Question about HP Compaq nc6000 Notebook
When I press the switch button the power led comes up but nothing shows on the screen, the cpu fan rolls for few few seconds and stops
    Sergeant:
    Champion:
  • 210 Answers
Try to do a power drain.... unplug the power chord... then remove the battery.... while the battery is out... press and hold the power button for 30 seconds.... then put the battery back in and then the power chord.... then try booting it up.... if it works well and good.... if it does not and u see all the lights but not anything on the screen, try with an external monitor just to check if its an issue with the lcd screen.... if its working on a different monitor, u know what to do... take it to a service center....
again if nothing works... dont wait.. take it to a service center
Posted on Mar 18, 2011
Hp P6000 fans stop after 15 seconds. Hard drive light stays on. nothing on monitor
dead PC, DESKTOP PC ,as old as 2009.
the fans tells you the PSU shut off, for cause.
fans, so you saw all fans turn off or just 1. or 2 of 3.
my pc has 4 fans many have 3;
CPU fan stops ,cpu overheats , PC goes slow or dead. clean the lint off it.
GPU fan , video goes dead. if it overheats.
PSU fan is inside the PSU if it goes bad, PSU is bad.
no monitor stated, is it CRT or LCD is it 15 years old.
if the monitor is 2002 or newer the OSD screen works
even with PC turned off, press the select button see that OSD screen ? telling you the monitor is not dead in 1second flat;
i caN NOT understand why the HDD lamp glows,
if the PSU shuts off , most LEDs go dead, on my PC
the standby LED on the MOBO glows, unless you pull the PSU power cord.
your HP PC came with 9 different mobo, during its production run.
at least. so answers come harder from that reason.
here are some simple tests.
test 1
power on, hear fans run
does the DVD drive (or cd) button eject work,.?
do all fans not just 1 or 2 worK? look for all fans clean the lent out
or things will overheat,
PSU can be bench tested or in the PC case.
using a jumper wire, even the HP service manual covers that.
power on the PC (after keeping monitor on for 5 full minutes)
test 2
the Screen must say, "hit ESC key to enter HP setup" BIOS.
press the ESC key on the monitor
if no text shows up that is a dead PC< "text above missing{"
if the PC told you to hit another key do so.
The ESC key , activates the BIOS brain. this cause
all those pages to work as seen in your service manual;.
if BIOS is dead that is a bad PSU (monitor ok)
or CPU is overheated.
bad ram, take all sticks out and test 1 by 1, ask how. !
The PSU will shut down on up to 12 or more faults
but never shuts down the standby power bus. unless AC line pulled.
IF the PSU has fan as most do this is the first place I look.
try this guide
https://support.hp.com/us-en/document/bph06788
Jul 08, 2017 | HP Computers & Internet
Why is my Sony VAIO VPCEB33FM green power light flashing?
It won't be the cpu. If it was, nothing would happen. I would look for a GPU issue, possible over heat.
Jan 01, 2015 | Sony Vaio Vpceb33fm
Toshiba Satellite L655 Not Switching on
You mentioned that it won't turn on with the charger (without the battery). Does this mean that it turns on if the battery is in?
If it turns on with the battery, then you need to replace your AC adapter.
Feb 13, 2013 | Computers & Internet
Pressing power button results in power light and hard disk light coming on for a couple of seconds cpu fan spins for same length of time then fan stops lights go off few seconds later lights come back fan...
it seems that you have damage memory card replacing may fix a problem but its better for it that you bring it to a technician in order to check much better because the motehrboard may possible be the problem.
Jun 30, 2011 | Acer Aspire 4315 Notebook
Hi, I have bought this dell vostro 1015 laptop one and half year ago. Day before yesterday my windows XP hanged and I was unable to shut down. So I pressed power on button for few seconds to switch off...
It sounds like your hard drive has gone bad. As this is a laptop you can try to reseat the hard drive, if that does not help then it might be a case of hard drive crash.
Oct 29, 2010 | Dell Vostro 1510 Laptop
Power On, Fans start but stop in few seconds and that's all
May be there is a problem in the windows, but suppose it is not booting at all.
First Check once more your boot options from bios menu
Second If it still the same thing, extract your battery out of your laptop for 12 min, then try to power up your laptop pluging in your power cable(don't use your battery)
Third If it still not working, there must be a problem in your cooling fan, so check it, also check your motherboard & your graphics card (Most of this problems happens due to a problem in the computer cooling system in motherboard & graphics card)
Hope it works for you Christos
Jan 30, 2010 | Toshiba Satellite P200-0TD00Y Notebook
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
Acer travelmate 292elcI problem starting
Hi, sorry to hear you are having problems. When this happens it usually suggests that the CPU/system board has failed. If the laptop is still under warranty I would suggest taking it back because this is something that will be covered and they should be able to fix it or replace the laptop itself. If not you may have to pay to have the system board/CPU replaced. Good luck and hope this helps. Si :)
Sep 26, 2007 | Acer TravelMate 292ELMI Notebook
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Power LED on but no boot up
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
HP Compaq nc6000 Notebook Logo
113 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
