Bad bios check sum start bios recovery - Computers & Internet
    Sergeant:
    Champion:
  • 210 Answers
Change the cmos battery
Posted on Mar 18, 2011
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
Bios recovery Asus motherboard P4V8X_X
Did you run the utlity to put the firmware onto a floppy disc or cd so that it can boot up on the disc to install it?
The utility is available for download in the same section that you got the firmware update from.
Aug 07, 2008 | Computers & Internet
Boot block compatible version ver 0.16 bad bios check sum.bios recovery floppy not find. cd rom not find. i want a solution for this . iam using asus p5rd1-vm motherbord pls help me frnds
Your bios i corrupt. You will need to download bios for your mother board, burn it on a cd and flash your motherboard bios. Go to your manufacturer site for more information on how to flash your bios using CD.
Nov 27, 2012 | Computers & Internet
Bad bios checksum
The BIOS sum check has detected faulty BIOS information. This can occur when the BIOS battery is nearly flat.
Replace the BIOS battery and then go into the BIOS configuration and set the Date and Time etc.
Mar 12, 2011 | ASUS Eee PC 2G Surf Notebook
When i'm turn on my pc this message would appear ''bios rom chesum error'' what should i'l do?
the ram has some error
better remove the rom blow air to it wipe it wit a clean soft  material
then replace the same
Mar 06, 2009 | Computers & Internet
Bios check sum error
Your bios defaulted. The battery keeps: date, time, and bios settings. You need to get in your bios and change the settings to what they need to be. You can enter the bios by hitting DEL during boot.
Dec 18, 2008 | Computers & Internet
I am getting 1 long beep and then 6 short ones
Hi canturob,
When a system reports a check sum error the bios is telling you the information stored from the last working boot does not match the current settings stored in the bios. Please power down your MSI system, unplug the power cord. Open the case & clear the bios. Location of JBAT1 on page 3 in manual.
Clear CMOS Jumper: JBAT1 page 10 in the manual. Remove the battery/cmos. Check it's voltage with a volt meter. It should test to 3volts DC. Anything less & the battery needs to be replaced.
While in the case re-check all data cables & power cables for good connection.
The MSI board uses the Award bios. Your current beep code of 1 long & six short is not a common beep code for the Award bios. See bios beep codes here: http://www.bioscentral.com/beepcodes/awardbeep.htm
If the battery checks out ok, you may need to update the bios. Go to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=205
To update your MSI bios (Option only if bios clear fails to resolves the check sum issue).
Good luck canturob!
Mike
Dec 03, 2008 | MSI PM8M-V Motherboard
Bootblock
This messages indicates that the BIOS could not be located and loaded up. Normally this happens when the BIOS is corrupted. The corrective action required is to re-flash the BIOS using a DOS bootable diskette in the 1.44 FDD. Aside from the BIOS file, a flashing software is also needed. Pls start here.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 22, 2008 | MSI K9VGM-V Motherboard
Laptop problem
oooh..blue screen too, I'll bet..you may need to boot from install cd, to recover, if you don't have a recovery disk..that is..
Feb 19, 2008 | Toshiba Satellite 1805-S253 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
