channel is displayed.
- Enter the frequency, including decimal point (for example, 156.065). The decimal will display as a dash.
- Press E. The frequency is now programmed into the scanner memory, and you can repeat the process to program any channel.
For more information on your scanner, you can download/print the operating manual here:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
Apr 25, 2010 | Uniden BC60XLT Handheld Scanner
Cant seem to get it to pick up local frequencies
Can't really diagnose the problem without more information, but make sure that your antenna is connected properly and that you've programmed frequencies that are active in your area. For a quick function check, program the frequency 162.55, 162.4, 162.475, 162.425, 162.45, 162.5, 162.525, 161.65, 161.775, or 163.275 into your scanner. One of them, probably the first one, will be the primary weather frequency in your area. If the scanner picks up the weather broadcast you'll know that it's working.
Dec 28, 2009 | Uniden BCT8 Base Scanner
Cant program my scanner
first turn it on, then press manual (might be labled man),the type in the channel you want to enter a frequency into and press manual again. next if there is a pgm or program button press it, if it has no program button just type in the frequency you wish to put into that channel. now press enter. repeat this process for each channel you wish to program.
Jan 15, 2009 | Uniden BC72XLT Handheld Scanner
How do I Program my Uniden Bearcat BC60XLT
how do I program bc60xlt handheld scanner
Aug 11, 2008 | Radio Communications
i am having trouble programing frequencies into my scanner i need help!!!!!!!!!!!!!!!!!!!
Aug 09, 2008 | Uniden BC60XLT-1 Handheld Scanner
Radio shack pro-97 hand held scanner
you can go to scanner master.com and get what frequencys you need. if this don't work let me know i will give you a new site.
Oct 31, 2007 | Icom IC-R5 Handheld Scanner
Programing
Here is a pdf format copy of the BC278CLT manual
http://www.uniden.com/pdf/BC278CLTom.pdf
Page 12 to program scanner frequencies.
Rollin CBs
Dean
Sep 30, 2007 | Uniden BC278CLT Base Scanner
Uniden BC72XLT Handheld Scanner Logo
155 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
