Question about Samsung V25 XVC 2800 Notebook
I have to press Fn to use letters onthe right side of keyboard if i dont then i get numbers instead? how do i unlockso i can use keyboard properly?
mtoal_1999
  • 25 Answers
SOURCE: keyboard problems
yes in some issues i have encountered the ribbon that plugs the keyboard in may be corrupted or you may have a bad keyboard
Posted on Aug 10, 2008
micromend
  • 748 Answers
SOURCE: hp pavilion dv1000 laptop pc keyboard not working properly.
Does this computer KB work alright in SAFE mode? If it does then drivers and/or viruses are the problem. If it doesn't work in SAFE mode then it could be drivers and or keyboard. Now try booting into BIOS. At the date prompt you usually can type any keyboard letter. If the keyboard works here, then you definately have driver/virus issues. If not replace the keyboard.
Posted on Mar 26, 2009
diddydaveh
  • 154 Answers
SOURCE: activation of the number pad so instead of
Hi, try pressing the numlock key - this should put the number pad as standatd until it is pressed again, when it will revert to letters.
Posted on May 15, 2009
  • 12 Answers
SOURCE: keyboard is not working properly-some of the letter keys also have numbers and when I type in a letter the number is coming up
look in bios, for numlock boot
thats why the number function works instead of the letter,
just got 16 odd at work and its my job to put xp pro on, with out a cd drive, if u need xp pro or another os hit me bk
Posted on May 18, 2009
  • 1043 Answers
SOURCE: i cant undo the fn key on the mini note
You should be able to turn off the built in numeric keypad by pressing the fn key and the num lk simultaneously. The num lk is directly above the +/= key. If after doing this you still find you only momentarily turn off the numeric keyboard then there is another underlying issue. At that point you should take your unit to your area HP repair center.
Posted on Jul 15, 2009
I have an Asus laptop Pro50G - the keyboard has numbers associated with certain letters e.g. J = 1 when using the function key. this morning after booting up, When I press these keys, instead of getting...
If there is a key on your keyboard that has the Fn key inside a lock icon, press Fn and that key and see if that unlocks the Fn key. You can also try pressing it normally, since your Fn key seems to have its own Fn-lock kind of setting.
If you dont have that kind of a key on your keyboard, this could be caused by an option in the BIOS. When booting up press the F2 key or whichever key your computer uses to open the BIOS. Once in the BIOS, look for an option that allows you to change the Fn key from a hotkey to something else, such as legacy.
Oct 19, 2017 | ASUS Computers & Internet
Letters on keyboard are producing numbers instead of letters, letter k gives 2, letters u gives 4 etc
that is the keypad for a keyboard to get back those letter you will need to press the Fn button and on the top of the keyboard where there is a list of F button press the one that looks like a keyboard. if that doesnt work try Fn and num lock
Jul 07, 2011 | Computers & Internet
My dell laptop types numbers instead of letters on some keys without pressing fn key
HI,
If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
Hope This Helps
THANK YOU
Feb 27, 2010 | Dell Vostro 1510 Laptop
My computer keyboard is typing numbers instead of letters.. any suggestions on how to fix it
This is because most notebook keyboards have a number pad incorporated into the right-hand side of the keyboard. Numbers are being typed because the NumLock is active.
To disable this function press the NumLock key (might be marked NumLock or have a symbol that looks like a calculator on it) on the keyboard (you might need to press the Fn function key and the NumLock simultaneously).
http://www.pcdoctor-guide.com/wordpress/?p=2446
Nov 25, 2009 | Compaq Presario 700 470024-192 Notebook
Instead of the letter ''O'' I get the number 6 on my keyboard.
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed.
Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Fn key plus and probably the Scroll keys, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Aug 20, 2009 | Lenovo ThinkPad X200 Notebook
Hi, I've got 2 eeepcs, with identical problems,
Aug 13, 2009 | ASUS Laptop Keyboard for Asus Eee PC
Keyboard buttons coming out with diffrent symbols to what i want
You have your Num Lock on, look for the Num Lock key (should be located in the top right of the keyboard) press that key and your keyboard will return to normal.
Sometimes you have to hold down Fn or shift when you press the Num Lock key.
Good luck.
Aug 06, 2009 | Acer Aspire 5720-6661 Notebook PC
Keyboard trouble
ok in the keyboard there is fn right. Hold FN+Number lock (num lk) then it should transfer back to letters
Jan 02, 2009 | Computers & Internet
Samsung V25 XVC 2800 Notebook Logo
100 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
