Question about Refrigerators
I have a KIC C100-BF30. Can I adjust the freezer compartment temperature?
  • 12 Answers
SOURCE: IFrost Free Sharp Refridgerator & Freezer-Fridge not keeping cold
You have a defrost problem. You need either the defrost timer, defrost heater, or the defrost bi-metal. If you have a meter you can ohm out the heater and the bi-metal ( as lonh a s the bi -metal is frozen as it opens when it gets warm to cut out the defrost heater) if you have an ohm reading on either one of the two the replace the defrost timer, if you don't then replace the part that has no ohm reading.
Posted on Sep 14, 2009
  • 121 Answers
SOURCE: Freezer compartment is OK, But refrigerator is
sounds like your thermostat may be bad . the thermostat senses the tempreture in the fresh food section and turns the ref. on and off as needed . do it yourself roughly 39-89 dollars if u hire a proffesional around 95.00- 165.oo depending on were u live and who u use.hope this helps
Posted on Oct 06, 2009
heatman101
  • 43501 Answers
SOURCE: Good day, I use a KIC
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Apr 17, 2011
rickead1
  • 1998 Answers
SOURCE: The top freezer is working but lower part
Hello Eddie111,
If you were to remove the rear panel on the inside rear of the freezer you would then be able to gain access to the evaporator coil, If when you gained access to the evaporator coil you then noticed any ice build up on the coil itself this would be called a defrost issue that your unit was having. This is usually due to one of three parts either the defrost thermostat, the defrost heater, or the defrost timer or in some units the adaptive control board would be showing a fault. Would need you to message me back further if you do have a defrost issue with your unit. There is also a small damper door that lets the evaporator fan motor blow cold air into the refrigerator side of the unit this damper door is controled by a thermostat that is found in the ceiling of the unit. Usually attached to the control knob that is located inside the freezer. So first thing to check for is that the fan is working on the inside of the freezer next thing would be if you have the defrost issue on the evaporator coil itself, and lastly you would check the damper door and the thermostat inside the refrigerator side of the unit. If you have any further questions message me back with your reply to the defrost question that I asked previously. Thanks again I await your reply
Rick
Posted on Jul 20, 2011
  • 115 Answers
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
How do I reduce the freezer temperature
Locate the the thermostat - usually located in the fresh food compartment (if a refrigerator). Make small adjustments of about 1/8 of the dial's travel at a time - and check the change after 24 hours. Be sure to check both the freezer AND fresh food compartment to prevent temperature from dropping to low for fresh food. Best results are obtained by using a thermometer put in a glass of water in the fresh food area and another thermometer left in the freezer. Most manufacturers suggest a freezer temperature not greater than 0°F and fresh food 35°F to 40°F. If you need specific help with this - please include the make AND complete model number of your freezer.
Oct 23, 2015 | Freezers
Westinghouse RJ532, 530 Litre, Frost Free Fridge/Freezer keeps stopping - if we move the little red dial in the fridge under the air temperature control it starts up again, goes for awhile and then stops....
If the refrigerator was tipped on back or side, even part way, it has to wit upright at least overnight, because of the freon flowing upward.
If you just moved in and it has been sitting and unplugged, then it may be low on freon.
Here are some tips
If you open the fresh food compartment of your fridge (the non-freezer compartment), you will most likely see two different controls. One refers to the refrigerator temperature and the other refers to the freezer. Different manufacturers use different wording, but the idea is the same.
The first thing you need to know in order to understand what these controls really do is that all the cold air in the entire refrigerator is made in the freezer compartment. A portion of that cold air is then blown into the fresh food compartment. How much cold air gets blown in is controlled by the "freezer" control, which is really just an air baffle that opens or closed to let more or less air into the fresh food compartment. The "refrigerator" control is actually a thermostat that feels the temperature inside the fresh food compartment and turns the compressor on and off according to the temperature that the thermostat feels.
Let’s run through an example. Suppose you decide that your ice cream isn’t hard enough. You adjust the "freezer" control to make your freezer colder. What you’re actually doing is restricting the amount of cold air that gets blown from the freezer into the fresh food compartment and so keeping more of the cold air in the freezer. As a result, the freezer will get colder but also the fresh food compartment will tend to get warmer because its cold air supply has been diminished. The "refrigerator" control (the thermostat) will feel this increase in temperature inside the fresh food compartment and will keep the compressor running longer in order to maintain the temperature setting on the "refrigerator" control. So, you can see that any change you make to one control will affect the other.
Many people then wonder, "Well, how do I know what the correct setting on the controls should be?" Since the temperature inside a refrigerator will vary according to lots of external factors such as frequency and duration of door openings, it is impossible to say where your controls should be set all the time in order to maintain a desired temperature in the freezer and fresh food compartments without knowing the actual temperature inside both compartments. For this reason, you should place two thermometers in your refrigerator: one in the fresh food compartment (the big one) and the other in your freezer. The controls should then be adjusted to achieve -10 to +10ºF in the freezer and between 36 and 38ºF in the fresh food compartment.
Keep in mind, too, that it takes 24 hours for any change in the controls to work through the system and reach steady state so don’t look for instantaneous changes in temperature when you make control setting changes. Knowing the actual temperature inside your refrigerator compartments is also a great way to save money on your power bill since you can adjust the controls to avoid running your compressor longer than needed to keep your food cold.
Mar 16, 2008 | Refrigerators
My kic fridge have 2 compartments. Freezer and fridge. only the fridge part dont work help please
The freezer is where the heat is removed from the box and cold air should circulate from the freezer into the refrigerator section. Something must be blocking the vent between the two. There is only one cooling unit; it cools the freezer and is also vented into the fridge for sub-freezing temperatures.
Nov 26, 2013 | Red Line Mens Classic Gmt Black Dial Black...
Refrigerator is not cold, but Freezer is too cold
You can adjust temperatures of both the compartments via regulators at the far end of the fridge compartment. you can set the temperature from there. sometimes they are also on the side panel. hope this helps. This might be helpful too http://www.wikihow.com/Set-Your-Refrigerator-Temperature
Aug 22, 2013 | Whirlpool GB2SHKXL Bottom Freezer...
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
I have a KIC 2 door fridge freezer. The freezer works but not the fridge part. It was working till a few days ago. The evaporator was frozen so i switched it off to defrost it. Since then it doesnt co
Check that your evaporator fan is operating. If it is, then take the rear freezer shield off and blow warm air down the cooling tubes to defrost the tubes. One of more of your cooling tubes is frosted up.
Jan 23, 2012 | Refrigerators
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
Dec 20, 2010 | GE GSS20IEP Side by Side Refrigerator
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Aug 10, 2010 | Traulsen Reach in Freezer - G22010
GE GSS25LGMFWW side by side. Freezer will run till iced up then defrost everything in the freezer compartment. Why is it doing this?
hi, have you try adjusting the temperature:
To change the temperature, press and release the
WARMER or COLDER pad. The SET light will come
on and the display will show the set temperature.
To change the temperature, tap either the
WARMER or COLDER pad until the desired
temperature is displayed. The
freezer temperatures can be adjusted between
–6°F and +6°F.
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
