Question about Datel Action Replay for Nintendo DS
My action replay is recoginized by pc just not code manager and it worked only once and now i want to connect again i will erase AR just to connect again
  • 12 Answers
SOURCE: action replay code manager doesnt see the action replay
Many are experiencing this, what you are looking at here is a faulty action replay. go to the Datel website and submit your serial number to them, it will immediatly say whether or not your AR is from the time period when they had a problem with the internal USB reading system, if it is, then send it in and one will be shipped withing 10-12 weeks
Posted on Mar 28, 2009
  • 12 Answers
SOURCE: my action replay code manager is empty and I want to add pokemon
Heres your problem, I believe you just recently purchased this AR, the new version of action replay require a software update found on Datel's website, after downloading this software your Domain Suffix of your Optical Drive will automatically replace the program with the newer one. Open up your winsock processor and buffer the Native file of your AR back into your fluxus core before adding codes to your action replay, if this does not fix the problem, submit a complaint to the Datel Hacking Team located at PO box 45265 North Ridge, CA. This whole process should take anywhere from 10-12 weeks to fully resolve
Posted on Mar 29, 2009
SOURCE: My Action Replay DS code manager is not recognizing my AR DS!
i have the same problem
Posted on Jun 04, 2009
SOURCE: aR keeps saying waiting for ds and how can I install driver soft
same herre
Posted on Jun 10, 2009
SOURCE: guys my ar code manager says it cannot work
my answer is that action replays do that they **** i hate them they mess up all the time
Posted on Jul 28, 2009
My action replay doesn't work with the game Animal crossing Wild
There are two possible reasons why it won't work 1. You used may have used to many cheats at once which overloaded the Action Replay. 2. I have noticed that sometimes there are a few bad codes that cause the game to mess up and freeze when the Action Replay is used.
Happy Fixing :u)
Oct 19, 2009 | Datel Action Replay for Nintendo DS
I dont have the cd for the action repay
if u dont have the ar cd, that's ok. you use the cd and ar cord to install the action replay code manager. if you go to a website like neoseeker or supercheats that has action replay codes posted, you can copy a code and then go to the ar code manager and add it to your codelist. i only use the code manager for really long cheats. you can still enter cheats manually to ur ar, but without the disk, you cant quickly put long cheats onto ur action replay. you can get an ar disk at walmart, target, or gamestop. sorry if this is too long, but i hope it helps.
Jul 14, 2009 | Datel Action Replay for Nintendo DS
I downloaded the AR code manager,and it doesnt recognize the AR
Then your ds card slot where you put the game or action replay might need cleaning i use a dry Q-tip and rub very very gently or your action replay is busted :P hint do not put in too many codes my mistake let just say its a magic eraser :P
Jul 02, 2009 | Nintendo DS Lite Console
My action replay code manager is empty and I want to add pokemon
Mar 23, 2009 | Datel Action Replay for Nintendo DS
My Ds Action Replay Went BLANK!
i have had a similar prob it wiped all the games andm then i could not put more on because it went multi coloured when i tried so i hap to reset the entire thing to do so(source codejunkies):
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
  1. With your console powered off insert the Action Replay DS
  2. Hold down buttons A+B
  3. Turn your console on
  4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
  5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
  6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
copyed from code junkies
Mar 20, 2009 | Datel Action Replay for Nintendo DS
Action replay code manager doesnt see the action replay
Jan 15, 2009 | Datel Action Replay for Nintendo DS
Erased Action Replay
Well, you're going to have to install the AR Code Manager on your PC. When you do that, insert your AR cartridge into your DS and plug it in via the USB cable on the PC. After that it should attempt to load your current code list. If nothing pops up hit the "Quick Update" button at the top, it should delete your current game codelist and download the new codelist from one of the sites listed.
Dec 31, 2008 | Datel Action Replay for Nintendo DS
My Action Replay nds refuses to be detected by the PC no matter what I do!
try to get action replay and it has all the code in usa through 2006 to 2007
Feb 21, 2008 | Nintendo DS Lite Console
Sorry, my last desc should be ignored here are all to solutions to problems. I know:
Prob: Two white Screens:
Solution: none so far, have emails sent to Datel. see what happens. This occurs when attempting save codes with the DS and the AR is pulled out or DS powered off. My suggestion if you get a new one, only update codes using the PC software.
Prob: AR keeps asking for game cart. insertion:
Solution: remove AR and put in game cart.
Prob: AR not enough memory to update codes:
Solution: there is more bugs in their software/firmware that doesn't really know when items are deleted and space is free. You must reset AR cart. and then use the PC software to reload all the codes:
a) First I would update the AR PC software (no DS AR connected)
b) Connect DS with AR to PC then update the AR firmware
c) Disconnect DS AR from PC
d) DS off hold A+B when TURN ON DS when DS logo shows press START+SELECT with A+B still down as well, hold for a while. turn off DS
e) Reconnect to PC, turn on DS and drag the PC US codes to the DS side. (Note: I had to do 4 & 5 a couple of times it finally worked)
Prob: AR PC software not seeing the DS AR connection: Solution: The PC drivers are not being found for the NDS link. You need to do the following:
a) close the AR PC software, and disconnect the AR DS.
b) connect the AR DS and then the windows new hardware driver install window pops up. must select using the manual browse option.
c) go the the action replay directory either on the action replay CD you bought or from a extracted version from the web. (NOTE: this is not the installed location, but before where the setup.exe exists) I had lost my CD and did about 10 minutes and found a .rar of the source code.
d) pick the action replay subdirectory and click on install
e) you should see the NDS link drivers being installed.
f) start the AR PC software and attempt to connect the DS AR it should work.
-- I hope this helps anyone --
Nov 23, 2007 | Nintendo DS Lite Console
Datel Action Replay for Nintendo DS Logo
20 people viewed this question
Top Datel Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Martin Murray
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
