Hi my becko washing machain is leaking warter from the back dose anyone no why it is
    Brigadier General:
  • 6,277 Answers
Sorry but the only way for anyone to find out where the water is leaking from is to remove the back (?) cover and look. It could be from a number of hoses- hot water inlet, cold water inlet, feed to the dispenser drawer hose(s),drainage hose...................
Sorry again but you will need someone to investigate for you ;-0(
Good luck,
John C
Posted on Mar 18, 2011
How fo i stop my fluids from running out my tail pipe
It would appear that the ice has caused considerable damage to the engine.. Have a compression test done to check for cracks and head gasket problems. have a coolant system pressure test done to check for leaks around the heads and block area including the heater core in the car.
Jan 12, 2014 | Cars & Trucks
Hello, my becko WM5100W washing Machine has stopped working, when you turn the washing machine on, the ready, wash and spin/end stay on, along with the start botton, usually it's just the start, and...
Hi Kaylee, To explain the self test/reset mode, will take a long time. Just go to this you tube site, and it will guide you through the process.
https://www.youtube.com/watch?v=8C4J3leArY0
You may have to enter the address manually.
Hope this helps
David
Nov 28, 2017 | Washing Machines
I have a new washing machaine otsein hoover is it ok to put a a small fridge on top of the machaine
I would not really recommend it as the fridge would be subject to vibration from the washer and the washer is not specified as part of a stackable system. That said it depends what you mean by a 'small fridge' and how much it weighs.
Jan 28, 2011 | Hoover HF712 Front Load
Leaking warter from bottom small amount
EASY FIX, CHANGE WATER PUMP, ONLY 2 CLIPS HOLD IT ON, JUST LAY THE MACHINE ON ITS BACK AND THE PUMP IS RIGHT IN FRONT IT SHOULD BE WHITE OR GRAY
Nov 08, 2010 | Whirlpool LSB6000PQ Top Load Washer
Spare wheel well keeps filling with water
The back side glass seal is leaking or wheel well seam leaking take the tire out drill a hole 3/8 or so
in the bottom so it drains when it rains or check it whith a warter hose
to find out where the warter is comming from
Mar 20, 2010 | 2002 Jeep Grand Cherokee
My dishwasher is leaking and I think the water wash level is to high. Is this adjustable. Thanks Geo.
Hi if your dish washer is leaking you need to replace the door seal please try this first look at seal for damage around the door warter should not come past this seal thank you for useing fixya please rate me
Mar 18, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Leaking washer
Replace the valve, or if new, have them do it. You are sure it is the valve and not where the hot warter hose attaches? Confirm by hooking up hot water under preasure to see if that seals itself.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Water leak
hi
wife had a 2001 focus estate with same problem
the problem was the seal arround the pollen filter which is situated under the bonnet just under the windscreen on the passenger side
hope this helps
dave
Oct 30, 2008 | 2000 Ford Focus
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
