Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
DC07 will not release to allow me to vacuum? - Dyson DC07 Bagless Upright Cyclonic Vacuum
3 Suggested Answers
SOURCE: Dyson DC07 Clear Bin Flap will not release
I just received my replacement root cyclone in the mail today after waiting in the back-ordered status for three months. I positioned a butter knife in between the rubber gasket on the bottom flap lid and the bottom rim of the clear bin at the farthest point from the hinge and slowly and gently wiggled the knife between until the bottom flap just fell open. I examined the rubber gasket and it survived without injury and the bottom flap seals without any gaps...good luck
Posted on May 27, 2010
  • 910 Answers
SOURCE: I have a Dyson root
Is this something you've had for a while or just purchased?
What are you doing to try and remove the Cyclone & Canister from the Vacuum?
Posted on Jun 26, 2011
DC07 Vacuum canister stuck. I won't release so I can empty it. Any suggestions?
You may have to press the release button and hold it depressed as you pry the canister loose.
Feb 13, 2015 | Dyson DC07 Animal Bagless Upright Cyclonic...
The canister will not release from the vacuum
I'm sorry to hear you're having difficulties with your DC07. The cyclone assembly should lift away easily from the main body of the cleaner when you press the release button. If it won't do this, it's probably best if you give us a call so we can help - you can reach us on 0800 2980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 15, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Where is the filter
Dyson put filters in three locations. 1) Remove the canister, there should be a release clip in the front above the handle, this allows the top to tip backwards. 2) On the left side, at the main unit is a round cover with thumb release, this pulls straight out. These are cleanable filters, RINSE ONLY no soap!!
3) Under the canister is a filter, the cover has 3 clips which need to be pried gently to open the cover. This is a hepa filter and cannot be cleaned, it must be replaced.
Nov 09, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson 28 handle is stuck in the locked and upright position. Vac runs fine, just can't get the handle to release to run the vac
On the lower right side of the body of this model is a air duct piece that can get stuck and won't allow you to use the release. Take out that piece and put it back on again to see if that will unlock it.
Nov 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Trying to replace roller brush on DC07 model
Hi the dyson is a bit strange with this the dyson engineers use a hook to put under the belt and pull it out to allow the brush to be removed I used a metal coat hanger to make the hook after seeing the dyson engineer when ours was under warranty if you make the hook with the wire doubled up it works fine for me hope this is of help Fred
Jun 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson Dc07 dustbin will not release
USUALY REMOVING THE 3 TOP SCREWS COMPLETLY YOU CAN NORMALY LIFT OFF THE TOP WITH EASE.
IF YOU CAN DO THIS REMOVE THE ROD TRIGGER ASEMBLY FROM THE TOP AND THEN PLACE THE BARE ROD BACK INTO THE BASE WITHOUT THE TOP AND ALIGN THE ROD TO THE TRAP DOOR LATCH AND GENTLY PUSH DOWN WITH SOME PRESSURE AND WITH A BIT OF LUCK SHOULD RELEASE BOTTOM FLAP IF SUCCESFUL WASH BOTTOM LATCH ASSEMBLY WITH HOT WARE AND REMOVE DUST & DEBRIS AND REASSEMBLE,
Apr 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Emptying cylinder
I hope you've found out by now, but, in case you haven't, the latch to remove the canister is right by the handle on top of it, just don't lift until you release the latch with your thumb, it's got a safety to keep you from hitting the release when you're using that handle to carry the vacuum.  (good engineering).
you can download a manual from the dyson site, here:
http://www.dyson.com/customercare/manuals/us/dc07_opmanual_usa.pdf
Aug 14, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
24 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
