Question about Cell Phones
How do I connect the Nokia Bluetooth Wireless Headset 0889 CE C7 Nokia phone.
SOURCE: Bluetooth headset
Put your phone in "Discovery Mode" Most phones can get there by going to Menu/Settings/Tools/Bluetooth. If you don't have Bluetooth option here, your phone probably doesn't have bluetooth capability. Then, on your bluetooth hold down the big button until the blue light stays. If you have a bluetooth that you flip, make sure it is closed first, press down the button until the light appears and then flip the bluetooth open. that should leave the light on. as the light stays on and your phone on discovery mode they should be able to locate each other.
Posted on Dec 29, 2006
TampaNative
  • 778 Answers
SOURCE: Nokia 6085 - unable to clear headset icon on display
Take it into an AT&T corporate store and have a technician check it out. They will probably re flash your phones firmware, and that should take care of your issue.
I hope this helps, and Good luck.
Posted on Mar 21, 2008
SOURCE: no connection withe nokia HS-36W bluetooth headset
go into the bluetooth menu, with phone bluetooth on.
next, select paired devices, select new.
now the headset hold the volume + and - at the same time to re-set the headset, NOT the phone + and - / the headset only
this will re-set the headset and paired it to the new phone.
Posted on May 19, 2008
trillian_tx
  • 4 Answers
SOURCE: bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Posted on Apr 14, 2009
humanmanual
  • 45 Answers
SOURCE: My LG cookie is not able to detect the Nokia Bluetooth headset
Sorry if you have done this but let's see if we can get you connected!
On your Nokia headset press and hold the multi-function key for roughly 8 seconds. Your green light will begin to flash quickly. Your Bluetooth headset is now in pairing mode.
Now using your LG Cookie, press Menu > Settings > Bluetooth > Search
Once found, you will need to type the pass code which is normally set as four zeros (0000).
You should now be connected.
We hope this helps!
Posted on Jul 11, 2009
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
I av bluetooth model no ce0889 but it is not conecting with my nokia e5 nokia mobile phone please tell me solution ,thanks
try to insert it in another nokia mobile phone same to your phone, If not functioning you may go to the any nokia mobile phone store & ask them to find you the right nokia wireless bluetooth headset. You may also return it where you buy it, bring your receipt to change what fit to your mobile phone, or consult mobile technician.
May 26, 2011 | Nokia Wireless Bluetooth Headset Headset
I can't connect my bluetooth headset on my nokia c7
Try to set the connection settings to automatic so that it can detect your bluetooth device.
Hope this helps! -jayps
Mar 15, 2011 | Cell Phones
Bluetooth connection
on and the headset is switched off.
2. Press and hold the power key until
the green indicator light starts to
flash quickly.
the phone, and set the phone to
Feb 09, 2010 | Nokia BH-208 Wireless Headset
I get the bluetooth symbol on the Nokia E63 handset but unable to receive calls.
are you using a bluetooth headset? if yes then check whether u have switched on your bluetooth headset & also your phone & bluetooth headset must be reachable, that is, both should be within range as mentioned in your bluetooth headset manual.
Oct 28, 2009 | Nokia E63 Cell Phone
Is my phone compatible w/ the jabra bt150??
bluetooth headsets are compatible with any phone that has bluetooth to connect just while its off, holding down the power button untill a constant red light comes on. then searching for the headset
Mar 18, 2009 | Jabra BT150 Wireless Headset
How do I connect my h350 motorola bluetooth with my nokia 6275cel
Try video instructions on connecting Bluetooth headset to Nokia phones on www.HandBookLive.com under Electronics category (Motorola H710 headset). It should be pretty much the same for all headsets. Watch chapter on Pairing phone to headset (Nokia example) It shows you the steps and what the phone screen will look like on your phone as you go through the steps (activating Bluetooth option on the phone, then searching for devices (headset) and finally pairing the headset with your phone.
Dec 17, 2008 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Nokia 6102i will not detect my BH-600
Hey I found the solution :
1. When the headset is off, press and hold the multifunction key until the indicator light is continuously displayed.
2. Switch on your compatible phone.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
found devices.
In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the indicator light starts to flash slowly, and the headset appears in the phone menu where you can view the currently paired Bluetooth devices.
The headset is now ready for use.
Enjoy..
Pavan
Jan 27, 2008 | Nokia BH-600 Wireless Headset
No response
find a nokia 6300 manual, i currently have this phone and it is quite easy to use, otherwise try referring to the manual for your headset. if you could also post the part about connecting your headset via bluetooth it would be helpful because i dont know how to pair the headset you are reffering to. (the problem for me the headset not the phone).
Oct 15, 2007 | Logitech Mobile Freedom Wireless Headset
Bluetooth wont connect
I cannot pair my bluetooth6133 coz I forgot the pascode
Sep 10, 2007 | GE Bluetooth In-ear Headset Wireless...
Cell Phones Logo
67 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
