Question about Amana Refrigerators
The plastic track on the dairy product tray has split and hence the plastic drawer drops down. Is there anywhere I could purchase a replacement runner track? The refrigerator is an Amana model SR5 20T W Thank you
  • Amana Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 18, 2011
Do you have to remove the screws on the ice-maker to remove the plastic icemaker service tray.
I believe you are talking about the shut off arm. You need to remove the lower freezer drawer. Pull it all the way forward and then lift up. The screws are under the icemaker.
Nov 01, 2014 | Sub-Zero 736TCI Refrigerator With Ice Box
How do i repair fisher paykel dd603 problem top drawer stuck on fast cycle, bottom drawe stuck on normal cycle
you will need to replace both draws control boards, with the dd603 control boards they have a small touch button panel on the top of the board which they didn't put a protective layer or plastic over and basically what happens is steam gets on the copper tracking and corrodes it hence the fact it doesn't work anymore, all new control boards even the replacement for yours comes with a plastic strip over the board. hope this helped
Oct 06, 2014 | Fisher and Paykel Dishwashers
Hp 1320 drawer stuck
hi
The paper tray has a small lock at the bottom of the tray which is broken or dislocated hence try to fix it if its dislocated or you may have to replace the try itself. But still you can use it by adding paper to the full of the tray's capacity and pressing it gentelly downwards and push it back into the printer.
May 05, 2014 | HP LaserJet 1320 Printer
How to replace samsung flex-tray ice tray
On my model RF265AABP, it is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out. Yours may be different.
z
Ice maker assembly upside down on bench.
Apr 10, 2013 | Samsung RS2530BBP (25 cu ft) Side by Side...
The detergent drawer will not shut, it seems jammed but when checked nothing there peventing shutting, also small plastic part, funnel and tube has dropped into detergent drawer, don't know where its come...
What you descibe- 'small plastic part, funnel and tube' sounds to me like the softener/conditioner drawer vital part! Because softener is fluid the drawer cannot just be open-ended like the pre-wash and wash parts else the softener would drip straight into the drum on pre-wash/wash! The water/softener mix is designed to siphon down this tube/funnel.
I would think that you could see where these bits have broken off. You will probably have to purchase a replacement.
I wonder if you have managed to take the detergent drawer completely out? If not here is an idea of what to do (I've copied and pasted almost all of my guidance notes on cleaning the softener part) -
Remove the complete drawer. To do this you will have to do one of the following-
  • push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck,
John C
Feb 21, 2011 | Washing Machines
Model 363.9668513 water collects under the fruit
this is because the plastic is shiny and attracts condensation,only "cure "is a piece of kitchen towel under drawer to mop up as/when.(when you open door all the cold air drops to the floor and is replaced with warm moist air from the kitchen.hence condensation.
Apr 13, 2010 | Refrigerators
The deep blum drawer has fallen down on one side.
it has slid off the track. remove draw inspect rails on side thatis down
Dec 22, 2009 | Dmm Blum Tandembox Sink Drawer With...
Dairy products are seperating
Time & temperature. Even if kept at the proper temperature, dairy products will separate in time. Bacteria will also do it. If you drink from the bottle, the enzymes in your saliva will infest and break down the whole container. It's being digested in the container, like feeding baby food from the jar. The food in the jar becomes watery, because it's being digested.
Aug 01, 2009 | GE GTS22KBP Top Freezer Refrigerator
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
DVD tray is out of alignment
Usually, if you are able to pull the tray as far out as it will come, then hold the tray in the front and gently twist the tray up and down. Then move it slightly left and right it will usually pop back in place.
It acts somewhat like a drawer when it get off track. Just make sure that you are very gentle when moving it so that you dont break the plastic tray.
Hope this helps. Please remember to rate this information.
Thanks
Sep 03, 2008 | HP Pavilion (PN153AAR) PC Desktop
Refrigerators Logo
43 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
