What is the procedure for scanning. - Office Equipment & Supplies
    Problem Solver:
  • 6 Answers
Insert the page for scanning to scanner,
open soft ware for scaning or open ms word give scan files from scanner or other capturing devices
select area for scaning
in some printers have on appication for scaning like hp scx-1350
Posted on Mar 18, 2011
2005 Chevy Malibu Lt v6 3.5, has anti theftwont go off, after ignition cylinder change
Did you change key also ? does it have transponder chip in the head of the key ? Needs to be programmed . You change what ? Ignition lock cylinder an key ?
Important: When replacing either the vehicle keys, PCM, or TDM and the 10-Minute Relearn Procedure is used, ensure that the appropriate calibration is selected for the replacement component on the calibration selection screen of the service programming system. The appropriate calibrations for specific vehicle theft deterrent (VTD) system components are described below.
• When preparing a TDM for replacement, the Prepare Module For TDM Setup Procedure calibration is required. This allows the retrieval of required information from the TDM prior to its replacement.
• When learning vehicle keys and the 10-Minute Relearn Procedure is used, the Vehicle Theft Deterrent Learn For Learning Replacement Keys calibration is required. This clears all previously learned keys from the TDM and enables the TDM to learn new vehicle keys. For learning additional vehicle keys, refer to Adding Keys .
• When replacing a TDM or ECM and the 10-Minute Relearn Procedure is used, the VTD Learn for Powertrain calibration is required. This clears the previously learned fuel continue password in the ECM and enables the ECM to learn the fuel continue password of the new TDM.
Important: When replacing a TDM with a GM SPO Replacement Part, insure the Setup a New TDM procedure is performed prior to the 10-Minute Relearn Procedure.
Connect a scan tool to the vehicle.
Turn ON the ignition, with the engine OFF.
Ensure that all power consuming devices are turned OFF on the vehicle.
With a scan tool, select Request Info. under Service Programming System and follow the scan tool on-screen instructions.
Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software.
On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions. Ensure the correct programming procedure is selected based on the component being replaced or programmed. See Important above.
Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle.
With a master vehicle key, turn ON the ignition, with the engine OFF.
With a scan tool, select Program ECU under Service Programming System.
At this point the scan tool must remain connected for the duration of the 10-Minute Relearn Procedure.
Jun 13, 2017 | Cars & Trucks
Why won't the car start with the new Crank shaft position sensor installed? 2005 Buick Lacrosse cxl 3.8l engine.
After replacing crank sensor Perform the crankshaft position system variation learn procedure. Refer to Crankshaft Position System Variation Learn !
No you don't need to replace the balancer !
Install a scan tool.
Monitor the powertrain control module (PCM) for DTCs with a scan tool. If other DTCs are set, except DTC P0315, refer to Diagnostic Trouble Code (DTC) List - Vehicle in Vehicle DTC Information for the applicable DTC.
Select the crankshaft position variation learn procedure with a scan tool.
The scan tool instructs you to perform the following:
4.1. Accelerate to wide open throttle (WOT).
4.2. Release the throttle when fuel cut-off occurs.
4.3. Observe the fuel cut-off specifications for the applicable engine.
4.4. The engine should not accelerate beyond the calibrated RPM value.
4.5. Release the throttle immediately if the value is exceeded.
4.6. Block the drive wheels.
4.7. Set the parking brake.
4.8. DO NOT apply the brake pedal.
4.9. Cycle the ignition from OFF to ON.
4.10. Apply and hold the brake pedal.
4.11. Start and idle the engine.
4.12. Turn the A/C OFF.
4.13. The vehicle must remain in Park or Neutral.
4.14. The scan tool monitors certain component signals to determine if all the conditions are met to continue with the procedure. The scan tool only displays the condition that inhibits the procedure. The scan tool monitors the following components:
• Crankshaft position (CKP) sensors activity--If there is a CKP sensor condition, refer to the applicable DTC.
• Camshaft position (CMP) signal activity--If there is a CMP signal condition, refer to the applicable DTC.
• Engine coolant temperature (ECT)--If the engine coolant temperature is not warm enough, idle the engine until the engine coolant temperature reaches the correct temperature.
