Question about Sony Handycam DCR-HC24E Mini DV Digital Camcorder
Hi there cannot connect i link to my pc no connection on my pc any advice would help
    Guru:
  • 276 Answers
Usually what you would do is buy a IEEE-1394 interface card and install it in your PC in an available slot on the motherboard. You can buy these for less than $20 and with a little tech knowledge about PCs many people can install the card themselves. The IEEE-1394 is called i.Link by Sony. If you are running Windows XP, or Vista, the drivers are already installed. Reboot PC and the new card should be recognized. Use the 4-pin to 4-pin firewire cable to connect camcorder to PC. You will need software to capture your video which should have been supplied by Sony with your camera. For Windows 7, you need to install LIVE Photo Gallery. Your camcorder was setup to work with Windows XP so an alternative may be to just find a friend with an older PC with a firewire card already installed running Windows XP. I just did this very same thing on my PC and it worked. Got the firewire card from Amazon.com for $3.95 VIA brand from Taiwan. I used Windows Movie Maker to capture video. Sony also sells a stand-alone DVD recorder which connects to a camcorder and requires no computer to create DVDs of your video.
Posted on Mar 18, 2011
Hi! I have a brother HL-2170W printer. It is connected via ethernet cable to a Dynalink RTA1046VW router (which is sitting on top of the printer) and I have a HP pavillion entertainment PC that is...
Hi!
Your Printer is connected to the (network) router via ethernet cable. Hence, it is a NETWORK PRINTER NOT A WIRELESS DEVICE, no matter your PC is connected to the network wirelessly. So, search for and install the printer as a NETWORK PRINTER. From the printer installation, it should searh and find the printer and susequently install the required drivers.
Moreover, you may checkout the followings link for instructions on how to install/ add a network printer.
LINK-1, LINK-2
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Apr 04, 2011 | Brother HL-2170W Mono Laser Printer
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
Oct 05, 2009 | Compaq Evo N610C Notebook
NEED HELP FROM ANY EXPERT OUT THERE! MAKE MY WELCOME SCREEN WORK!
Hi, you need to right click on your local area connection, then go to properties and uninstall the protocol from there.
May 30, 2009 | Acer Aspire T180-EA350M (AST180EA350M) PC...
How do I connect this to my PC?
Hi there.
You can connect your TV up as an external monitor either through the VGA or HDMI ports if your laptop and TV supports such connections.
If you post back what connections you have on the TV and your laptop i will be able to advice you on what leads you will need to connect to the TV.
Kind regards
May 23, 2009 | Everex StepNote VA4103M Notebook
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Connection to wireless internet
Hi Dire,
Try this link, and see if it helps.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&treeid=C5450E3B88432610E030A68F27286D46&journalid=4327770B4FB1797CE040A68F5A2836D7&Query=d2lyZWxlc3M=&SystemID=INS_PNT_6000&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true
Another idea is to pickup a USB Wireless adapter, Even if you just borrow one from a friend, and try. See if you can connect with it.
You can also go to Start>Control Panel>System>click on the hardware tab, and then on Device Manager.Click on the + sign by Network Adatpers, Find your Wireless network adapter, right click on it, and choose Uninstall. Reboot to have Windows reinstall the wireless.
Hope some of these help.
Good Luck
Jan 09, 2008 | Dell Inspiron 6000 Notebook
Wireless connectivity
hi,
connect to rourter wired
open ur router page
and run the set up
Jan 05, 2008 | NetGear WGR614 Wireless Router
Sony Handycam DCR-HC24E Mini DV Digital Camcorder Logo
163 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
