I just wan to ask about the computers driver...can i know what is bluetooth audio driver...and how can i instal it...
  • Computers & ... Master
  • 27,725 Answers
If you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Posted on Mar 18, 2011
CAN'T FIND WIN7 DRIVER FOR BLUETOOTH HBS-200 HEADSET
Unfortunately, Windows 7 removed native support for bluetooth headsets, for absolutely no reason.
The drivers are actually not needed for the Headset specifically, but rather for the A2DP and AVRCP profiles and audio sink. The downside is that Microsoft's Bluetooth stack does not support either of these.
So you need a Better Bluetooth Stack, so it understands all of the virtual Bluetooth devices.
These directions work for almost any headset that has issues when connected to Windows. Sadly, there is no really good well-defined set of drivers for Windows Bluetooth, so it will frequently take some finagling.
1: Find the correct and absolutely most-up-to-date drivers for your Bluetooth hardware on your computer. In -MOST- cases, the chipset is Broadcom, however manufacturers such as Dell and others tend to put some odd wrappers around the chip so their drivers are required. If not, the direct-from-Broadcom drivers will work.
2: IF the Bluetooth hardware is already detected by Windows, delete it from device manager. Reboot the computer if this was done.
3: On reboot, Windows may detect it and reinstall it fresh. This is fine if it does. Allow it to install and reboot if it requests.
Once the Windows stack is installed properly, you can install the updated stack. With Dell drivers and other OEM computer manufacturer drivers, Windows may not detect it to begin with, however having Windows drivers first is not necessary with these drivers.
4: Install the proper driver. With the Broadcom driver, this will only work if Windows has already installed. With OEM drivers, this is often not necessary. Reboot if necessary.
With the happy stack installed, and the headset paired, you will find that instead of just Handsfree Telephony and Headset services, you will also have Remote Control and Audio Sink services.
Headset/Handsfree: Mono 38kbps audio out and also a microphone input. This is what is used for phone calls. It sounds horrid, mind you.
Audio Sink: Stereo happiness and joy. No microphone input.
Once you have these devices, you do need to set your audio playback device appropriately for Stereo Happiness and Joy.
Mar 27, 2014 | Radio Communications
The audio on my computer doesn't work
Bluetooth should have nothing to do with audio. Check device manager and confirm that the audio drivers are installed and are working.
Feb 01, 2014 | Computers & Internet
None of the bluetooth drivers on my computer work
Try an anti virus run followed by a registry cleaner. A good tip regarding these links is unless you asked for them and know what they will do, ignore them.
Bluetooth perephal device problem on dell inspirion
If you want to connect a Bluetooth peripheral device to a computer, you may need to download a new driver to support it.
There are two approaches to this:
If your Bluetooth device came with a driver on a disc, you can install the driver directly from the disc.
Otherwise, simply connect your computer to the Internet and connect your Bluetooth device to your computer, then wait for Windows to install any required drivers automatically.
You may receive this message when you connect your Bluetooth device to your computer: "Windows needs to install driver software for your Bluetooth peripheral device."
Bluetooth peripheral device driver downloads are easy to locate via any search engine.
Open the CD-ROM drive on the computer and insert the driver disc that shipped with the Bluetooth device.
Wait for a moment to see if the software auto-launches, as most modern software discs do.
If the program does not launch automatically, double-click the "My Computer" icon and then double-click the "CD-ROM drive" icon.
If this does not launch the software but instead opens a file folder, look for a .exe file such as "setup.exe" or "run.exe" and double-click that.
You're looking for a Bluetooth peripheral device driver.
Follow the on-screen prompts, once the software launches, to install the Bluetooth peripheral device drivers on the disc. You may be prompted to restart your computer at the end of the process.
Letting Windows Install the Driver
Make sure Windows is up to date, as most Bluetooth drivers are included in Windows Service Pack updates.
To do this, make sure your computer is connected to the Internet, then click the "Start" button in Windows and select "Windows Update" from the program list.
This will launch an Internet Explorer window. Click the "Find Updates" button in the window and wait for Microsoft to search for available updates.
If it recommends any high priority updates, follow the on-screen prompts to install them.
Connect the Bluetooth device to the computer.
There are three ways to do this.
If you have an internal Bluetooth receiver in your computer, just make sure the receiver and your Bluetooth device are turned on and put your device within range of the computer.
If you have a USB Bluetooth receiver, plug it into an available USB port on the computer; then turn on the Bluetooth device and put it within range of the computer.
If you have another type of auxiliary cable, you may also be able to use it to connect your Bluetooth device to the computer without using a Bluetooth connection.
Watch the system tray in the bottom right corner of Windows.
You should see a notification that Windows has detected a Bluetooth device, followed by another notification that the device has been installed properly.
The installation it is referring to is that of the driver. If this does not work as expected, proceed to the next step.
Click the "Start" button in Windows, then click "Control Panel." Launch "Device Manager."
Expand the "Bluetooth Devices" entry in the Device Manager by clicking the plus sign next to it.
Find your Bluetooth device listed under this heading, right-click it and select "Update driver" from the list of options.
Wait as Windows automatically finds and configures any missing Bluetooth peripheral device driver downloads.
Hope this helps
Nov 06, 2012 | Dell Inspiron 15R 5520 USB Docking Station...
Bluetooth driver for window 7
Download Bluetooth Driver Installer, version 1.0.0.81 Beta, released on July 17, 2012
32-bit (x86) version BluetoothDriverInstaller.exe (1.9Mb)
64-bit (x64) version BluetoothDriverInstaller_x64.exe (2.9Mb)
How to use
1. Uninstall your existing bluetooth stack (driver software that came with the bluetooth adapter).
2. Reboot your computer and click "Cancel" when Windows asks for the driver.
3. Run BluetoothDriverInstaller.exe and follow instructions of the wizard.
hope this helps
Aug 01, 2012 | Acer Aspire 4935 Drivers Recovery Restore...
Windows 7 and Dell BH200 Bluetooth Headphones
You have to set bluetooth as default audio device. For doing this, go to >Contro Panel> Sound and Audio Devices>Audio(Tab) and in Default Device choose bluetooth device.
In my case, I had problem when i installed SP3 on XP. I changed my bluetooth driver to "Toshiba Bluetooth Stack V6.00.10" and it worked for me.
Oct 30, 2009 | Audio Players & Recorders
Windows cannot search A hardware?
Its probably a bluetooth device as it says. So install its drivers if not recognized automaticaly
1. If it is an external dongle try to install the drivers from a CD that came with it.
2. If not (an internal device usually on laptops) drivers for it are on the motherboard CD, so browse the CD looking for a folder named Bluetooth, or something associated and install them.
After installing will be asked to reset your computer so do it as asked. After that the installed device will copy and execute some files and will start working
Aug 02, 2009 | Computers & Internet
Windows Vista wont connect to these headphones
Try going to control panel->sounds->make the hands free audio the default.
Jun 17, 2008 | Insignia Bluetooth Wireless...
Acer aspire 4720z audio driver for widows xp home edition sp2
is there any other way to solve the audio problem? after i install win xp sp3 in my acer aspire 5550,i get stuck in installing audio driver.i have download the driver from many website even in acer.com, but still cant solve it..please give me some idea..
Dec 02, 2007 | Acer Aspire 4720 Notebook
Computers & Internet Logo
David Payne
David Payne
