Question about Samsung S8300 Ultra Touch platinium-red Cell Phone
My Samsung S8300T red cell phone has suddenly lost its sound. When there is an incoming call there is no ring tone (although it still vibrates) and if i set the alarm clock, the alarm will go off, but make no sound and if I answer an incoming call the other party can hear me, but i can't hear them, there is no sound alert for new m essages or when I receive email. Help! (please) This problem only seems to have started in the last few days. I have looked at all my settings, I have switched the phone on and off, I have taken the battery out and replaced it (I am not all that technical!!!)
How do l make my samsung s8300t ring longer?l keep missing calls because it only rings for about 10 seconds.
Posted on Apr 20, 2011
  • 35 Answers
You have to check it in nearest Samsung care or service center
Posted on Mar 18, 2011
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Stopped ringing and now just vibrating on incoming calls no sound on music either
Reset your phone to the default factory settings. If not remove the battery and reset. If this wont solve check the settings on the tones, if there is settings for ringing. If this wont work the ringer can be faulty. Might need to remove to check if this is a loose connection or a failure.
Feb 14, 2011 | Samsung S8300 Ultra Touch platinium-red...
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
On incoming calls all it does is vibrate
social.microsoft.com/.../8306e39b-6e42-4db0-a318-36fd49d59601
Jun 23, 2009 | Motorola Mobility MoroKRZR K1m Cellular...
Hi Does anyone know if you are able to set the ringtone to silent and also the incoming message tone to silent (need it for work) on the Samsung F480 Thanks Elkay
In order to set the ring tone to silent you must turn the volume down to silent or vibrate. Go to phone in menu and check on sounds.
Jan 04, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
No ring on incoming call
i had the same problem and went searching on line till i found the answer, press the # button it takes the mute off or puts it on.
regards patty
Nov 08, 2008 | Samsung SGH-D900 Cellular Phone
Won't Ring
check the settings in your phone book. this happened to my phone and all of the personal ring tones were set to vibrate. I don't know how this happened. I went into each contact and changed the ring tone to none and I am back in business
Sep 15, 2008 | Motorola Mobility W385 Cellular Phone
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
Samsung S8300 Ultra Touch platinium-red Cell Phone Logo
414 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
