Question about Lexmark X4580 InkJet Printer
Hi, I have downloaded the software for the printer and have tried to print 4 documents.The printer is showing downloading application list then after a few mins it comes up with cannot retreive application list.The printer icon on laptop is showing 4 documents pending.How do i get it to print?
    Problem Solver:
  • 6 Answers
Check the settigs.
Posted on Mar 18, 2011
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
Brother printer mod. 420cn will print test page from computer but will not print any documents from computer fhs1950
if it will not print any document FROM an application on the computer, try another application. while your at it, make sure it is pointing to the correct printer. check your printers list if there's a duplicate printer icon.
Oct 12, 2008 | Office Equipment & Supplies
Hp photosmart C7250 hangs while printing
Hi Georgette,
You have tried your best with possible troubleshooting to fix the issue. There are few possible workaround solution for this issue.
First, If the USB Cable is more than 3-5 ft long, it could be the reason. Also, if the USB Cable is worn out or is broken in-between.
2nd, The printer does not seems to accept command from PC ( win 7 ) using the HP Software. So Uninstall the Software. Restart the PC.
Do not install Printer Software. Connect the Printer USB to PC and Windows 7 will display new hardware detected message.
Continue with the New Hardware Found Wizard and install the drivers it will list by Default.
Try to print and it should work.
If this works, You will be able to print without any problems however if you want to scan a document, you need to use Applications like MS-Paint, Microsoft Word etc, or Use the Scanners and Camera option in Control panel.
You can then install the software disk of printer or the downloaded software from Hp website to install Printer software for SCanning.
If you do so, you will find 2 printer icons in Printers Folder. First one will be with WSD text ( this icon is created when you connect the printer using USB without installing the printer software ) and 2nd icon will be HP Photosmart C7200 All in One ( this will be the Software installed ) and this will be default icon with check mark.
Whenever you want to print from any application, You need to click on File - Print - choose the WSD icon to print.
Regards,
Sean S
Sep 19, 2012 | HP Photosmart C7250 All-In-One Thermal...
How do set up my lexmark pro901 to scan to my pc so that I can email the scans
Make sure the Lexmark Pinnacle Pro901 printer driver is installed on your computer. If you have the install disc that came with your printer, just insert it to your computer hard driver and follow the instructions on your computer screen. You can also the download the printer driver from the Lexmark website at http://bit.ly/d3ftso. Select your operating system > download > execute the file. Again, just follow the instructions on your computer screen.
Note: The install disc contains the Lexmark OCR scan software necessary for scanning documents for editing and saving them as PDF files. The downloaded driver does not contain the OCR software.
To scan to your computer using the printer operator panel:
1. From the home screen, navigate to Scan to Computer: Scan > Scan to Computer
2. Touch USB-Connected Computer or the name of a network computer. The local or network computer is the destination that will receive the scan. Wait until the printer has finished downloading a list of the scan applications available on the selected computer.
3. Select an application (in your case your email), and then touch Accept.
4. Select the color, resolution quality and the original image size. If necessary, touch Accept each time you make a selection.
5. Press the start button to start scanning. The scan is complete when the application you selected in step 4 opens on the destination computer, and the scan appears within the application as a new file.
To scan to your computer using the printer software (Lexmark Printer Home):
For Windows:
1. Click Start.
2. Click All Programs or Programs, and then select the printer program folder from the list.
3. Select Printer Home.
4. Choose your printer from the printer drop-down list.
5. Click Email, and then select Photo, Document or PDF.
Note: You can select Document only if an OCR application is stored on your computer. Scanning starts and the scan progress dialog appears.
6. When the scan is finished, a new e-mail message is created with the scanned document automatically attached.
7. Compose your e-mail message. Note: If your e-mail program does not open automatically, then you can scan the document to the computer and then send it through e-mail as an attachment.
For Mac:
1. From the Finder desktop, double-click the printer program folder.
2. Double-click the printer Center to open the All-In-One Center.
3. From the "What is being scanned?" menu on the main screen, select a document type.
4. From the "How will the scanned image be used?" menu, choose To be viewed on monitor/web page.
5. From the "Send scanned image to" menu, choose an application.
6. Click Scan.
7. Retrieve the scanned image from the application, and then send it through e-mail as an attachment.
I hope this information has been helpful.
