Mobile modem out of order this error was detected.
Iam vijay my mobile samsungC3053 pin2 is blocked,phone number 8686638135
Posted on Mar 18, 2011
My phone is not connectad in pc as amodem
In order to connect your phone as a modem to your pc you require pc suite for your mobile. Just google for the company name alongwith pc suite and download and instal it. After installation it will be detected as a modem.
Jan 18, 2011 | Computers & Internet
Hi i have just purchased huawei e1831 ( t- mobile) but during software installaion message come " problem occure during hardware installation ur hardware will not work properly" after that...
1 Restart the PC
2 Reinstall the software
3 IF still the problem persists then right click on My computer -->manage-->Devicemanager
4 Here if you expand device manager u will see the a yellow error message. simply reinstall the driver and it will work for sure.
5 have a run on your system for antivirus before doing all this.
Jan 15, 2011 | T-Mobile Huawei T-Mobile Webconnect USB...
I am using samsung 3g metro gt-s5350 with MTNL sim. I am able to surf the net on the mobile but not able to use it as modem for using internet for my laptop. It is showing "os error, remote device...
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
Nov 08, 2010 | Samsung Modem Configuration Software...
Windows XP doesn't detect SBC SpeedStream5100 Ethernet ADSL Modem
in order to the ethernet port to work under the safemode enviroment, you must choose the option for "Safe mode with networking" if you choose "safemode" only the only the drivers the OS needed to boot will be loaded.
Hope it helps!
Feb 19, 2010 | Computers & Internet
How to Install WM610 Modem in Ubuntu?
Check to see if WM610 is compatible with LINUX:
the easiest way to unlock modem is using DC UNLOCKER is easy as 1,2,3 (with in few seconds )
to download :- http://www.sendspace.com/file/v4jd4wt.gif
for modem types look my DOC file. 1. connect modem to computer
2. don't click connect button on mobile partner window
3. change sim card you wish to use (after unlocking)
4. install DC unlocker
5. run DC unlocker
select manufacture and select modem as "_Auto detect (recommended)_"
6. click on search icon("detect card")
good luck!!!!!!!!!!!!!
May 17, 2009 | Computers & Internet
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
