Hi, My son has pulled an emergency emptying hose on aeg 16830. It became very loose. Is there any way of fixing it? Thanks, Nat
    New Friend:
Hi there
Just saw your reply above. What happens if you've torn the emergency emptying hose off? Water is now leaking. I take it I need to get a new one. I can't see where it fits in the inside? Thanks jon
Posted on Aug 30, 2016
    Brigadier General:
  • 6,277 Answers
As long as the hose still has its 'bung' in the end and it's not ripped or torn so that water does not come out, I cannot see the fact that it is 'very loose' affecting anything. You would have to pull it to gain access to the bung in an 'emergency and drain whatever water was left in it anyway ;-0)
Clever lad. Put him on FixYa to give advice on 'emergency emptying' !
Cheers, John C
Posted on Mar 18, 2011
  • rakushka_77r Mar 18, 2011
    The water came out unfortunatelly when I switched the machine now. So he ripped it off apparently :-(.
    I don't allow him to do it, but our 'clever' nanny did apparently.
    thank you!
Tip
AEG Electrolux Lavamat 50600 is not spinning here are a few work throughs
Download manual
First off that was a link to the online user manual. If this was the first time using the machine did you follow the recommended first time use procedure by following these steps:
Before using your machine for the first time
0 Slightly pull the detergent compartment out of the control panel.
0 Pour about 1 liter of water through the detergent compartment into the washing machine.
When this has been done the ?KO lock can function correctly.
0 Run a wash cycle without laundry (COTTONS 95, with half the amount of washing powder).
This removes any residues from the drum which may have been left during manufacture.
If you have used this prior to the problem occurring try this:
The issues for not spinning are numerous as to what may cause this and it appears to be a lot but most of it is rather simple :
If there is water in the drum you need to follow the pump out procedure and remove water in the drum. Then there may be a "Bend" in the inlet hose. If there is water reaching the drum this is the possible causes and simple to check:
Water is leaking out from under the washing machine.
Fabric softener is not added, compartment for fabric softener is filled with water.
Appliance does not spin, water in the drum.
Washing has not been spun sufficiently, there is water left in the drum.
Door cannot be opened.
The rinse water is cloudy.Possible cause
The inlet hose connection is not tight.
The inlet hose has a leak.
The drain pump cover is not tight.
Washing is caught in the door.
Suction cap in the fabric softener compartment is not correctly fitted or is blocked.
RINSE HOLD selected.
SOAKING program is terminated.
There is a "Bend" in the outlet hose.
Maximum pumping height (drain height 1 m from the position of the machine) is exceeded.
Drain pump is blocked.
The water drainage system is blocked.
The door is locked due to safety reasons
Probably caused by a washing powder with a high silicate content.
Troubleshooting these are the remedies:
Tighten the inlet hose connection.
Check the inlet hose and if necessary replace it.
Tighten cover by turning clockwise.
Abort the program, remove the washing caught in the door, start a new program.
Clean the detergent compartment, fit the suction cap on firmly.
Deselect RINSE HOLD.
Pump out water and set the main wash cycle as desired.
Eliminate the Bend ( it would not allow me to use the proper word here see manual.)
Please contact AEG Service Force Centre, it has a retro- kit available for pump heights above 1 m.
I would definitely try this as it appears to the reset procedure for this machine:
Switch off the machine and pull the plug out of the socket
I would say no less than 20 minutes
but do this while waiting further:
clean the drain pump.
Clean the blockage
Carrying out an emergency emptying
1 Warning! Isolate the washing machine from the main supply before the emergency emptying!
If the washing machine no longer pumps out the water an emergency emptying must be carried out.
Warning! The water, which flows out of the emergency emptying hose can be hot.
First allow the water to cool down before emergency emptying!
0 Put down a flat container to catch the water draining out.
0 Pull down the flap in the left corner of the base strip and remove it.
0 Release the emergency emptying hose from its holder.
0 Pull the emergency emptying hose out a little.
0 Place a container underneath to catch the water.
0 Release the plug of the emergency emptying hose by turning it anti-clockwise and pull it out.
The water will drain out. Depending on the amount of water, it may be necessary to empty the container catching the water several times.
