Hi, My candy washer dryer (alise gow464) takes a lot of persuading to work. When I set the cycle all the lights on the front light up but then it will not start and the lights go out. If I open the door and rearrange the washing a bit, the correct cycle lights will light up and it works but this can often take a few times. This happens whether there is a full load or just a couple of items. If I switch it off at the plug and wait a few minutes it works first time, but the next time I come to use it I have to go through the same procedure. Also, I have set a wool wash before and the wrong cycle has started. Any help would be gratefully received, many thanks.
  • john_cross Mar 18, 2011
    JUST in case and no promises- which is why I am posting as 'clarification' and not 'solution', and it's worth doing anyway ;-0)
    Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many intermittent 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
    Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
    If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
    REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
    It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
    Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
    At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
    Hope the filter is at least one of the problems and good luck!
    John C
  • lucywarner85 Mar 18, 2011
    Many thanks, I will give that a go!
    Sergeant:
  • 183 Answers
Most of these are a problem with a membrane switch, it's ribbon cable, or the connection it makes at the main circuit board. If you have a rotary switch instead of a membrane switch on your model(you didn't give us the model number) then it can be the switch. but these models have more trouble on the main board, OR the mechanical timer, again depending on your specific model.
Posted on Apr 03, 2017
  • 1294 Answers
SOURCE: candy alise 1000 formula stainless
Click on brand name (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Or click on "washing machines" above to find your brand.
Posted on Jan 01, 2008
Master_Tech
  • 770 Answers
SOURCE: Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Posted on Jan 24, 2008
ginko
  • 19396 Answers
SOURCE: door won't open Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The door sensor/ lock is not working well
Posted on Mar 21, 2008
huuum
  • 750 Answers
SOURCE: Getting HF error, on Whirlpool Front load washer
Dear jodyheidi,
Welcome to fixya.com
I'm Huuum and happy to assist you,
Try this first and if it fails to remedy the problem then call service as you wanted!
Huuum At your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know how you progress!
Bless You, Huuum
Please remember to leave a rating when you are finished!
Thank You
Posted on Sep 23, 2008
SOURCE: I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
Posted on May 28, 2009
Hi, My Candy washer/dryer has stopped working. I get a light on either 1000 or 1400 spin, and a light on 15 minutes and nothing else. There is no water entering the machine.
you may have to take the top off in order to see if the water inlet valve is operating as that's where the water fills from
eric
Dec 29, 2017 | Candy Washing Machines
Candy Alise 1000es
Hello, Here is the location for the manual that you need. Candy Alise 1000 ES User Instructions
Aug 25, 2014 | Washing Machines
Where do I find Candy Alise 1000es Instruction Manual for Washer Dryer
You can find the instructions for your machine on a site called manuals lib (library) there you can download a PDF file for free.
Lost engagement ring in washer dryer
Check the hoses at the base of the water pump.They could stil be there.
Jan 06, 2014 | Candy Washing Machines
My washer/dryer isn't drying clothes
this is all i could find on the internet and that is the manual not sure if its going to be of any help to you but you could go to this link and download the manual and see if it does help you out.
i think its the first one on the page.
candy alise go4w464 washer dryer not drying clothes Google Search
Oct 31, 2017 | Candy Washing Machines
Candy Washer/dryer Stalls
Have you checked the drain hose connection? Make sure the bung is clear in the trap
Aug 07, 2012 | Candy CNW136 Front Load Washer/Dryer
I have the Candy Alise washer-dryer, It is 3 years old. The lock door sensor light is not coming on when the door is shut, the door seems to be shutting properly and making the click noise when it closes....
There is likely to be a problem with the 'door closed' sensor, unfortunately requiring a service engineer's attention I suggest ;-0(
Good luck,
John C
Apr 06, 2011 | Candy Washing Machines
Candy Alise-the stain blaster and 90 degree lights are flashing and it will not function. Please help!
Hi again,
11 flashes decodes as 'faulty dryer module or wiring to it'. Not sure that helps you other than saying that a service call is required, sorry ;-0(
Good luck,
John C
Mar 22, 2011 | Washing Machines
Candy alise 1000 formula stainless
Jan 01, 2008 | Washing Machines
Washing Machines Logo
240 people viewed this question
Top Washing Machines Experts
