Question about Brother SE-270D Computerized Sewing Machine
Flashing light on power up.
I switched from sewing to emboring and now all it does is flashing. No other function are working. I've only had the machine 8 months.
  • 323 Answers
Take it back to the dealer to be repaired or replaced under warranty.
sewman7
Posted on Aug 02, 2008
Why does it keep stopping with lights flashing when filling bobbin?
Singer 7422 keeps stopping with lights flashing when filling ...
www.fixya.com/support/t26006759-singer_7422_keeps_stopping_lights
4 hours ago - Singer 7422 keeps stopping with lights flashing when filling bobbin Machine stops ... Machine stops and red lights flash when loading bobbink.
Dec 13, 2015 | Singer Sewing Machine 7422
My singer curvy starts beeping and lights flashing and won't sew
I just got mine to stop flashing lights and function again when I unplugged the cords from the machine and let it sit for a minute. You can always give that a try.
Dec 20, 2012 | Singer 8763 Curvy
Singer confidence 7463 all lights flashing
try
rethreading the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or thread
make sure bobbin is inserted correctly & that it's not damaged
try changing the needle
May 20, 2012 | Singer Confidence 7463 Computerized Sewing...
Flashing lights
You have a warranty - take the machine back to your Bernina dealer for service.
Mar 28, 2010 | Bernina Artista 170
Flashing lights/ no functioning of machine
When we had the same problem as you, we called the helpline and they walked us through the basic reset process. We turned it on and had the same problem. We then raised the presserfoot, turned the wheel on the side of the machine, put down the presserfoot, and then unplugged the power cord from the side of the machine. We then turned it on, and it was fixed! Hope this helps!
Jan 02, 2010 | Singer Sewing Machines
Flashing lights
This is a copy of the post on your premium solution thread.
According to Singer guidelines , if there is only red blinking light, then there is an fault inside the machine, unless it reset disconnecting from power.
If there is an error code with format EM-01 - EM-09 tell me which error you get and I should find a fix.
Here is a complete user guide, check pages 90-92 for common errors.
If you have no error message, and light does not go out with power disconnect then it may be a faulty control board.
In this case I suggest doing a last attempt removing all threads, and reset design unplug from power 10/15 mins.
Let me know if you still have the problem.
Regards
Apr 12, 2008 | Singer CE-100 Futura Computerized Sewing...
Needle position jammed?
First make sure you are using a needle that is recommended by your model. Secondly make sure the needle is inserted correctly. The flat side of the needle needs to be against the flat bar that makes the needle go up and down. After this, unplug the power supply and let it set for a couple of minutes. This gives the computer time to re-set itself.
Hope these suggestions work!
Zelma
Jan 19, 2008 | Singer 7442 Mechanical Sewing Machine
The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Oct 27, 2006 | Singer CE-100 Futura Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
71 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
