Question about Saeco Talea Touch 14-Cup Coffee Maker
What is message "prime water circuit" not in
  • Anonymous Mar 19, 2014
    Trying to brew a cup, there is a message on the display that says "prime" and it won't let me brew.
  • Anonymous Mar 22, 2014
    keep trying to prime - goes through motions but hardly any water come out. It then goes back to the error message
    Problem Solver:
  • 5 Answers
Fill the water tract with the water. For example - swith the steamer to hot water dispence and run water for several seconds (untill it goes smoothly).
Posted on Mar 23, 2011
  • cocco288 Jul 02, 2011
    I too had the same error message, "prime water circuit". I tried running lots of hot water and my problem is still not solved. And now, the coffee does not drip out, and the rinse cycle does not make any water come out either! Has anyone brought this problem in for servicing? Please help.. thanks!
    By the way, I bought this machine only 2 weeks ago so this is quite discouraging.
Did you find the answer yet? I just had this problem today. Please help.
Posted on Nov 11, 2011
Message prompt says "prime", what
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 22, 2011 | Keurig B50 Coffee Maker
Message "prime" appears on display
heatman101
Jul 14, 2011 | Keurig B60 Coffee Maker
My new gaggia platinum vision will not prime. it says "prime water circuit" and makes several loud clicking sounds and then says "restart to solve the problem", but this doesnt solve...
We had the same problem on our machine, and it was fixed by backing the strength setting (the physical dial on the front of the machine) off from the "maximum" setting a small amount. Somehow this was creating too much back pressure, and the useless "will not prime" message appeared.
Dec 29, 2010 | Microwave Ovens
Error 5 message on lcd screen. What does this mean?
That means prime the water circuit. It should prime by itself. If the machine is making noise and still failed to prime, you can do it manually by going into test mode , set the multi valve to hotwater position and operate the pump . When the water flow freely turn off the machine and restart it. Hope it will help.
Jun 03, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
Message
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. clean machine with the Saeco scale remover thank you ,Lee Davidian
Jan 17, 2010 | Saeco Magic De Luxe Espresso Machine
My machine seems to be set on ventiate. it wil dispense hot water but that's it.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. I hope this helps , Lee Davidian
Dec 27, 2009 | Saeco Royal Digital Plus Coffee...
My Saeco Royal Coffee Maker keeps giving me a ventilate message and wont do anything else. What is wrong? And how can I fix this?
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. Hope this helps , Lee Davidian
What is the priming?
Prime refers to priming the pump. The error message means that there is air in the system which is preventing the pump from pumping water. To correct this, fill the tank with water, press the water button on the right side, and turn the water/steam knob to open. Allow the water to flow until the stream is steady. Press the water button again and your problem should be fixed
Feb 14, 2009 | Saeco Aroma Espresso Machine
Saeco Odea GO How do I
This is a common problem that is not explained in the manual. Turn the left silver knob on the top deck of the machine past the steam icon to the water drop icon. Let about eight ounces of water out into a cup and the circuit is primed.
Apr 13, 2008 | Kitchen Ranges
Saeco Talea Touch 14-Cup Coffee Maker Logo
1,317 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