To do this, temporarily close the emergency emptying hose again with the plug. When the water has drained out completely:
0 Push and twist the plug firmly back into the emergency emptying hose.
0 Push the emergency emptying hose back in a little and let it catch onto the holder.
0 Replace the flap in the base plate and close it. When the washing machine is completely empty, the ?KO lock can no longer function correctly. Therefore before the next wash pour in approx 1 liter of water (pour it in through the washing powder compartment)
steps to Clean the drain pump
1 Warning! Switch off the washing machine and pull the plug out of the socket before cleaning the drain pump!
0 First carry out an emergency emptying (see section "Carrying out an emergency emptying").
0 Place a towel on the floor in front of the cover of the drain pump. Surplus water may flow out. 0 Unscrew the cover of the drain pump by twisting it anti-clockwise and pull it out.
0 Remove any foreign bodies which maybe in the pump housing.
0 Check whether the impeller of the pump can be turned. (It is normal forthe pump to turn in steps.) If the impeller cannot be turned at all please contact your local AEG Service Force Center.
0 Replace the cover (insert the ridges on the cover into the guiding slots)and screw on tightly in a clockwise direction.
0 Close the emergency emptying hose, push it in and twist.
0 Close the flap. I sure hope this helps a few people especially the one who I posted this for initially. GOOD Luck! If none of these suggestions work then best to call AEG for servicing, I strongly believe that the Bend in the inlet hose or the drain pump most likely the culprit and or any one of the other issues may well resolve the spin malfunction as well as possibly the main computer may have been goofed due to a slight power surge which unplugging from electric and turning off water for 30 minutes is the basic reset procedure for most electronics ( not all ;but most) while working through these steps should not hurt a thing.
on Dec 26, 2014 | Washing Machines
Aeg lavamat turbo 16830
start at the beginning,, check your fuse
Jul 16, 2013 | Washing Machines
I have an AEG Electrolux 16830 - I get an error code E10 - pressing the start switch recommences the program and it completes as normal. How do I reset the machine so this does not happen. An engineer...
E10 indicates that the water inlet hose is squashed or kinked.
First check the filter for coins or other junks.
Make sure the drain hose isn't blocked, restricted or kinked.
Hope this helps.. Good luck! ;)
Thanks for using
FixYa - a 4-thumbs up rating is greatly appreciated for answering your free question
Jun 06, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
The door handle of my AEG Lavamat turbo 16830 is broken, I ordered a new one but would like advice regarding installation please. Thanks
Hi there, we too have a similar problem. Our new door handle part has arrived but we are having huge problems fitting it as we cant prise the grey outer trim off the door and thus can't get in to put the new door handle in.
Please help! How can we get the trim off without resorting to serious damage with a screwdriver!!!?
Dec 19, 2010 | AEG Lavamat W1450 Front Load Washer
How do I reconnect hose?
1. Bend or put on back side the appliance and remove the three screws which secure the plinth to the lower part.
2. Remove the filter door
3. Remove two screws
4. Release the plinth
5. Turn it
6. Remove the plinth
6259706-vsmw15pk1kyieti0geqgsykn-3-0.png Dado
Oct 03, 2010 | AEG L76800 Front Load Washer
AEG Lavamat 16830 washer dryer
can anyone tell me how to remove the rear panel of a AEG lavamat dryer. regards Roy
Jul 20, 2008 | Washing Machines
AEG Washer dryer will not complete cycle
I ended up trying the machine on a few different cycles all of which failed to complete. Finally tried a 'Drying' only cycle and it emptied out quite alot of water which was odd. It now seems fine. guessing it was a blockage and a certain amount of water was backed up in the machine??? any clarity welcome.
Mar 24, 2008 | AEG Washing Machines
Washing Machines Logo
191 people viewed this question
Top Washing Machines Experts
