Question about LG Washing Machines
How can I fix my LG Intellwasher? I think I need to change the bearing on the drum as they sound very dry and loud, I think the water seal in the drum must have worn. David Moule
  • 770 Answers
What is your model number
Posted on Aug 02, 2008
Whirlpool cabrio started making a loud noise when spinning. I've replaced the suspension springs before. Is that all I need to order? It's been a while.
Sounds like the bearings are toast. These machines have a poor seal in the tub which allows water to penetrate the bearings, drying/rusting them out. Go on "youtube" and search your problem. I use a 2"X4" and a jack on the center shaft to lift the drum out. Bearing tool and shaft/bearing, seal kit is approx. $150. Should take you approx. 4 hrs. if you're handy.
Nov 28, 2016 | Whirlpool Washing Machines
Loud noises during spin cycle. Drum is eating up. All springs and shocks appear to be ok
The water seal has worn out and water has gotten into the bearings. You need to call a service tech to have it repaired. It is not a cheap repair. Whirlpool has a repair that replaces the back half of outer tub and a new inner tub or basket one in the same. Another salution is replace the seal and bearings, still a lot of labor. go to utube and a guy does to an LG, but the the repair is about the same for a Duet
Aug 08, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Loud dryer noise when drying
sounds like bearing take off back and see if and black markes around the bearings only other thing it could be is the felt ring around the drum
Apr 05, 2014 | LG DLE5977 Electric Dryer
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
How to Replace Bearing Ball on a LG Front Load Washer??? The bearing ball is leaking water and makes loud noise. need to fix problem please help.
The rear half of the outer wash drum (which contains the rear bearing and tub shaft seal) needs to be replaced. On a 1 - 10 scale, this rates a difficulty rating of about an 8. An experienced appliance tech can do it in about 2 hours, and hit you up for about $500. I do not suggest this as a do it yourself repair. Did you know that the new LG machines use a balance ring to make them much smoother running? (Hint: It may be wiser to replace the machine.)
Jul 04, 2010 | LG WM-0532HW Front Load Washer
How do you change drum bearing on lg wm-1290fhb washing machine
It is a difficult job in terms of handling! You require spanners and bearing puller. You require one extra assistance to hold the drum and pull from the front.
You have to change the full set of Bearings with same type and design. Check the bearing housing and the shaft before fixing new ones! Replace the water seals if any
Apr 05, 2010 | LG WM-1290FHB Front Load Washer
Hi, My LG dryer is making a sqeeking noise when turned on. Pretty loud at first and then sound reduces further in the drying cycle. Any suggestions?
If you can open one of the smalle panels to see inside around the drum- check to see if the belt is rubbing and there is black rubber dust or strings around that area. It is probably one of the bearings or felt gaskets or seals that the drum rides on.
Nov 16, 2009 | LG DLG5932W Gas Dryer
VERY LOUD GRINDING NOISE LG WM-2277HW Front Load Washer
Get a new washer. Perhaps another brand.
The fix for me was to get a new washer. Had same issue with loud spin cycle. Tried researching while wife was continuing use of washer. Then the LE message appeared.
Took back apart and found that water had leaked and caused a boat load of damage. Bearings shot, seal leaks, drum leaks, Stator damaged. Same issue as 'jammy64' stated.
Cost to repair wasn't worth it. Going to get an
Electrolux model.
May 19, 2008 | LG WM-2277HW Front Load Washer
LG/ westinghouse lifestyle font loader
what you will need to do is wright down the model number and go to ebay and put in bearings for a lg then put your model number in and it will come up with very cheap bearings thats where i get all my stock from. good luck £4.50p very cheap
Jan 06, 2008 | LG WM2077CW Laundry XL Front Load...
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
