Question about IBM ThinkPad T42 Notebook
My ibm t42 is unable to switch on. it does no charge when i plug in the power cable. i also charged the battery in another IBM laptop but when i tried on mine, it did not switch on. i then opened it and check whether the various components were in place and functioning properly; it did but the laptop is not switching on.... can someone help me?
It seems that the board is defected. If you see no led lights then you need to replace your motherboard.
Sorry
Posted on Apr 19, 2011
My laptop computer ibm t42 does not charge the battery
Hello....those T40 series laptops which I use to support at a previous job. They would often develop these same issues. We would often keep them in stock because after a while the batteries just don't hold a charge. Its not that the laptop is not charging them. The battery simply does not hold the charge.
Gary Paul
Jan 27, 2010 | IBM ThinkPad T42 Notebook
My previously healthy Thinkpad T42, will not post.
The Thinkpad T42 doesn't have a reset button on it like the older IBM's used to.
There could be a problem with the battery. With the machine turned off remove AC power and then the battery. Plug in AC power again and see if the laptop will boot without the battery.
If it boots let it load up as normal and then shut it down again, reinsert the battery and try to boot it up. If it boots fine, if not then there is a problem with the battery.
Please post back if you need anymore advice.
Good luck.
Jan 14, 2010 | IBM ThinkPad T42 Notebook
Battery trouble
Unless you have access to another machine to try another battery it is a case of buying a new one
Dec 25, 2009 | IBM ThinkPad T42p Notebook
IBM Thinkpad T42. About 1hr ago went black-dead. When the power supply is plugged in there is no icon illuminated. No power reaching anything. Recently have had some fan-error warnings and have been...
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 02, 2009 | IBM ThinkPad T42 Notebook
Computer works on AC adapter but battery does not charge
hi,there might be the issue with dc in cable(cable from jack to m/b) or the inverter board.
May 29, 2009 | IBM ThinkPad T42 Notebook
IBM ThinkPad - Possible Battery Issue
Some laptops have issues when you run them leaving the battery plugged in. Shut the machine off. Remove the charger, remove the battery. Hold the power button on the machine to disapate all of the residual power. Do this for about a minute. Put the machine back together and leave the battery out. Turn it on with only the power supply. If the problem resets, then your battery is at fault. If not then your charger might be shot or the invertor inside the laptop is fried. Time to get a new one (Laptop or Charger).
Apr 27, 2009 | IBM ThinkPad T42 Notebook
IBM thinkpad t42 new Battery "On line, critical"
The only way is to continue using it that way till it will not go off when you unplug.
The charger might have gone bad too.
Try the first method then replace charger.
Mar 18, 2009 | IBM ThinkPad T42 Notebook
My T42 suddenly wont recharge the battery or wrk off mainsadapter
If the Laptop wont work off the power adepter, it also will not charge. The adepter could be bad (even if showing a power light) or the connector on the laptop could be broken. The best test is to take the battery out, attach the power adepter and try to start the computer if it starts, your battery is at fault. If nothing, suspect eh charger first. Be sure the pin on the Laptop power connector isn't bent or broken.
Jan 04, 2009 | IBM ThinkPad T42 Notebook
IBM ThinkPad T42 Notebook Logo
56 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
