Does not spin and lighta are flashing - Washing Machines
    Brigadier General:
  • 6,277 Answers
Sorry but you do not say the make and model of your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
Dashbroad lighta go out engine still running then battery goes flat
sounds like alternatoror theres a short somewhere
Jan 27, 2015 | Cars & Trucks
Electric range lights keep nking
Here is a link. On the right side of that page is a link to contact Kenmore for assistance with their products. Good luck.
Mar 29, 2014 | Kenmore 30" Slide-In Electric Range...
Anti brake lights on
you need to have it scanned for fault codes, most likely the brake light switch
Dec 27, 2012 | 1999 Mercedes-Benz CLK
Lighta 1 and 7 flashing
Fault code 130.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Jun 30, 2012 | Fisher and Paykel Washing Machines
My sony laptop turns on but screen is black
Black screen on startup with an amber flashing light A flashing amber light along with your black screen on startup can be a few things.
  1. Not enough power getting to the motherboard.
  2. A dead power supply.
  3. A bent pin or shorted out USB port causing a problem.
Computer black screen after installing new hardware Often when computer users install hardware in order to upgrade their own computers they run into problems. If you have just performed an upgrade and then get a black screen, the answer is obvious. Some hardware components may not be compatible with the others in your system. And of course there is always the risk of static electricity damaging your components when you are not an experienced computer repair person.
You might just be installing a new piece of RAM but the best way to troubleshoot this is to go back to where you started from. Always start from the beginning. If your computer was working and you installed something, then take it back out. Think about what you are doing and try again.
Apr 28, 2012 | Sony Computers & Internet
Tail lights brake lights reverse lighta park lights in the back dont work what do i do
Check all your fuses, then inspect the bulbs. If none are working you might have the ground for the tail light circuit out. Do the turn signals work? Hope this helps, if you need further assistance just reply to this thread/post.
Jun 12, 2011 | 1997 Dodge Neon
Brake lighta not working
rplace fuse or brake light switch
Jul 03, 2009 | 1995 GMC Suburban
Changing lighta
svp ou elle se trouvel )emplassemt)la fiche de scanner de honda accord 2001
Oct 14, 2008 | 2000 Honda Accord
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
