Question about Xerox Phaser 3100MFP/S Laser Printer
Printer has show a display printer error & Fuser Temp. so plz give me solution for this problem
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Mar 18, 2011
We are getting a 50.7 fuser error on our HP CM6040mfp printer and we replaced with new one but still it showing the fuser error. Do we need to reset the printer or any other issues .kindly help
Pressure release mechanism error in fuser, you already replaced the fuser.. then check below connectors.. Remove rear door...>Check connectors:J1720,J1965,J1964 &dc controller PCA connector J105 & J121..shown in fig>check fuser driving gear,>Fuser driving motor as shown in fig>Fuser sensor flag & pressure release sensor> perform sensor test... administration..scroll to trouble shoot..sensor test..perform all sensors as shown in display.. check sensot test passed or not...
Jan 31, 2012 | HP Office Equipment & Supplies
502 fuser error. replaced fuser with same message.
Hello Dear ,
Open the door & pull out the fuser then you will see the 2 no of sencors situated left upper side below the front covel ,clean them with clean cotton your problem will be resolved .
Altough problem persists then if u r technical then open the fuser unit & remove the teflon u will find temp sencor it become dirty by which it also shows the said error clean them you problem will be resolved 100%..
Regards
jm
Aug 23, 2011 | HP LaserJet 4700 Printer
Sharp Am - 410 Copier & Printer " Fuser Temp" error message
My Sharp printer AM 410 is showing in the header fuser temp error what show I do
Jul 07, 2011 | Office Equipment & Supplies
I have canon ir400 machine... it displayed error codes e002.. what i do? plz help me....
If the fuser assy has been repaired and you keep experiancing an E002 the problem is most likely a faulty DC Controller (main board) The DC Controller handles the voltage applied to the fuser assy and gives the error code E002 or E003. Have your tech clean & reseat connectors on the DC Controller before just replacing it. I have found cleaning the connectors & reseating them solves the problem 75% of the time.
Jan 12, 2011 | Canon imageRUNNER 400S Copier
Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Mar 12, 2010 | Xerox Phaser 3100MFP/S Laser Printer
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
Sep 14, 2009 | Xerox Phaser 6120/YN Laser Printer
Printer error, fuser temp
It is giving me an error message of "printer error,fuser temp"
Jun 24, 2009 | Gestetner DSm415f All-In-One Laser Printer
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
Xerox Phaser 3100MFP/S Laser Printer Logo
35 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
