Question about Sony KV-29LS60 29" TV
Hi i hane got a sony tv with code kv-29ls60e . the problem that i have got is that the tv stop and swithc off . the led is open and close for three times and i have to swithc it on again . this could be happens for more than three times per day . and some timew the tv isn't s open again. please tell me what i haave to do .
techman
  • 3130 Answers
SOURCE: sony trinitron kv-27fv17
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby, this means there is a component inside your TV set, in the main power supply or the sweep power supply that is not letting the TV set's power supply regulate properly. I'm sorry to say, there is no quick fix for this and is going to need to be diagnoised by a trained tech. Good Luck
Posted on Mar 20, 2007
SOURCE: Sony KV-32FS120 blinks 4 times
good day.
Have you tried first resoldering the terminals in the circuitry?
Also, try to check for the ABL supply near the flyback. Watch out for the small voltage zener diodes.
response is highly appreciated.
chris
Posted on Mar 28, 2008
IrishDruid
  • 2712 Answers
SOURCE: sony trinitron kv-36fs76u
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other).
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Since the set is new, it may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers,
IrishDruid
Posted on Apr 26, 2008
localwonder
  • 6784 Answers
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Posted on Jun 21, 2009
SOURCE: Sony FD Trinitron WEGA KV 32FS120
Replace D645 and D647 with 2.5A1KV diodes.PROBLEM SOLVED. Thank you Solution #5.
Posted on May 16, 2010
Sony tv model KV-HA21M80 is having problem front stand by L.E.D is blinking 4 times and stopping
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Electro help
Jan 14, 2015 | Sony Televison & Video
Sony fd trinitron colour television kv 29ls60e
There is no built-in converter to this TV. You've to use an other one externally.
Jan 22, 2014 | Televison & Video
The power supply probably is failing.
Jan 10, 2014 | Televison & Video
Tv sony stop after 20 min standby led flashes 3 times
HI,
By three blink it means the B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is because there is problem in the power supply circuit. Check for any dry soldering in the power supply side. If the tv is working properly for 20 minutes then its sure that there is some dry soldering joints in the power supply side. You have to resolder suspected soldering contacts using soldering ion and solder. The dry soldering joints will look like on in the picture.
ajin_g_109.jpg ok
Oct 06, 2011 | Sony KV-29FX66 29" TV
Sony KV-20Fs100. Same problen as #4620488. TV
4 blink of power led shows problem in vertical deflection section and most probably vertical output IC is defective, replace it to fix the issue.
Regarding .rar file type of service manual files, download winrar software trail version from internet, install it and use it to unzip .rar file to get pdf manual file.
You wont get +B volts because tv switch to protection mode and power supply shuts down. Service manual has blinking standby led error code details as well.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony TV Model Number: KV-27FS100L No Power 1. Stand By LED Blinking Three Blinks No PowerIntermittent. 2. Stand By LED Blinking Three Blinks No Power Intermittent. 3. Stand By LED Blinking Two Blinks No...
Try using another power outlet, if you are using a power distribution board then try plugging the TV directly into a wall socket. If using an extension cord then try with another cord. It also maybe that the factory lead that came with the TV is faulty, any of these problems may be restricting the correct amount of amperage required by the TV unit to operate.
Apr 07, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Stand by led blink 4 times
my tv is FD Trinitron WEGA KV-HA21. when i press the power button it starts but after about three secounds it trips to stand-by and starts blinking four quick succession at intervals
Jul 20, 2008 | Televison & Video
Sony KV-29LS60 29" TV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
