Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
The wisk can not be fixed - KitchenAid K5SS Heavy Duty Commercial Stand Mixer
    Genius:
  • 1,739 Answers
Check here for a posiible replacement whisk:
http://www.abtecparts.com/kitchenaid_mixers.htm
Posted on Mar 19, 2011
I need parts to a Wolfgang Puck Stand Mixer. Dough Hook, Bubble Wisk, splash guard
Hello
We are a leading metal casting and cnc machining precision parts manufacturer in China.
Pls check our website to learn more about our products.
If you have a PDF or STP dwgs, pls send us so that we can quote for you immediately
You will get the most super quality and the most competitive price from us
If you let us work for you
Beat Regards ,
Simon sun
Ningbo Huayuan Precision Casting Machining Co.,Ltd
Ningbo Huayuan Casting Machinery Factory
Tel:+86-574-88166711
Fax:+86-574-88166721
E-mail:info@huayuan-machinery.com
Web:www.huayuan-machinery.com
Dec 18, 2013 | Wolfgang Puck Commercially Rated 700-Watt...
I purchased a new KitchenAid Professional 600 Stand Mixer Model #KP26M1XQNP. I used it once and it was difficult to keep the paddle from coming off during mixing. The speed didn't seem accurate...
Stop messing about with it and return it to place of purchase to be fixed under guarantee. Any fiddling about you do with it is only going to endanger your guarantee.
Mar 29, 2017 | KitchenAid KP26M1X Stand Mixer
The mixing head, the part that flips up is loose. when i am mixing and i try to lock the head i have to lip it slightly to be able to lock it. after that it makes a noise as the beater, either the paddle...
It sounds like the head height needs adjusting. There are full instructions in the user manual. Basically lift the head to its fully back position. Look towards the hinge and you will see a screw that can be screwed out to raise the head height.
May 06, 2011 | KitchenAid K45SS Classic Stand Mixer
The wisk is hiting the bowl how can i adjust
Hi FMOINIZ, by the symptom you are describing, you need to adjust your mixer’s Bowl to Beater Clearance. This is quite an easy task, and is explained in your Users Instruction manual that came with your mixer. If you do not have one, you can easily download a PDF version from the KA website at: ’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (4) KP50PSWW0.pdf (2930.74 KB) and save that file to your PC. Turn to Page 11 and you will find the instructions for adjusting the Bowl-Lift model mixer head height.
But to save you some time, I have extracted the instructions below:
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 26, 2009 | KitchenAid KP50PS Professional 5 Series...
How do you release the wisk
Hello. Actually, the wisk releases just like the other attachments do......... just lift and twist it 1/4 turn.
Oct 13, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Trying to locate a wire whisk for my Hobart D-340
Bill. Whisks are not interchangable for different bowls. Try ebay to locate one.
If this solution has assisted you, please rate it. ricardok45
Mar 20, 2009 | Hobart D340-6009 Mixer
The attachments move up on the shaft
There is a retaining clip part number 9703680 illus no 25 on pg 5 of this part diagram http://www.goodmans.net/images/dmg/ka_diagrams/KP26M1X.pdf that part slip down the shaft on my mixer. I use a pair retain clip pliers to put back in place in the grove on the shaft and was back in business. if the clip is not on the shaft then you need to get a new one.
Jan 15, 2009 | KitchenAid KP2671 Professional 6 Series...
Mixer not creaming butter and sugar...
make sure you are using the right attachment. usually for batters you want to use the flat beater. not the dough hook. the flat beater looks like a triangle with lines through the center. and make sure you are using the correct speed on the mixer. start out at stir and then go up to no more than half speed. these mixers take a little longer to incorperate batters but they do a very good job at it. if the batter is thin enough you can try using the wisk as well. but only if it is a thin batter.
Apr 24, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 575 Professional Mixer
Read the instruction manual. There is a screw to adjust the beater height, it is where the mixer joins to the stand.
Feb 28, 2008 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
205 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
