I'm trying to reset my canon ip2772 but it shows error 006 on service tool area..
SOURCE: canon Printer ip2772 error 5200
error 5200, how to solve
Posted on Feb 17, 2011
  • 2246 Answers
SOURCE: i have a canon ip2772
press resume button for 2 minutes to reset
Posted on Mar 18, 2011
  • 525 Answers
SOURCE: ip 3000 canon showing service error 5100, tried to
Carriage error [5100]
Solution (Replacement of listed parts, which are likely
to be faulty):
- Carriage unit (QM2-1250)
- Timing **** strip film (QC1-4284)
- Logic board ***'y (QM2-1520)*1
- Carriage motor (QK1-0545)
Posted on Jan 23, 2011
elix0411
  • 3530 Answers
SOURCE: my Canon IPF5000 printer is
Welcome to Fixya
Performing firmware update/upgrade will reset the counter back to 0. Here's the link where to download the firmware for this printer.
You may try to restore the printer back to factory settings before doing firmware update.
Enter the Service mode following the procedure below.
1. Turn off the printer
2. Turn on the printer while holding down the Paper Source button and [Information] button]. Keep pressing the above buttons until initializing appears on the display
3. S is displayed in the upper right corner of the display showing the version
4. after display of Online, pressing the Menu button displays the SERVICE MODE top menu and the MESSAGE LED flashes.
The Service mode is added to the options in the Main menu. The Service mode can be entered even in the error status (when an error message is shown on the display) by turning the power off and then using the above key operation. it would be required to manually go through all the counters reset and re-initialize most major components.
Thank you for using Fixya!
Posted on Feb 08, 2011
caroldon
  • 17129 Answers
SOURCE: How can i reset canon
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Posted on Jul 13, 2011
Ip2772 error number5b00
I had a problem, my printer shown me the error munber 5b00. When I try it to reset it I make a mistac. I press the resum button 4x. Now my printer will not goes to service mode. What can I do? Pls. Help me
Apr 20, 2014 | Canon PIXMA iP1800 InkJet Photo Printer
Canon pixma mp 230 error 006
The error "006" can occur for many reasons, which we explain below, starting from the most probable to least probable. It is recommended if you have questions or problems with the procedure write a comment, they are always answered and help solve other problems.
Incompatibility with the service tool and printer
It is possible that the program for resetting you are using is not compatible with your computer, in most cases this error appears as a result. It is recommended that where got the service tool, verify that printer is compatible even with the same name as the tool can search the Internet service compatibility, you can ask in a comment to this publication.
Not followed the correct procedure to enter the service mode
Enter the mode of service is an important part to restore print pillows, if not properly enters the service tool will not work or will file errors when trying to run it. The options for selecting in the program are disabled.
Clean the connectors of the printer and cartridges
The cartridge connectors (copper contacts in the front of the cartridge) and printer connectors, located also in the front of the head must be clean in its entirety, means, they may not have stains of ink or lint that can prevent proper operation.
Check printer drivers
In some cases when you test that everything is working properly, and the problem still continues, you should uninstall and install again the printer drivers, so with the printer off until the software installer asks you to connect it.
Jan 09, 2014 | Office Equipment & Supplies
Service tool for canon ip2772
How can i get canon ip2772 service tool?
Apr 20, 2013 | Canon PIXMA Office Equipment & Supplies
Canon pixma iP2772 how can i fix 5B00 error?
Try this............
STEP 1: Entering Service ModeYou have to enter in service mode in order to used the resetter. To do that follow this procedure,
1. Turn off the printer without pulling the power cords.2. Hold down Resume button and press Power button.3. Keep holding down Power button and let Resume button go.4. Then Press Resume button 5 times then let BOTH buttons go.5. You will notice that the Alternate Blinking error is gone, this means that the printer is in Service Mode state.
STEPS 2: Using the Resetter
1. After you download the resetter, extract it and double click "servicetool.exe"2. Press the "Main" Button, Then press "EEPROM Clear" button if a pop-up appear just click OK5. Then power off the printer(sometimes you have to press twice the power button to turn off) and turn on again. and its done!
Sep 28, 2012 | Canon Office Equipment & Supplies
How to download driver for printer iP2772
Hi
Download the drivers from the link below.
quicklydownload.com/drivers/printer/canon-pixma-ip2770-ip2772/266504
Save the file on your machine and then open it to run setup.
Follow the on display instructions to install
Feb 28, 2012 | Office Equipment & Supplies
How to fix error 006 in canon service tool
how to solve it service tools code error 06?
Jan 04, 2012 | Canon PIXMA iP2000 InkJet Printer
HOW TO REPAIR CANON IP2772 ERROR 5B00
In your Printer colour curtize is blank. please refil. then try it will come back.
Oct 04, 2011 | Office Equipment & Supplies
670 people viewed this question
jasbo
jasbo
