Question about Husqvarna Garden
I own a husqvarna l120 ride on lawn mower but cant get it to start, i have changed the battery, checked the seat switch and all the obvious things like its in neutral and the cutter is in the up position, there is no hint of a noise when i turn the key?
  • 784 Answers
Check starter relay.
Posted on Mar 18, 2011
Blades will not engae on a husqvarna 42 inch riding lawn mower
It sounds like you could have a bad seat switch or maybe a loose wire at the pto switch or loose connection at the two wires going to the clutch. To check to see if you have current to the clutch, first check to see if your battery has at least 12 volts. pull the two wires apart going to the electric, then start the tractor then with a vom meter check for from 9 to 12 volts at these two wires anything less the clutch won't kick in. If you have voltage then you have a bad clutch or it needs adjusted. If you don't have voltage then you could have a bad pto switch. Also check your seat switch to be sure it is good. Good luck, hope this helps..
Jun 25, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I cant start the mower. I have charged up battery, checked gas and cant start the thing. What else can I do? It is a 22 HP Airens.
make sure parking brake is set, you are in the seat, the mower engaging lever is in the down position and the the gear box is in Neutral
Sep 25, 2013 | Ariens Lawn Tractor 46"" Riding Lawn Mower...
Husqvarna Riding Lawn Mower 46 Cut model #454140010G MOWER will not ingadge
I can not say this enough, check the safety switches. There should be one on the seat, the clutch /brake pedal and /or the equipment pto switch. Also, check the wires running to these switches. They tend to move and vibrate as you mow and a worn spot in the wires can cause a short, resulting in the mower not starting.
Good Luck!!!
Jul 17, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I don't kown anything about charging batteries! How do I carge a battery in a 2008 Husqvarna riding lawn more?
mille get yourself a cooler and put 8 cold beers in it. Put that cooler into the gap between the seat and the "dash" of the mower. Make sure your gas and oil are good. Have someone jump start your mower from a car and then you mow and drink and mow and drink until the beer is all gone. If the mower does not start from the battery the next day go out and buy yourself a new battery. If the battery and charging system are good then you do not have to charge it if it is being used regularly.
Apr 20, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
May 26, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Every time I lift off the seat of my John Deere engine Dies....
The seat switch is doing it's job,you can;t get off the seat unless the pta is off and the tractor has the park brake engaged.Replacing the switch won't change anything.
May 16, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna gth 2448t 48'' 24 hp riding mower 2007
YA IT SOUNDS LIKE YOUR SEAT SWICH IS BAD THATS THE MOST COMON THING I SEE A LOT OF LET ME KNOW IF THIS HELPS YOU
Oct 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
93 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