Enable the crankshaft position system variation learn procedure with the scan tool and perform the following:
Important: While the learn procedure is in progress, release the throttle immediately when the engine starts to decelerate. The engine control is returned to the operator and the engine responds to throttle position after the learn procedure is complete.
5.1. Accelerate to WOT.
5.2. Release when fuel cut-off occurs.
5.3. Test in progress.
The scan tool displays Learn Status: Learned this ignition. If the scan tool indicates that DTC P0315 ran and passed, the CKP variation learn procedure is complete. If the scan tool indicates DTC P0315 failed or did not run, refer to DTC P0315. If any other DTCs set, refer to Diagnostic Trouble Code (DTC) List - Vehicle in Vehicle DTC Information for the applicable DTC.
Turn OFF the ignition for 30 seconds after the learn procedure is completed successfully.
The CKP system variation learn procedure is also required when the following service procedures have been performed, regardless of whether DTC P0315 is set.
• Engine replacement
Feb 07, 2017 | 2005 Buick LaCrosse
How to bleed the brakes on my 2002 Buick rendezvous cxl
If the standard bleeding procedures do not produce an acceptable pedal you will need a scantool that can activate the automated ABS bleed and a pressure bleeding system.
To bleed the brakes use the standard pattern of RR,LR,RF,LF
ABS Automated Bleed Procedure
Caution: Refer to Brake Fluid Irritant Caution in Service Precautions.
Notice: Refer to Brake Fluid Effects on Paint and Electrical Components Notice in Service Precautions.
Important: In most circumstances a base brake bleed is all that is required for most component replacements (such as wheel cylinders, calipers, brake tubes, and master cylinder) except for brake pressure modulator valve (BPMV) replacement.
The following automated ABS bleed procedure is required when one of the following occur:
Manual bleeding at the wheel cylinders does not achieve the desired pedal height or feel.
BPMV replacement
Extreme loss of brake fluid has occurred.
Air ingestion is suspected.
If none of the above conditions apply, use standard bleed procedures.
The auto bleed procedure is used on BOSH 5.3 equipped vehicles. This procedure uses a scan tool to cycle the system solenoid valves and run the pump in order to purge the air from the secondary circuits. These secondary circuits are normally closed off, and are only opened during system initialization at vehicle start up and during ABS operation. The automated bleed procedure opens these secondary circuits and allows any air trapped inside the BPMV to flow out toward the wheel cylinders or calipers where it can be purged out of the system.
Preliminary Inspection
Inspect the battery for full charge, repair the battery and charging system, as necessary.
Connect a scan tool to the data link connector (DLC) and select current and history DTCs. Repair any DTCs prior to performing the ABS bleed procedure.
Inspect for visual damage and leaks and repair, as needed.
Preliminary Setup
Raise and vehicle on a suitable support.
Turn the ignition switch to the OFF position.
Remove all 4 tires, if necessary.
Connect the pressure bleeding tool according to the manufacturer's instructions.
Turn the ignition switch to RUN position, engine off.
Connect a scan tool and establish communications with the ABS system.
Pressurize the bleeding tool to 206 - 241 kPa (30 - 35 psi) .
Performing the Automated Bleed Procedure
Notice: The Auto Bleed Procedure may be terminated at any time during the process by pressing the EXIT button. No further Scan Tool prompts pertaining to the Auto Bleed procedure will be given. After exiting the bleed procedure, relieve bleed pressure and disconnect bleed equipment per manufacturers instructions. Failure to properly relieve pressure may result in spilled brake fluid causing damage to components and painted surfaces.
With the pressure bleeding tool at 206 - 241 kPa (30 - 35 psi) , and all bleeder screws in closed position, select Automated Bleed Procedure on the scan tool and follow the instructions.
The first part of the automated bleed procedure will cycle the pump and front release valves for one minute. After the cycling has stopped the scan tool will enter a cool down mode and display a 3 minute timer. The auto bleed will not continue until this timer expired, and cannot be overridden.
During the next step, the scan tool will request the technician to open one of the bleeder screws. The scan tool will then cycle the respective release valve and pump motor for one minute.
The scan tool will repeat step 3 for the remaining bleeder screws.
