Question about Ingenico i6780 Signature Capture Pad - (6780US0035)
Trust issue startup blocked message - Ingenico i6780 Signature Capture Pad - (6780US0035)
Hii when im conecting the webcam a message box is showing after 2005.11.1 error.can u help me?
Are you XP?
A choice; Uninstall the webcam and reinstall with newer drivers or
Try this;
Click start, run, type msconfig and click ok.
On the 'General' tab, tick 'Selective Startup'.
On the 'Startup' tab, uncheck all except your antivirus programs.
Click apply, click ok, and reboot when prompted. When the System configuration utility dialog box appears on restart, put a check in the box to not show this again, and click ok.
If this stops the error message, go back to msconfig and recheck half the startup items. Click apply, ok, and reboot. If the message comes back, you'll know that one of the items you rechecked is causing the issue. Continue this way until you isolate the program that causes the message.
Feb 27, 2011 | Computers & Internet
Hi,just got a tocco lite and it is not receiving messages,i cant remedy it and nothing in instructions help! thanks
Most Samsung phones have a block list for messages. This is very useful if you are getting hassle from someone but it is too easy to inadvertently add someone you trust to the list.
I cannot remember where it is in the Tocco lite but look under the messages section for the blocked list and remove any numbers that are in there.
My friend once had a similar problem and her husband could not send her messages. She was shocked to find his number in the blocked list and as soon as I deleted it, he could send her messages again.
Feb 06, 2011 | Cell Phones
Since installing Windows XP, replacing Windows 2000 on my PC I get an error message on start up that there is an issue with my CD driver and that this may cause instability. The drive works OK and no...
the message is likely association with an item listed in the MSCONFIG startup group. The message itself seems harmless and if the system is running to you satisfaction, nothing has to be done.
If you want to try and get rid of the error, open MSCONFIG, startup tab and uncheck all items and reboot. if the issue is gone on reboot, then one of the items in the startup group is the issue, go back to MSCONFIG, re-check the top half, reboot see if the error comes back. Continue rechecking half the remaining items till you isolate the section the issue is being generated from, then unchecking just 1/2 of that section get doing halves till you isolate the 1 entry that is the issue (Usually can be done in 7 to 8 reboots) once determined, leave that item unchecked and if you have no further issues, you are done.
IF leaving that item unchecked causes another issue, the see if there is an updated driver for that item
Jan 16, 2011 | Computers & Internet
I have got virus on my comp & admin rights are blocked, i need to format my machine but it's not allowing me stating some other disk utilities are running, control panel access is also blocked, please...
Try to start your system in safe mode , and scan your system for viruses, You can also try installing Avira Free Antivirus which is very good at removing viruses,
if you are not able to get through this, try doing system restore, trust me I have tried it multiple times it works. If you have windows 7 you can get to startup and repair by tapping F8 at BIOS and do System restore.
Oct 30, 2010 | Microsoft Windows XP Professional
Run dll32 stopped working. Cannot access software with mouse.
Please follow these instructions to check which software is causing this issue:
1. Click on Pearl (Start Button), in the serach box type:
msconfig
and hit the enter key on the keyboard. It should open the System Configuration Utility window.
2. Click on Services over the top and then at the bottom right corner, put a check in the "Hide all Microsoft services" checkbox.
3. Click on "Disable All" button.
4. Click on "Startup" tab, and then click on "Disable All" button again.
5. Press OK button and then "Restart" button on the following window. Let the computer restart.
6. Once you're back on the desktop, you'd get a window for System Configuration Utility. Put a check in the box "Don't Show....." and then press OK button.
7. Now, once again check the issue. If the issue is resolved, open System Configuration Windows again and then enable all the services from Services tab and then check the issue after restarting the computer in the same way as mentioned above.
8. If issue is still resolved, enable half of the Startup items from Startup tab and then check issue.
9. If issue occurs again, it means, there's a culprit in the checked startup items. But if issue doesn't occur, then issue could be with rest of the Startup items. Now, uncheck the first half startup items (that were check before), and then check rest of the half items. Check the issue again.......
10. Now, if the issue occurs, then make a note of all the names of the startup items and then follow the same procedure, for them. Now, you need to be careful, as by design the System Configuration will sort all the enable startup items to the top. So, it means all the entries would be mixed on next reboot. From now on you need to make a note of all the entries that you're enabling or disabling........
I know guys it's a bit lengthy process, but trust me it works in both XP and Vista. I'm one of the Microsoft XP/Vista Techs............BEST OF LUCK...........!!!!!!!
Dec 29, 2009 | Microsoft Wireless Laser Mouse 5000
I need the moves list for marvel nemesis for ps2. i bought the game with no book and i only know what the game tells me under controller in options. i keep getting my **** kicked by all these power moves. ...
msconfig
Dec 29, 2009 | KEIO PS2 Optical Scroll Mouse
I cant recieve or send texts out of no where but i can recieve and send calls
You may want to call your wireless provider to make sure they haven't blocked text messaging on your account. I had text messaging blocked on my account for a while because I had two children on my account and couldn't trust them not to run up the bill.
Apr 16, 2009 | LG VOYAGER VX10000 Cellular Phone
Error message: another program has control of the device
I have had a similar issue before where I was unable to utilize the HP software for scanning. Have you added any software recently or run any updates on software?
I had to utilize msconfig to disable services so that I could re-enable the services one by one to see what was causing the error.
To do this you will need to click on Start-Run and type msconfig then click Ok. Go to the Startup tab and select the Disable All button. You will then have to reboot. After you have rebooted, try to scan. If you are able to scan, then you will know that one of the programs in startup is causing the problem. You will now need to go through msconfig-Startup tab to re-enable each item one by one, and you will have to restart your computer after each time so that the change will take affect. It is a lengthy process, but the end result will be that you know which item is blocking your HP scanning.
Please let me know if this has helped you or if you would like further assistance. Thank you.
Mar 27, 2009 | HP PSC 2510 All-In-One InkJet Printer
Western Digital Elements 500gb External Drive. When i switch on the computer with the external drive attched, the screen comes up eith an error message and ask to uninstall the hardware. It works only if...
Go into your computers BIOS screen. (on most computers, press F2 or the Delete key to get into the BIOS) and remove USB from your Startup list. Different Bioses preform this different ways so I can't tell you how to make sure this happens but trust me, it's in there.
Nov 09, 2008 | Computers & Internet
Ingenico i6780 Signature Capture Pad - (6780US0035) Logo
242 people viewed this question
Top Ingenico Televison & Video Experts
Electro Med Services...
Are you an Ingenico Televison and Video Expert? Answer questions, earn points and help others
