Question about Grundig GUFSAT02SD
Ive bought a Grundig GUFSAT02SD freesat box. We already have another fresat box working off a 4 way LNB dish so ive just connected another sat cable from the dish. Have connected up the scart to the tV and the sat cable as per the manual but the freesat box wont turn on. The box is definitely getting power because it makes a ticking noise and the light on the front is red. According to a picture on the grundig site when its on the light should go green. You use the remote to switch it from standby to on but despite verifying that the remote batteries are OK and checking they are in the right way round and removing all the packing/plastic from the front of the box, it wont turn on. Any ideas?
5 Suggested Answers
  • 76 Answers
SOURCE: Grundig arganto 82
You have a problem in the secondary of the power supply,no amount of switching on or off will solve this,it will have to go to service,
Posted on May 20, 2007
  • 4 Answers
SOURCE: I require a user manual for grundig gdt1500
I also have this problem. I have sent a request to Grundig.co.uk. There is some information here:
http://support.thetechguys.com/layout.aspx?ID={28880c68-4c71-4f8f-b787-d81337345574}&CatID={68268fd3-68bd-4930-9469-e82274f9f26e}
It shows the connection layout and remote control functions.
Posted on Jan 08, 2010
  • 916 Answers
SOURCE: No sound from grundig tv,
Return it to the shop
Posted on Feb 16, 2011
ginko
  • 19396 Answers
SOURCE: No sound on a 21in
Hi.
Using AV entry ensure that the red/white leads have been connected properly to TV Audio input. SCART is supposed to have built in sound. Test using a different scart.
Try disconnecting power cord for fifteen minutes, that will discharge internal component and reset the TV. Double check audio settings just in case.
If all that does not help, then the problem is likely the sound circuit inside TV. In this case the audio circuit is built-in the main board. Usually with the 19'' LCD TVs you need to replace the main board. Parts for this model are not available from third party distributors. In case the TV is defective, I suggest calling the Grundig number listed on your owners manual to arrange repair or to check part availability. To find contacts you can also use the 'International' tab on top of this page:Welcome to Grundig.
Regards.
Ginko.
Posted on Apr 11, 2011
Can i connect the tv to a sattelite dish to recieve freeview
No you need to connect a terrestrial aerial to get freeview
To get freesat you connect a sat dish and lnb
Nov 29, 2015 | Televison & Video
I have a foxstat -HDR humax box and I am getting no or bad signal on the TV downstairs. I can get some channels but not all.
I suspect that the box upstairs is a Freesat box; a Freeview box requires a feed from an aerial, not a dish.
The problem you are seeing may be caused by water in the cables, if they are not sealed at the LNB. The LNB may be failing, but dish misalignment is more likely.
As there is an unused output on the LNB, try swapping one of the feeds with a poor signal to it.
Jul 27, 2015 | Humax Televison & Video
Ive got a freesat dish and reciever but we get 90% signal but no quality any suggestions
Your on the wrong satellite, If your on any satellite youll get a high Signal but you wont get a high quality until your on the specific satellite. Astra 2A is for freesat. If you can bring that up on the menu then just keep moving the dish until the quality goes above 50% and that will suffice for a decent picture.
Mar 14, 2011 | Televison & Video
I have a Zinwell Quad LNB J4S which I have just got around to fitting to my Sky Mini dish and have a problem. There are 2 supplied fixing brackets only one of which fits my dish arm but holds the LMB at...
Hi, You would probably be better of getting a new dish and single 4 output LNB or you could try just ordering a 4 output LNB with a universal bracket especially for the sky dish variants, I have seen these on ebay and have used one successfully myself, I think it only cost me 20 gbp.
If you are having problems in the area with reception it may also pay to get a 90cm dish and 4 output LNB combined.
Hope this helps.
Feb 11, 2011 | Televison & Video
I have bought a Grundig 320GB/500GB freesat unfortunatly I keep losing sound from my tv the problem is with the tv. I was wondering if it would be possible to connect 1 or 2 speakers to the box to get...
TV's aren't good audio sources anyway. They usually have speakers suitable for lo-fi watching such as news and talk shows.
You don't say how the audio gets to the TV. Buried in the signal on the RFcoaxial? HDMI?
You can't just hang speakers on the Grundig.
If you have an audio system with an optical or coaxial audio input the best multichannel audio would be heard by skipping past the TV anyway.
Jan 22, 2011 | Audio Players & Recorders
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
I can't get Channel 4, E4, More4 etc. on freesat
Channel Four is available on Freesat as follows:
Channel 4 Freq 10729 Vertical 22000 5/6 -
Enter these figures on your 'Search for Channels' menu, and it should turn up Channel Four.
Mar 10, 2010 | Grundig GUFSAT02SD
Unable to get sky on panasonic tv
You cannot drive both from a single cable. You require a dual LNB fitted to your dish (replacing the single LNB). This has two cables out , one to sky and the other to the TV. If you have your own dish this should not be a problem.
Jan 09, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Grundig GUFSAT02SD Logo
113 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
