Question about Whirlpool Washing Machines
Says error 'E 05' drum not filling with water
    Brigadier General:
  • 6,277 Answers
Whirlpool code 'E05' means failure of the NTC (Negative Temperature Co-efficient thermistor- or the bit that measures the water temperature to you and me!) .
I have heard from elsewhere that sometimes pouring 2 or 3 kettles of boiling water into the drum and leaving for 10-15 minutes will 'kick it into life' ; I cannot guarantee that but it is worth a try. If it doesn't work sorry, it is an engineer call ;-0(
Good luck,
John C
Posted on Mar 18, 2011
Where is the water sensor located? Error message IE. Sensor might be faulty.
The water sensor is a pressure switch that sits on top of the drum and monitors the pressure of air in the drum. As water fills the drum, air moves out and this creates a pressure on the switch which works out proportionately how much water has filled the drum.
See video.
Washing Machine pressure switch
Sep 25, 2014 | LG Dishwashers
Water wont pump out code f-05
Clogged drain pump.
Check the drain pump filter. Use a flashligth and you will se if the impeller is stuck on something. If not check the hose from the drum to the drainpump housing. May be clogged.
If not, replace drainpump
Apr 14, 2014 | Hotpoint Washing Machines
Error f0-05 showing during cycle
Error code F05 means water level switch is stuck on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean plastic filter inside hose.
Refit and test.
Mar 31, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Error Code F-05
Error code F05 denotes pressure switch jammed on full.
Remove lower rear cover of washer.
Remove and clean filter inside hose.
Refit back and test.
Please rate my solution.
Thgankyou.
Feb 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint machine has filled with water and won't empty error F-05 FLASHING before that all lights were flashing ??
Error F05 means pressure switch jammed on full.
Fit back and test
Jan 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
Help with correcting fault code f-5
F-05 error means:-- Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
TO RESOLVE THE PROBLEM:--
Check the Water Temperature Sensor, Heating Element and Element Relay globul1a.gif Check connections to the Sensor, Heating Element and Relay
May 07, 2009 | Washing Machines
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Kenmore elite 44832 front load washer troubleshooting F11 c01 c02
Was there ever a post back for this problem? I have the same issue, and I tried replacing the central control board, but it is still giving the F11 error. I follow the troubleshooting guidelines, but it never makes it past C01. I suppose the next logical step is to look at the motor control board and then the motor.
Sep 11, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
349 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
