Despite cleaning out the drawer, the fabric softner is still there at the end of the wash. Have cleaned the drawer several times, but to no avail. Any suggestions?
    Sergeant:
  • 170 Answers
Remove drawer/ look inside opening of washer ( at the top of opening inside) there is small little holes for the water to come through to fill the fabric softner spot and also bleach spot and detrgent spot. Holes may be pluged use a old tooth bush or some item to clean holes..Hope that helps thanks for voting.
Posted on Mar 18, 2011
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Tip
Fridgidaire Washing Machine Fabric Softner not going into washer
Recently my wife hollered at me to figure out why she could not get the fabric softner to go into her washing machine. By looking a round a bit I figured out what the problem was and am going to pass the solution on with this tip. The solution is very simple and it will only take you a few minutes to clean up things so that they work like new again. Because of the stickiness of the fabric softners this will be something that you will want to do on a regular basis to keep your washer working well.
Pull out the drawer and on the extreme top left of the drawer you will see a plastic tab that holds the drawer from coming all the way out. Push down on the tab and slide the drawer all the way out. You may have to bend down ad look up to see the plastic tab.
You will want to take the drawer to a sink and give it good scrubbing. Wash everything out, take the covers off of the bleach compartment and the fabric softener compartment. Clean out the holes with a toothpick in the tube that the cover sets on. That is were the siphon action takes place that pulls the bleach and fabric softner out of the cup of the drawer.
You also will want to wipe out behind the drawer while you have it apart.
Replace the drawer and you are back in business!!
heatman101
on Aug 19, 2010 | Washing Machines
My washing machine fabric drawer is blocked have cleaned complete drawer but still fabric softner is in the drawer at the end of cycle .
Pull the little 'hat' off it's post in the fabric softener compartment. Clean off any softener residue and return.
Mar 17, 2010 | Hotpoint Washing Machines
Black on door seal and water filling fabric softner section in dr
hotpoint Aquarius
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 20, 2009 | Washing Machines
My front load washer will not empty out the fabric softner. I have taken out the drawer & cleaned it. It will empty out the laundry soap, but not the fabric softner
I have the same problem with mine. I found that some fabric softners worked better than others. I found Downy the worst, when i switched the problem seems to stop once i cleaned out the drawer
Nov 30, 2009 | Frigidaire GLTF2940ES Front Load Washer
Jetstream 1200 wont take away fabric softner
strip and clean out the soap tray then remove the tray and clean the fill water holes above it with a stiff washing up brush.
Mar 16, 2009 | Zanussi ZWF1430W Front Load Washer
Kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
Jan 17, 2009 | Kenmore 44102 Front Load Washer
Washing power drawer, the fabric softner section
Pull the drawer out as far as it will come and then grasping it firmly, give it a good tug towards you, this will free the drawer to enable you to thoroughly clean every piece of it, particularly the conditioner parts of it.
Get a piece of wire with a bend on the end, and poke it in to all the holes in the top of the dispenser compartment, this will clera any blockages there.
Plz rate my solution, and feel free to leave any comment.
Thanks.
Jan 09, 2009 | Indesit W 123 Front Load Washer
Fabric softner dispenser
take the soap dispenser drawer out and clean the drawer and the underneath the drawer, then clean the inside of the machine where the drawer fits into to. It could be caused by a build up of soap.
Oct 30, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
