Question about Canon DR 3020 Path-Through Scanner
Hi got the following error message ... "ScanFile
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I have many years repairing canon scanners so here is my suggestion to you.
First does the scanner power up? If so that's eliminates a internal power supply problem.
Second did anyone change the dip-switch settings on the back of the scanner? Ill assume no on that one.
Third when you first boot up your computer do you see a screen when the computer is in boot up mode that says Adaptec SCSI and then a number? If not here is a couple things to check. First I would check the SCSI cable is good. No bent pins in the connector and no exposed wires coming out of the connector. If you can try swapping a good known working cable with the problem scanner. Second try re seating the SCSI card if that doesn't work do you have another card that you know works that you can swap into the problem computer. After swapping the cable first test to see if the scanner scans, then if you replace the card again retest to see if the scanner scans.
Lastly and I have seen this happen, the drivers may get corrupted if new software is installed that relates to scanning. You may want to google DR 3020 drivers that should pull up Canon's web site and reinstall the drivers. Once you install the latest drivers then reboot the computer and test it to see if it now scans.
Im sure one of my suggestions should correct your problem. I hope this helps you out.
Posted on Apr 01, 2011
Scanner error 52 turn off and turn on
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP LaserJet 3055 All-In-One Printer
Printer TX550W has message "A printer error has occurred. Turn off and then on. See your documentation".
Hi, this error message usually caused by jammed papers or foreign objects inside your printer. To resolve this issue, please try the following steps.
1. Turn off the printer.2. Open the scanner unit.3. Check for any jammed papers or foreign objects then remove it.4. Check the ink cartridges and lids if push down fully.5. Close the scanner unit.6. Turn on the printer.
If the same error reappears, try the following.
1. Turn off the printer.2. Open the scanner unit.3. Remove all the ink cartridges.4. Turn on the printer >> your printer will display install ink cartridges.5. Install all the ink cartridges, make sure it clicks into place and also the lids should be push down fully.5. Close the scanner unit.6. Press the Start or OK button to charge the cartridges.
If the issue persists, your unit will require service. Please contact Epson so they can check if your printer is still under warranty or ask them for the nearest service center in your area.
Nov 23, 2011 | Epson Stylus Multifunction Inkjet Printer/...
When the DataWedge 2.0 is launched, an Error "cannot set scan parameters 00000000" appears and scanner does not function. Was running just fine. MC7094. Scanning is working fine in another...
If the scanner is not working, you can try to go to this site to check the information on how to reset the device. Here is the link that you can try.
Thank you for sing Fixya.
Aug 09, 2011 | Symbol MC9090 Barcode Scanner
When i try to scan, it gives me the following message "Undefined error occurred. (0x8021001F) A probably cause is that the system is unstable. Reboot the system. If this does not resolve the...
check in your scanner panel if there is any error showing like U 1 or any other message.if not then your scanner is perfect and check your system
Mar 21, 2011 | Fujitsu ScanSnap S510
I got this error... "You
It's AVG. I was having the same issue. To fix:
Open AVG
Right click where it says "Link scanner active", then open advanced settings
Uncheck where it says "Add "secure by Link-scanner" to any Facebook.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 08, 2011 | Facebook Social Network
Copier has and "L" and blinks back forth between
Hi this error may happen due to problem on the scanner unit. Please check the following;
  • Turn it off the on if it doesn't clear then
  • Check the scanner lock above paper exit tray and unlock it then off and on
  • Check that the copy lamp is lighting ,if not check the lamp cable and lamp itself and replace.
  • Check the scanner motor and the rail then pulleys and adjust.
Be careful while handling brittle glass.
Dec 10, 2010 | Sharp AL 1631 Copier
Hi, my terminal Motorola MC3190 doesn't want to enable scanner and i really don't know why.... There is an error code A0000032 with message: "CANNNOT ENABLE SCANNER"
The scanner engine/output can be used only by one application. If a second application is trying to access the scanner, while in use. The error message will come.
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software.
Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Nov 09, 2010 | Zebra Symbol Technologies MC909X-G Series...
Error message
hi,
You can go to this site ..
http://www.fix-all-dll-errors.com/ltkrn70n.dll/
as I registered few dll's from this site... pretty helpful...worked in my case :)
Jun 07, 2009 | Office Equipment & Supplies
Canon DR 3020 Path-Through Scanner Logo
201 people viewed this question
old marine
old marine
