Question about Crystal Decisions CRYSTAL REPORTS 9 Professional (prevc90) for PC
While generating report it displays invalid index, when i am using parameter in report, without parameter it displays.
  • 197 Answers
See if you can reset the parameter in the format tab on your menu bar
Posted on Mar 22, 2011
Every time I fax out, there's a confirm report print out. How di I turn this off?
To disable a confirmation report each time you fax, you need to make a change in the Parameter Settings. To do this, perform the following:
  • Press User Tools
  • Using the up and down arrows, select Fax Features
  • Press OK
  • The "switch" you need to modify is switch #3.
  • After hitting OK, use the arrows to scroll down to switch 03.
  • Once there, press 00
  • Press User Tools
Your machine is now set up to fax without printing a confirmation report. The transaction will still be stored and can be made part of a more general report.
Mar 08, 2011 | Ricoh Aficio MP 2000 Black and White...
How do I get a confirmation when a fax is sent
Press FUNCTION and DATA REGISTRATION.
Use the search buttons(^,v) to display 3. REPORT SETTINGS.
Press SET, then use the search buttons to display "TX REPORT"
Press SET, then use the search buttons to select "OUTPUT YES"
Press SET.
now exit from menu and whenever you send a fax a trasmission report will be generate automatically
Jan 06, 2011 | Canon CFX-L4000 Plain Paper Laser Fax
I do not want a Communication Result Report after each fax is sent. How do I turn this report function off?
This is a somewhat complicated change. You must change the user parameter "switch" to turn the automatic printing of the transmission result report off. If you have your Facsimile Reference Manual "Advanced Features" then just go to the user parameters section and go thru the steps. If you do not have your manual you can download for free here.
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
Be sure to get the advanced features facsimile manual.
Sorry for the referral to a manual but you will see what I mean, it is just too much stuff to type here and the manual has pictures of the display as you go.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Ricoh Aficio 1515 Black and White Copier
Verifone 3750 download needed invalid go parameter
Description
This error message means there is a parameter keyed incorrectly and the programming has been lost.
Steps
1. Recall each parameter in the correct download group.
2. If each parameter is correct then make sure the parameters are not keyed more then once in the group.
3. Restart the download.
Apr 08, 2010 | VeriFone Omni 3700
What button do I press to generate a Fax report - this is not always generated automatically.
Sounds like your Fax Options are set to print on error only. If you want to have both confirmations and error pages do the following:
1 Press Menu until “Fax Setup” appears on the top line of the display. Press Enter.
2 Use the scroll button to find MSG Confirm. Press enter.
3 It may be selected to On-Err. Use the scroll arrow buttons to get to On. Press Enter.
4 To return to Standby mode, press Stop/Clear.
This should make your fax print out a confirmation on a successful or failure transmit of your fax.
If you want to print out the last few sent or receive faxes:
Printing a Report
1 Press Menu until “Reports” appears on the top line of the display.
2 Press the scroll arrow buttons to display the report or list you want to print on the bottom line.
•Phone Book: Phonebook list •Sent Report: Sent fax report •RCV Report: Received fax report •System Data: System data list •Scheduled Jobs: Scheduled job information •MSG Confirm: Message confirmation •Junk Fax List: Junk fax number list
3 Press Enter. The selected information prints out.
You can find your manual in English by clicking here.
------------------------------------------------------ Please rate this post if it helps you! :)
Dec 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Disabling Auto-Print of Communication Result Report
It's in the "user parameters" in the "fax features" menu. No disrespect, but it's a needlessly complicated setting (all of the parameter settings are if you aren't familiar with Ricoh).
You can download the manual here if you don't have one (It's in the Printer /Scanner reference). Look in the index under "Communication result report".......good luck:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp16/mp16en.htm
Mar 11, 2009 | Ricoh Aficio MP1600SPF Copier
Primavera financial reporting
Have you considered creating a regular export from P6 and using Access or some other reporting tool to generate your reports? I could set you something if I new the specifics of what you are trying to get.
Feb 10, 2009 | Primavera Contractor 6.1 Full Version for...
Datamax WS6308 print error in .net
El controlador de Seagull es muy bueno y con muchos parametros, intenta modificar los parametros del spooler. Seagull driver is very good and with many parameters, try to modify the parameters of the spooler. buscar
Nov 24, 2008 | Epson Printer
Printing confirmation page after completed fax
If you have the operators manual (it may be in the back compartment of the machine), look in the index for "fax parameters", then "fax reports".
Nov 30, 2007 | Minolta DI-2010F Copier
Computers & Internet Logo
104 people viewed this question
Top Crystal Decisions Computers & Internet Experts
David Payne
David Payne
Are you a Crystal Decisions Computer and Internet Expert? Answer questions, earn points and help others
