I normally use 1 burner on heater. when i switch to two burners it struggles to light when it do light its very noisy for length of time i have it on.
    Brigadier General:
  • 4,736 Answers
Patrick, from what you have described, the heater needs a thorough cleaning, as the second burner's air intake control valve is partially clogged with dust and or lint.
Posted on Mar 18, 2011
How to fix a pressure switch on a goodman Gms807034ana
Since the burners light this eliminates the pressure switch as the problem. Typically when the burners come on and shut off quickly a flame sensor, ground problem or the limit switch tripping are the main reasons. Since the flame sensor has been replaced, check the limit switch
Jan 04, 2013 | Goodman GMS80453ANA Open Flame Mid-Size...
Rinnai reh15-217 burners cut out automatically after being on for about 1/2 an hour
If you're saying the burners turn OFF after 1/2 hour, but the pilot light stays lit ... I'd have to assume that the automatic thermostat control on the heater, turned the burners OFF, because the temperature you had it set on had been reached. The real question (at least for me) is are you allowing enough time for the temperature to drop and the heater to turn back ON automatically?
May 16, 2011 | Heating & Cooling
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
Ran out of propane, Stovetop has ignitors and they seem to be functioning fine. When turning on knobs there is plenty of propane smell but the burners fail to light.
This is normal when you run out of propane. Depending on the length of line you have, there will be a delay in relighting it again because of insert air in the line. My advice to you is to first air out the house til the smell is gone. Then turn on only 1 burner with the igniter sparking and also hold a handheld bbq lighter at the burner to ensure that the gas burner lights when the air is finally purged. This should only take 20-30secs. If it takes longer, air out the room and try again. Use common sense and please be careful!
May 18, 2010 | Thermador Cooktops
I have a goodman central heating . My problem is the electric ignitor will light the burner after a brift time the burner goes out. This problem will go on the entire time of the heating cycle. I have...
Hi!
First of all does this unit uses a hot surface ignitor or a spark ignitor? A hot surface ignitor is a resistive element that will get hot enough(glows yellow to near white) that ignites the main burners directly and a spark ignitor will light a pilot light first then that pilot light will ignite the main burners.
If your system uses the hot surface ignitor then there will be a flame sensor on the last burner that lights. This is a thin silver metal probe that is actually in the burner flame when that burner is lit. It is held in place normally by a 1/4 inch screw. It will have 1 wire attached to the end by a female spade connector. You can pull this wire off before you remove the flame sensor to clean it. Use a fine emery cloth to lightly sand off any residue on it. Also you will need to clean the end of that burner that the flame sensor serves as this is normally the grounding field. This is most likely the problem with your system if it is a hot surface ignition type.
If your system is the spark type then the problem is similar. Normally the pilot light is toughing a small flame sensing probe that is next to the pilot light. This probe also has to be clean. One more thing to look at is to see if the pilot light is large enough to surround the flame sensor. If the pilot is weak it will not touch the flame sensor enough and the system will do what it is doing for you now. If the pilot is weak then the pilot orfice is restricted. This should only be looked at and repaired by a qualified service technician. I hope I pointed you in the right direction!! Good luck!!
Dec 02, 2009 | Heating & Cooling
Gas Flow Problem
Replace the regulator and hose assembly that screws onto the propane bottle. I had the same problem on two patio heaters and my 4 burner grill. You can get regulators and hose at Home Depot, Lowes, Northern, probably Meijers, etc. Check the fitting on the end of the hose for the correct gender, male or female, size, and hose length. You can get a fitting in the plumbing department to change the gender.
I can all but give you money that this will fix it.
Jan 15, 2009 | Char-Broil Performance 463463006
Igniters won't turn on & unwanted flammes
You say you have no sparks coming from your gas range, but your rear burner is lighting. That doesn't quite make sense. If some of your burners are lighting, then the problem can't be with the spark module. The spark module sends a spark to ALL the igniters at the same time. That is, EACH burner switch, when turned to ignite, will cause a spark to go to ALL the burner igniters at the same time. Just watch the next time you turn one of your burner switches on, and you'll see a spark at all the burners simultaneously. This is normal. I suspect that you have a bad igniter switch or wiring harness. For example, if you have a front burner that won't light, but WILL light when you turn on another burner, the spark is being provided by a working burner switch. This is also normal. Now, am I assuming that your back burner will not light properly, but will light if you use the front burner? If so, the burner switch for the rear burner is probably bad, or the wiring harness has a break somewhere. Now...if you have no sparks, as you say, but randomly a burner will light, then I would suspect a bad spark module. I hope I'm not confusing you here. In a nutshell: One burner doesn't work, but all others do - bad burner switch, or wiring harness. No burners light, or light randomly - spark module. I hope this helps you.
Jul 28, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
