Question about DFI NF4X INFINITY Motherboard
When I hit the power button it wont turn on. I have replaced the RAM with a known working DDR400 1GB stick, no fix. Tried switching power supplies, no fix, tried new videocard since when it was last on (a few days back) it froze after booting into windows 7 and updating drivers. I have not tried another CPU since I dont have another S754 CPU. the CMOS Jumper is switched to reset settings on boot. The power LED comes on when plugged in on the MOBO, and once I hit the power button, the DRAM LED light turns on, but thats it. No system fans turn on, and i know my PSU is good. PCPC 510W PSU. System specs with known working components: A64 3700+ S754 CPU (Clawhammer i believe), Patriot 1GB PC3200 RAM stick (normally Corsair XMS 2x 512MB sticks at 2.2.2.5 1T at 2.8V. Seagate 7200.11 1TB HDD plugged into SATA port 3 at the moment, but I have tried all SATA ports with no luck. no additional Sound Card, I took it out, as well as no CD/DVD/BD Drive. As stated earlier, this was working, then after updating the system drivers and normal updates in a fresh windows 7 ultimate install, it froze and wont turn back on. i hit the power button and the only change is the DRAM LED light on the mobo turns on, and is red in color. System has not been overclocked.
    Master:
  • 325 Answers
When you say the CMOS is set to reset, this should not be the case for normal usage. and maybe the problem if left in the on position the system will not start (which sounds like your problem).
Posted on Mar 18, 2011
MacBook Pro no power at all
When my Mac decided to no work when power button was hit, only two options came to mind, Power Button or Motherboard.
Turns out, power button is connected to keyboard which was the problem. The fix was easy, new keyboard.
Hope this helps.
Cheers
Feb 08, 2014 | Apple Computers & Internet
MacBook Pro not turning on
Sounds like a possible power supply issue, or a fuse has blown inside for the power.
Feb 08, 2014 | Apple MacBook Pro Notebook
Windows not booting
Turn the laptop off. Turn it upside-down and remove the battery. There is another accessible compartment on the bottom, that when opened, reveals the RAM sticks. This compartment is likely sealed shut with a couple of small, Phillips screws.
Once you get it open, carefully remove the RAM stick(s) and re-insert them. If your laptop uses two sticks, start by only inserting one--test--insert #2--test. Be sure they are inserted firmly and completely. So long as your laptop has not been subjected to a voltage surge or something like that -- your problem is likely with the RAM and usually the above procedure will fix. However, RAM can go bad, and there are other things that could be wrong.
If the above proceedure does not fix, next I would borrow the RAM (1 stick) from another, known-working laptop, and try it with the known-working RAM stick. Or, you can purchase another RAM stick. RAM is cheap. At any rate, I have found it best to rule out RAM before spending time and effort elsewhere.
If it is not the RAM, it could be the motherboard. On a laptop, if it is not the RAM, it is probably best to take it to a pro who can test your motherboard and power-supply and processor with special instruments. But I bet its the RAM. :-) Good luck and rate me if this helped.
Don
Feb 29, 2012 | Computers & Internet
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
Test
move memory one slot over
Test
Move memory over one slot
test
move memory to last slot
test
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
Turned computer on and monitor instantly goes to sleep,also cant turn off the computer using button.have to use switch on power supply
Try this, unplug everything from the other board except the main hard drive, power connections, and monitor. if it does not come up, remove ram cards, leaving one stick. try again, if it is still bad swap ram sticks. If after all of this it still does not work you have a bad motherboard or processor
Nov 14, 2011 | HP Compaq Presario SR5210NX Desktop PC...
Power switch notworking ( ASUS P4PE-X Motherboard)
Please refer your motherboard manual and fix the front panel cable including power button. After this if power button is not working than swap the power button cable and reset button cable.
And then start your PC by pressing the reset button.
Else you just recheck all the cable + RAM + CPU.
Mar 09, 2009 | ASUS P4PE-X Motherboard
One long beep.
  1. Leave the memory slot closest to the processor empty and try booting again. Award bios 1 long beep is memory error as the first 64K of the ram stick closest to th processor is accessed first. since you have tried different ram in different locations, let's rule out the board.
  2. If that doesn't solve anything try a different power supply. Sometimes (Phoenix) gives a long beep when system board or power supply are bad.
  3. Now if nothing else has worked it is probably tour mother board.
May 16, 2008 | Abit KN8 Ultra Motherboard
Won't turn on
if you are able ,open the box,earth yourself out on it (static can damage things) if you have more than one stick of ram take them out ,and try booting up with one stick at a time, in the first ram slot ,if you find one that does not boot the system up its the bad one ,reinsert what ever other sticks you have , problem solved.
if not ,replace all ram chips, then
  • remove any ad in cards that you have, one at a time (other than a video card if you have one) then try booting,
  • if you have gone through all the cards (not the video as mentioned before) and still not booting, remove everything including the video card ,ram, disconnect all drives ,
  • if you hear no beeps then the most likely problem is the motherboard ,
  • but have known power supplies that fluctuate to cause the same problem.
good luck
Terry
Mar 23, 2008 | Dell Dimension 8400 PC Desktop
Asus a8n sli deluxe not powering up
do you have 2 sticks of ram in the pc?
if so try it with one in and do this with both
as in boot it with a single ram stick and try to determine if its a faulty ram stick
also if you can try another power sup unit
please let me know how you get on
Mar 22, 2008 | ASUS A8N-SLI Motherboard
DFI NF4X INFINITY Motherboard Logo
124 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Matthew Spark
Matthew Spark
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
