Question about D-Link DCS-5300 Network Camera
What is the default ip and password of dlink dcs-5300 networl camera? pls help me.
SOURCE: Password and user id
Reset the camera by holding the reset button for 3 seconds (use a paper clip in the hole marked "Reset" on the back). The camera will then reset to all default settings, including an IP address of 192.168.0.20.
Posted on Nov 30, 2007
SOURCE: DCS reset
Push the reset button on the back of the camera
Posted on Feb 23, 2008
  • 3 Answers
SOURCE: IP camera keeps resets itself
Hi
I have a pretty good knowledge of these cameras as I have 5 around my house.....
IP address resets are likely caused by the default address being loaded (192.168.0.99) and the box is not checked to reset the IP on reboot. You have two options.....
Using IP surveillence, open the camera settings. You will be prompted that the recording will stop, just press OK. Once you get to the settings window, you should see your list of cameras and the config screen for the one that is highlighted. Pick the camera you want to change the setting for and go to the tab where you can assign the IP address and gateway. Type in the IP address you want it to use. Uncheck the box that says 'reset IP on reboot'. That box is at the top. Hit apply. Once you do that, cycle the power on the unit leaving it off for at least 10 seconds. When the camera reboots, type in the new IP and you should be able to view it. (sometimes the camera will default on that IP if your router is using 192.168.0.1 and DHCP for computers that has that IP in it's range of assignments of IPs. Telling the camera which one to use and telling it to not reset on reboot will make the new IP stay in the camera.)
Your second option is to use the Installation Wizard or IE, find the camera either by typing in the IP for the camera in IE with the http:// or linking to the device with the installation wizard. If you follow the same procedure of assigning the IP and unchecking the box on reboot like described earlier, this should cure your problem. You do NOT want the IP resetting on reboot unless the camera will not link to your home router (likely causes for this is the IP range the router uses, say 192.168.1.1 like most belkin or linksys routers use, does not cover the IP range of the camera in it's DHCP server.
What I found best was to buy a junk router, set it's DHCP IP range to cover 192.168.0.99, set the camera, save it, kill the cameras power, connect it to the router you plan to use, then start the camera back up. Make sure whatever IP address you use on the camera is one covered by the DHCP server list on the router. ie: camera is set to 192.168.2.2 and the router assigns IPs from 192.168.2.2 through192.168.2.254. If your router only assigns IPS from 192.168.2.100 through 192.168.2.200 and the IP on the camera is 192.168.2.2, you won't be able to connect to it.
Hope this helps
Posted on Sep 20, 2008
  • 477 Answers
SOURCE: what is the default ip address of D-Link DCS-3220
Hello
The D-Link DCS-3220 have DHCP, that means it gets a automatic address from your router.
IT doesent have a STATIC ip, if you not set it manually.
To configure your D-Link DCS-3220 CAM and find the IP you need to install this program.
Install Wizard You need to unpack it first.
Connect your computer and cam to same router and run the program. Then it should find your cam so you can configure it and see what ip it get your you set.
Then you can browser to the cams IP.
Here is the manual and instruktions for you CAM
Here is Quick install guide
Here is you Dlink cam site to get firmware updates and more.
Hope it works.
Posted on Jul 09, 2009
jan mczeal
  • 632 Answers
SOURCE: My DLink 5300 G internet camera suddenly says "No Signal."
  1. Remove the Java update and roll it back to the previous state.
  2. If it does not resolve the issue, reset the camera.
  3. Lightly insert a paper clip or a similar sized object into the reset hole on the back of the camera, press lightly and then release the button.
  4. The LED on the front of the camera will begin blinking red and green.
  5. When the LED stops the blinking, the reset has complete.
  6. If the issue is still present, restore the camera to factory settings.
  7. Insert the paperclip or other tool and press on the button continuously.
  8. Wait for the LED on the front of the camera to blink red and green and hold the button through two cycles of blinking (about 5-7 seconds.)
  9. Withdraw the tool after the second cycle of the LED blinking and factory restore has been completed.
  10. Run the installation wizard. If you don't have the installation CD, go to the manufacturer's website and download the software.
Posted on Nov 10, 2009
How to recover dir-600 dlink router password withoute reset
You need to log into the dlink router and look at the Wireless Security and you will see the password. To get into the router you will need the ip address of the router, the default user id and the password. You manual will give you this info if you do not know it.
Get online and got to www.google.com In the google search box type: "Dlink Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals.
The IP address to put in your browser to get into the router is: 192.168.0.1
The default userid is: admin
There is not default password, so leave it blank.
Jun 05, 2012 | D-Link DIR-600 Router
What is ip default dcs-3110 network camera?
Please follow this process for IP Address:-
http://setuprouter.com/router/dlink/dcs-3110/login.htm
Dec 29, 2010 | D-Link Dcs-3110 Megapixel Camera DCS-3110...
What is the default ip address of D-Link DCS-3220 ip cam ?
Hello
Hope it works.
Jul 09, 2009 | D-Link DCS-3220 Network Camera
Lost driver for webcam
Software, drivers, firmware and manuals located at:
http://support.dlink.com/products/view.asp?productid=DCS-5300
May 03, 2009 | D-Link DCS-5300 Network Camera
DCS-1000w through Dlink DIR-655 router
These cameras are touchy. Hold the reset button on the back in for about 20-30 seconds. Bring up the CD software you got with the camera, it should spot the camera right off and you can configure. That seems to be the only way I can communicate with this model. After setup, then browsers, etc seem to work fine. I would also download the latest Firmware and update.
Apr 12, 2008 | D-Link DCS-1000W Personal Web Camera
D-Link DCS-5300 Network Camera Logo
1,995 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
