Question about Garmin Ghc 10 Autopilot Control Unit
My Ghc 10 shows the following message " searching for autopilot controller" what does this mean?
How do i recalibrate the st4000 tiller for the starboard side
Hi Tina!
The ST 4000 is factory default to the starboard side. If you require a port side mount, see chapter 7 of the manual to which I have provided a link below. (3.16 MB) About halfway down the page.
The text reads as follows:
OPERATING SENSE REVERSAL
Press +1 and -1 keys together for five seconds.
The display will then show port or starboard and the phase of the autopilot will automatically change.
The control head will automatically revert back to its normal operation within 5 seconds.
Note: This should normally only be required if the actuator is port hand mounted.
Hope this helps.
(Sorry about the orientation of the manual, it's pretty cheesy coming from Raymarine.)
-Steve
Raymarine Retired Autopilot Manuals
Dec 05, 2014 | Boating
Garmin troubleshooting
call Garmin Marine support they know this stuff better than anyone and usually have a very short hold time from my exprience
Jul 27, 2014 | Garmin GHC 20 Marine Autopilot Control...
Hi am trying to connect it with my pc but its asking new hardware found "mtp device driver" but not installing just poping up againg and again not connecting with pc
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
gylacz
May 03, 2011 | Sony Walkman NWZ-B135 MP3 Player
MOT POW SWAPPED, this is the message which appear just like that. the autopilot is working last 5 years, i have checked the wires connections, all is set as the diagram. one thing: my rudder has some...
Check if rudder reference unit is installed as before ,it seems that the pilot sense that the rudder is turning the wrong way. check when giving +10 command the
rudder turns to increase the heading,if yes, it could be the wiring of the rudder reference unit or it was installed the wrong way after service on the rudder.
Is rudder position indicating correctly?
Jun 24, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Wires came loose of control unit from circuit board do you know what order they should be soldered back Green, white and yellow wires are still connected but I don't know where/which terminal to...
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Mar 27, 2010 | Griffin Technology Griffin iTrip AutoPilot...
I would like to connect my garmin gps72 via the garmin supplied four line plug to the nmea ports in back of my raymarine st6002 autopilot controller. The st6002 controller is plugged into a smartpilot x5...
I connected my Garmin gpsmap76 to a Raymarine autopilot using the NEMA output from the GPS. The autopilot was also on the seatalk bus. It work fine. The GPS provided navigational guidance to the autopilot
Dec 21, 2009 | Garmin GPS 72 GPS Receiver
Autopilot shows "no rudref"
The rudder sensor works like a light dimmer, so you get 5V and ground on the outside two connections and a varying voltage between about 1 and 4 volts depending on rudder position
847-746-0100 www.technicalmarine.com
Jul 07, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
AP35 Autopilot
Yep, if rudder calibration values are OK, then there is a real problem with calibration, it can be a mechanical problem or a faulty rudder feedback unit. Follow procedure at page 93 of user manual :
AP35 Autopilot Instruction Manualto troubleshoot the error, if you cannot get rid of the error message you may have to replace the rudder feedback unit or to have the unit inspected by a technician.
Aug 14, 2008 | Simrad AP35 GPS Receiver
Garmin Ghc 10 Autopilot Control Unit Logo
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
