Question about Samsung Televison & Video
I am having a "Check fan #2" warning on my Samsung
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Samsung Expert
  • 177 Answers
Check fan is DMD fan defect.
I am having a
Clean fan or replace it with the new one.
Posted on Mar 18, 2011
Testimonial: "Thank you very much, I will let you know how it turns out."
  • 1 more comment
  • reynoldshsd Jun 09, 2011
    I had same warning, check fan 2, then TV cut off 5 mins later. Won't saty on more then 10 seconds. Thanks for the picture, helped me fine fan 2. Cleaned and blew out all dust. Turned on TV, fan works fine, lamp comes, but TV still shuts off in 10 seconds, anymore things I should try--thanks
  • Basuki Jrobenk
    Basuki Jrobenk Jun 09, 2011
    hello,
    have you see the Led lamp indicator from front of TV ?
    you should read my tips here :http://www.fixya.com/support/r8801056-er...
    I hope thats will help you.
  • reynoldshsd Jun 24, 2011
    this is fan 1 on my Samsung, fan 2 was on the right side of the lamp, and it was bad, had to get a repairman to fix as it was hard to get right side module out, cost $165
Need help fixing the picture on an older Samsung dlp tv
You need to replace your color wheel. Part# BP96-00674A. This has been a common problem with the samsung dlp's. I hope this helps.
Apr 23, 2016 | Samsung HLR4667W 46" DLP- DIGITAL LIGHT...
Samsung tv series sq01 has check fan 2 on screen then will shut off where is fan 2 located and what does this mean
you will need the complete model/serial number for proper part#. To locate which fan is problem try watching to see which one is not coming on at start-up.
Dec 09, 2014 | Samsung Televison & Video
Where is "fan #2" in Samsung dlp hl-r5656w?
I don't know which is fan #2 but if you take the back off, you will see one fan right in front of you. The other is harder to get to. It's the black box inside the silver covering with the holes (in left lower part).
My TV was acting up by having only one color showing until I let it cool down then it would work fine. I cut a hole in the plastic back cover and mounted a bigger computer fan. Just spliced it in the wires of the little fan. Fixed the problem
Jan 26, 2013 | Samsung HL-R5656W 56" DLP HDTV
Is there any solution for "check fan 1" Samsung LN40A650A LCD TV
Just fixed my Samsung LN40 check fan #1.Unplug, Take the back off (like 20 screws were hard to find them all) fan is exposed in the middle. Unscrew fan, used q-tips and nozzle tool on vacuum cleaner to remove built up dust gunk. Blew in center of fan to dislodge dust. Screwed fan back on, plugged in to see if fan was spinning to cool TV. It was and the check fan message disappeared. Put the back on. Feeling Lucky no big repair.
Nov 26, 2011 | Samsung LN40A650A LCD TV
Will not turn on and says "check 2nd fan"
Thats indicating that the number 2 fan needs replacment. You can get the fan for your model from www.tvrepairworld.com under the Samsung cooling fan category.
Aug 20, 2011 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
I just put a new lamp in my tv (42" samsung tantus) and the temp light is coming on.
Samsung Tantus used TV says Check Fan # 2 ? and will Not respond to any commands Nor show anything but Blue back ground and Flashing FAN warning ?
Jan 09, 2011 | Samsung Televison & Video
Samsung DLP tv wont turn on just says standby temp
I Have a samsung hlr4667w and it started doing exactly the same thing on the same day. look in the back...is the bulb on? Mine is, but there is no image and the controls are not responsive. Wonder if there is a software glitch? anyone else seen this?
Oct 21, 2009 | Samsung Televison & Video
Televison & Video Logo
632 people viewed this question
Henry  Thomas
Henry Thomas
