Question about Zanussi ZWF1440 Front Load Washer
I have E30 error on my ZWF 1631 W. Not covered in the manual. Any advice?
    Brigadier General:
  • 6,277 Answers
Sorry but I do not have the decode for E30 on your particular machine BUT for the ZWG models it states 'check filter of the drain pump' which is what I tend to advise in cases like this!
So I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
Why do i get 'err on display and buttons do nothing
err is error......should be a number or code after err.......
cheers
Jun 19, 2014 | Zanussi Washing Machines
My zanussi ZWF 1631 -W is showin fault E50 ..any idea ??
Hopefully answered on your other posting ;-0) John C
Sep 10, 2011 | Zanussi ZWF1630 Front Load Washer
Zanussi zfw 1631 w skipping through programmes straight onto drain from wash. has been coming up with an error code e30
I'm going to take a stab at the filter on the empty pump being blocked.
I have tried to find an error code that matches for you and loads of forums talk about a possible blocked pump filter (Though I have seen a motor fault mentioned too!).
Try checking the filter out, it's the biggest cause of questions being posted on this site for washing machines
Jun 29, 2011 | Zanussi Washing Machines
Error cde E20 on zanussi zwf 1631
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 17, 2010 | Washing Machines
Sharp AL 1631 ---- Getting blank copies
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Jan 22, 2009 | Sharp AL 1631 Copier
Flashing light
Change the toner
Jun 23, 2008 | Sharp AL 1631 Copier
Zwf 1631 w
Have you took the front cover off and looked for the strainer which is located before the water pump. I have seen many of them plugged tightly, causing the water not to drain. Look inside the owners manual that came with the machine. It also should give you some things to check that would cause the code E20 to keep flashing. Hope this helps.
May 09, 2008 | Zanussi ZWF1430W Front Load Washer
Zanusi zwf 1631 w wont work
all of the e50 codes indicate motor check your brushes. if you still have problems email me
Feb 10, 2008 | Zanussi ZWF1630 Front Load Washer
Error code e30
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
& pl rate if helped...............
Dec 04, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
363 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
