Question about HP Photosmart C3180 All-In-One InkJet Printer
I have a c3180 with originals ink cartridges.Suddenly it wouldn`t print black.I tried cleaning, i tried exchanging the cartridges. The software can see the cartridges and ink level as ok.
  • birgers Mar 18, 2011
    I solved it by cleaning the contacts i the printercradle. I dont know why, but now I can print black again. Ps. i have had the printercartridges in and out a lot of times, so it was dirt on the cradle and not a faulty placement of cartridges.
    Problem Solver:
  • 6 Answers
Check the toner blde(give for service)
Posted on Mar 18, 2011
I just put in a new black ink cartridge and it will not print black ink. The color ink prints, but the black will not.
Hello nicfurtaw, there are dried ink on the ink carousel, or cradle, you may need to soften the ink. Use cotton buds, dip into warm water and gently wipe the ink hole where the ink pass through, until the carousel is clean.
  1. remove the black ink cartridge
  2. find the spot where the ink pass through
  3. see dried ink on it.
  4. use cotton buds dipped in warm water to soften the ink.
  5. do this several times
  6. clean enough, test to see if the black ink will pass through
  7. replace the black ink cartridge
  8. test the printer.
Feb 10, 2011 | HP Photosmart C3180 All-In-One InkJet...
HP C3180 prints only black and white. The black and color cartridges have ink.
do one thing...take out the cartridge then clean the coper contacts..and then reinstall them then try to print it will work
Jan 18, 2010 | HP Photosmart C3180 All-In-One InkJet...
HP 3180 BLACK IS PRINTING LIGHT
Call HP.
There is an un-acknowledged issue with these printers having problems like that ....
They end up replacing some big parts inside it.
Jun 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Print Cartridge(s) Problem The following print cartridge has a problem: Black
1.Try printing a page of black text, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck, it worked for me.
May 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
Will not print black
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 23, 2009 | HP Photosmart C3180 All-In-One InkJet...
Ink cartridge
Black HP 92
Color HP 93
Photo HP 99
Jan 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
Black print is faded when i print
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 10, 2009 | HP Photosmart C3180 All-In-One InkJet...
Hp c3180 photo printing
Use original inks. Try reinstalling the drivers. Should all that fail, you may need to get it serviced or replaced if under warranty.
May 11, 2008 | HP Photosmart C3180 All-In-One InkJet...
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
113 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
