Question about LG W2453V-PF 24" LCD HD Monitor
Hi. I'we got this small issue with my LG W2453TQ Flatron display. When I start up my pc, sometimes the screen doesn't go on (I think it does recognice the display signal, but suddenly goes to power saving mode, eventhou the pc is already supposed to be showing desktop) I use DVI to connect the pc to monitor and today updated nvidia drivers, but still sometimes the screen works and sometimes it won't. When this happens I have to take off the DVI and plug it back few times, then the screen wakes up.
  • 16 Answers
SOURCE: My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Posted on Feb 06, 2008
SOURCE: Flatron W2252TQ goes into 'power saving mode'
I had a similar problem with an LG monitor that I resolved by connecting the analogue cable as well as the digital cable from the pc. This problem must be caused by the monitor not receiving a digital signal.
Posted on May 29, 2009
SOURCE: LG w2361vg sometimes get stuck in DVI Power Saving Mode
Maybe you can update your video card driver. My wife notebook is connected at times to my DELL17" flat screen and ever so often it cuts off in the middle of something. I update the video driver and reset the monitor to factory settings and it's working like a dream.
I suggest, you use the menu buttons on the LCD and reset it ot factory settings, and possibly update your video card.
Posted on Aug 13, 2009
jmgldsmth
  • 2005 Answers
SOURCE: lg flatron w1952tq monitor goes immediatly into power saving mode
reinstall windows
Posted on Sep 06, 2009
SOURCE: LG screen goes in stand by.
oke having a similar problem atm, this is what i have found so far. was trying to help a friend who has bought the same 19" LG monitor. When i connected the monitor to her PC i noticed that it was not the same connection as the previous one but it had the smaller blue connection..this shouldnt be a problem but it was. The monitor when powered up, showed LG logo then went into power saving mode. My next step was to try the monitor on my own PC to make sure it was working, When i did this the monitor got a signal but on the initial boot it did say that this monitor was not compatible currently the way i had it set up ( where i had it plugged in? the only place it can be) because of my graphics card. oke so atleast i knew the monitor was working and was recieving a signal.
the only difference i can see is when i put it in her PC it is not giving me this information which also did give 3 steps to solving the problem but didnt seem legit. the next step i will take is to try my monitor on her PC although im not sure i expect it to work.
i think it must be a) PC is now faulty or b) PC is not sending a signal to the monitor ( possibly due to the fact it is not the same connection as before.)
what i have seen on other similar posts says you should also listen for your PC starting up normally.
another thing i would like to know i think it can be usefull for this topic. are the people who are experiencing this problem in the same situation as me i.e. changing the type of connection used by the monitor from the larger to the smaller type?
id also liek to note that the monitor i have was bought on a tight budget from PC world.
only other help i can give to people with this problem is that it is much easier to see where the fault is when you have 2 PC's and 2 monitors i know this is not viable for many but if atall possible interchanging parts with the PC that is working correctly and the one black screening can help you see exactly what the problem is,
as far as i know aswell the main reason for a monitor to sleep is that its simply not getting a signal from the PC BUT on rare occasions it can be a fault in the monitor. IF you have another monitor with the same connection that you can get yto work on the same PC its the monitor with the problem, if u have a monitor that u know is working on another PC with the same connection but is not working on the PC in questions its a PC fault.
sorry for the jumble of words in this answer i tryed my best to explain, all my knowledge of PCs is from friends and self tought so ... hope it helped
Posted on Apr 07, 2010
When i on my pc then the lg screen show me message analog power saving mode and then screen turns black. how can i overcome this problem
I would say that it doesn't see any signal coming from the computer. Check your output. Check the video drivers. Try another video display.
Aug 10, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My lg lcd 22' flatron just turn green,i can still use it but i had to get use to its green display, what should i do to make it back to normal??? pls. help....
Have you tried taking out the connecting VGA cable and putting it back in? (Sounds silly but sometimes works!) Also, can you try using a different cable to see if it is a cable fault? Try the monitor on a different PC/laptop and then you can tell if it is a fault with the PC or the screen.
Jul 26, 2011 | LG 22" FLATRON LCD Monitor
I have an LG flatron w2043t monitor. there is many small dark spot in the lcd display
if the screen is old or has been neglected before, maybe the Liquid Crystal Display (LCD) is starting to bug out. I had the same problem with a flatscreen LCD television some time back, and there was green parts all over the place. im afraid that if this is the case, the only solution i know of is to purchase a new screen. Good luck!
Jul 03, 2010 | Computers & Internet
Instruction Manual for the LG W2453TQ Monitor Please Many Thanks
You can download the user manual of your LG W2453TQ monitor from this link which I uploaded for you.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Jun 15, 2010 | LG W2453V-PF 24" TFT Widescreen Monitor
LG FLATRON E700SH problem wid it is that .its led is flickering dimmly but screen is black out ..? buta sometime after 20m 45 minutes the monitors starts working .but some time it doesnt.??????????
The picture board on your monitor is malfunctioning, since the power led or button is on, but the screen is black out, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 26, 2010 | LG Flatron Ez T910BU 19" CRT Monitor
After starting, my monitor displays "power saving mode".
Go into the menu and reset the monitor to factory defaults.
Aug 28, 2009 | LG L1915S 19" LCD Monitor
My lg flatron L1730S, the screen shows some different color
1. Solder the neck board dry points (cromo IC )
2. display cable connector.
Dec 20, 2008 | LG Flatron 915FT 19" CRT Monitor
LG FLatron W2252TQ Not working properley in DIgital mode.
Fixing power problems with your LG Flatron Monitor (LG1753S) ' Just ...
blog.lopau.com/fixing-power-problems-with-your-lg-flatron-monitor-lg1753s/
Fixing power problems with your LG Flatron Monitor (LG1753S) ... So after checking the power isproperly plugged, I shut down my pc again. .... I can start a game and then change the resolution, Popp of "energy saving mode digital" led goes ..
Mar 21, 2017 | Computers & Internet
LG W2453V-PF 24" LCD HD Monitor Logo
1,338 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