Sep 19, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Cannot Scan Document into my computer after doing the following: click scan; click download to computer; clicked OK; receive message Downloading Application; then receive message cannot retrieve...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 24, 2011 | Lexmark X4690 Wireless InkJet Printer
HOW CAN I DOWNLOAD THE SOFTWARE OF CANON MP190 TO ALLOW ME SCAN MY DOCUMENTS
Hi, The MP drivers are necessary to print documents and scan images.These drivers must be installed to use the print and scan features.The MP Navigator EX software for windows allows you to scan,save and print photosand documents.You can also edit images or attach images to e-mail using this application software.To download the softwares if you don't have the cd,
1)Go to software.canon-europe.com 2)Under Multifunctionals Select PIXMA MP 190 3)Select your operating system. 4)select your language. 5)Download the drivers and install it
Hope this information is useful to you. Feel free to post your comments. THANKS FOR USING FIXYA......BEST WISHES.....
Dec 09, 2010 | Canon PIXMA MP190 All-In-One InkJet...
I am trying to get my dell v305w printer to scan and it keeps telling me downloading application list and then it says after 2 mins unable to download apps
The printer is trying to connect to your pc to download a list of programs to send the scanned document and/or picture to when you use your scanner.
The printer will only scan to certain software and there are separate choices for handling pictures and text documents.
When it tries to communicate with your pc to find software that it can scan to, its not finding any installed that will work with your printer. Its telling you that it is unable to get the list of applications after attempting to connect with your pc.
So, what does that mean?
It means that either "bi directional support" is not enabled in your printing preference so your printer is limited to sending info one way oly (to the computer). If this is the case you can go to your control panel and then choose printers and check the preferences listed there.
OR
You don't have applications installed in your pc that your printer can send scanned documents to.
If this is the case then you need to install software that your printer will work with and then set the options on your printer to pick the default you want to use with both pictures and text documents.
Printers usually accept microsoft word, word pad, microsoft works and any other word processing software to scan text documents to.
Printers usually accept just about any picture editing software installed on your pc to send scanned pictures to.
You can avoid all of the above by checking to make sure that your printers software is 100% installed including the scanning features. Go to the Dell website and update the drivers on your printer to make sure you have the full version that is most current.
The printer will always use its own program to scan both documents and text to regardless of the other software applications you might have installed on your pc.
Sep 27, 2010 | Dell V305w All-In-One R840635AU InkJet...
I've installed the software for my x3550 printer, and when I try to scan a picture via wireless, I select my laptop and it shows on the display: "Downloading Applications List". After that it displays:...
Hi. This printer is wireless for the print function but not for the scan function, go figure. In order to scan you must hook up the printer to your puter via a USB wire.
Aug 11, 2009 | Lexmark X3350 All-In-One InkJet Printer
Document Not Printing, How can I download Printer Driver Installation?
Here is the web page for your printer software:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=412108
Select the software you require from the list.
Regards,
Graemevm
Apr 28, 2009 | Computers & Internet
Printer "out of memory"
The problem isn't your printer. The problem is with your Microsoft Works software. I know of six solutions that may work.
1) Download the latest service pack for .NET Framework 1.1. http://www.microsoft.com/downloads/details.aspx?FamilyId=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en
2) Go to this website and download the update. http://www.microsoft.com/downloads/details.aspx?FamilyID=65f5b806-e6a1-4f92-a656-e56eeda67e3d&displaylang=en
3) Uninstall printer completely (again). Unplug the printer from the computer. Reboot computer. Download the lastest driver from HP website. When installing the driver software, choose (type)a different directory,( ie. C:\MYHP\HP4180\ ). Plug Printer back to computer.
4) Go to this website. http://support.microsoft.com/kb/841220
5) Click START, click RUN, type SPOOL. Double click printer folder, clear (delete) any files in this folder.
6) Download the latest version of Microsoft Works 9.0.
Let me know if this works.
Feb 03, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Lexmark X4580 InkJet Printer Logo
110 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
