Question about Sport & Outdoor - Others
On a 1991 Big Bear 4wheeler, the reverse light stays on even when it is actually in neutral which is causing the 4wheeler to not start since it "thinks" that it is in reverse. Can't seem to be able to get the light off by shifting it.
  • 217 Answers
SOURCE: 03 silverado neutral safety switch
possible but it can also be a range selecter switch problem. any work done on vehicle lately? pleas respone and i will try my best to help thanks.
Posted on Jan 31, 2009
  • 3567 Answers
SOURCE: 1998 Honda Goldwing will not start nothing.
Sort of sounds like a Twilight Zone kind of problem doesn't it. I would have the battery checked for an internal dead short. This is something that happens on odd occasions and can happen even to a new battery. Yea, the little lights will work ( they do not draw much juice ), but the starter motor draws a lot of juice and a shorted battery just ain't got it. Also check the wiring harness connections. One loose connection can cause bunches of trouble.
Posted on Mar 14, 2009
boysor2933
  • 293 Answers
SOURCE: suzuki sidekick clutch problem
Check the cable clearance. Too much clearance will cause clutch slippage or total clutch disengagement. Adjust the cable so that the clutch pedal will be hard to press by hand .5 to .75 inch from its initial point.
Posted on May 28, 2009
  • 29 Answers
SOURCE: light dimming
BROTHER; It sounds like you have a ground issue,clean all of your elect. connections with CRC, lectamotive. This will clean out the dirt and old grease, then greasy the connections with DI-ELECTRIC GREASE, nothing else. If you use any other grease you will have a short and more elect. problems. Try that and GOOD LUCK......GREASY
Posted on Oct 02, 2009
SOURCE: I FITTED A NEW REVERSING SWITCH ON MY CLASS A140
IFITTED A NEW REVERSING SWITCH ON MY CLASS A140 MERCEDES AND FOUND THE REVERSING LIGHTS STAYED ON ALL THE TIME, EVEN IN NEUTRAL.I changed it three times in case of faulty switch still the same problem
Posted on May 01, 2010
Shifter moves on big bear 350 but quad wont reverse now it goes forwards
for some reason you are not getting into reverse , there is no real reason it should stay in forward gears unless there is someting wrong with the shifter itself being in the wrong position this can happen take it off and reposition it and make sure your clutch is disengauging to shift gears , will it go into all gears or just 1 forward , ck into that and be a little more specific on the problem ,good luck
Mar 18, 2014 | Grizzly Big Bear Atv Maintenance Free...
Why is my Jeep Grand Cherokee Laredo is stuck in reverse
the switch is out of adjustment on its mount..loosen the mount bolts and readjust the switch..
Dec 16, 2013 | 2004 Jeep Grand Cherokee
2000 chevy blazer automatic. reverse lights staying on????
sounds like you have a bad reverse switch,possibly neutral switch if the reverse circuit is built within the neutral switch.you could have a bad wire causing the lights to be on all the time(power worn though touching the wire that goes to the backup lights.
Mar 18, 2011 | 2000 Chevrolet Blazer
My 1999 Pontiac Sunfire GT 2.4L Automatic Gear Selector is broken
you car likely thinks its stuck in reverse, which it may be... even if you can roll it. you'll need to find a way to either get it into park or neutral, normally this can be done by the actual linkages under the shift console or from underneath the car.
Apr 07, 2017 | 1999 Pontiac Sunfire
I FITTED A NEW REVERSING SWITCH ON MY CLASS A140 MERCEDES AND FOUND THE REVERSING LIGHTS STAYED ON ALL THE TIME, EVEN IN NEUTRAL.
Jan 22, 2010 | 1999 Mercedes-Benz E-Class
Just bought 1990 big bear and I cant seem to get it in reverse. What is the sequence?
down shift it into neutral then turn the reverse knob. while holding the reverse knob(still turned) down shift again and it should shift into rev. then just up shift to take it out of reverse
Oct 13, 2009 | 2003 Yamaha WR 450 F
Renault senic 1.6 petrol
id check the reverse light light switch, if this is faulty this can cause that mesaage to come up
Sep 29, 2009 | 2001 Renault Sportwagon
Yamaha big bear no spark
I'm not familiar with all quads and all the kill switch locations. Does it have a tip-over kill switch? Is it working? Is the quad in neutral? Is the neutral light on? Many engines will not spark if the neutral light is not on. Are the headlights off when starting?
How good is your battery? A low battery can kill spark. Test for spark by grounding the threads of the plug against the cylinder. Have a friend kick the bike while you watch for spark. Assuming no spark, then check all the kill switches with an Ohmmeter to be sure each switch is working properly. Sometimes a switch goes bad. Try disconnecting all kill switches then check spark.
Check the wiring harness, even under the gas tank and seat. Are all the connectors clean and with a tight connection? Any abraded wires? Check the ignition switch also. The switch can go bad as well. Are the flywheel coils good > is the battery getting a charge?
Still no spark? If CDI then get it checked.
If points then file or replace them along with a new condensor and reset the gap then time the engine. >> I hope this helps.
Please rate this answer. Thanks trsrhntr!
Apr 02, 2009 | kawasaki KLX 300 Motorcycles
1991 Caprice No reverse. Moves in neutral. All forward gears OK.
What engine? Rear wheel drive ?Sounds like shift linkage or cable out of adjustment slightly. Have a look at where cable or rod attaches to transmission for adjustment. If not sure of what your looking for get back to me with info.
Mar 21, 2009 | 1993 Nissan Maxima
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