With the bleeder tool still attached to the vehicle and maintaining 241 kPa (35 psi) , the scan tool will instruct the technician to independently open each bleeder screw for approximately 20 seconds. This should allow any remaining air to be purged from the brake lines.
When the automated bleed procedure is completed the scan tool will display the appropriate message.
Install all 4 tires, if necessary refer to Tire and Wheel Removal and Installation.
Remove pressure from the pressure bleeding tool and then disconnect the tool from the vehicle.
Depress the brake pedal to gage pedal height and feel. Repeat steps 1-8 until the pedal is acceptable.
Remove the scan tool from the DLC connector.
Install.
Lower the vehicle.
Inspect the brake fluid level in master cylinder.
Road test the vehicle while making sure the brake pedal remains high and firm.
If the vehicle is equipped with a traction control system (TCS), the scan tool will cycle both the ABS and the TCS solenoid valves. This bleed procedure is the same as above.
Sep 15, 2016 | 2002 Buick Rendezvous
Where is the crankshaft position sensor located on a 2008 HHR 2.2 is that ecotec engine
My info says it is located above the starter motor. Info says to remove the starter.
The info also says you have to do a crankshaft variation relearn procedure. I can't help you with that procedure.
Nov 18, 2015 | Cars & Trucks
2005 buick lacrosse crank shaft sensor how to replace
What engine does yours have ? 3.6 or 3.8 L An when finished a
  1. Install a scan tool.
  2. Monitor the powertrain control module (PCM) for DTCs with a scan tool. If other DTCs are set, except DTC P0315, refer to Diagnostic Trouble Code (DTC) List - Vehicle in Vehicle DTC Information for the applicable DTC.
  3. Select the crankshaft position variation learn procedure with a scan tool.
  4. The scan tool instructs you to perform the following:
  5. 4.1.
    4.2.
    4.3.
    4.4.
    4.5.
    4.6.
    4.7.
    4.8.
    4.9.
    4.10.
    4.11.
    4.12.
    Turn the A/C OFF.
    4.13.
    4.14.
  6. Enable the crankshaft position system variation learn procedure with the scan tool and perform the following:
You best bet is take to the dealer ,unless you have a GM Tech2 factory scan tool .
Oct 20, 2015 | Buick Cars & Trucks
Please run channel auto scan
Auto channel scan is part of the initial set up procedure. Return to that procedure and repeat auto channel scan.
Jul 29, 2014 | Dynex DX-L19-10A LCD TV
98 corvette what is the proper procedure to bleeding the brakes
  1. Raise the vehicle on a suitable support.
  2. Remove all four tire and wheel assemblies.
  3. Inspect the brake system for leaks and visual damage.
  4. Inspect the battery state of charge.
  5. Install a scan tool.
  6. Turn ON the ignition, with the engine OFF. With the scan tool, establish communications with the electronic brake control module (EBCM). Select Special Functions. Select Automated Bleed from the Special Functions menu.
  7. Bleed the base brake system. Follow the scan tool directions until the desired brake pedal height is achieved.
  8. If the bleed procedure is aborted, a malfunction exists. Perform the following steps before resuming the bleed procedure:
    1. If a DTC is detected, check for the cause and repair as necessary.
    2. If the brake pedal feels spongy, perform the conventional brake bleed procedure again.
  9. When the desired pedal height is achieved, press the brake pedal in order to inspect for firmness. Remove the scan tool.
  10. Install the tire and wheel assemblies. Inspect the brake fluid level.
  11. Road test the vehicle while inspecting that the pedal remains high and firm.
  7. With the scan tool, establish communications with the electronic brake control module (EBCM). Select Special Functions. Select Automated Bleed from the Special Functions menu.
  8. Bleed the base brake system.
  9. Follow the scan tool directions until the desired brake pedal height is achieved.
Jan 03, 2011 | 1998 Chevrolet Corvette
Whats the proper way to bleed the breaks
Bleeding the Brake System (ABS) Auto Bleed Procedure NOTE: Perform a manual bleeding procedure. If the brake pedal height and firmness results are not achieved, perform the auto bleed procedure below.
  1. Raise and support the vehicle.
  2. Remove the tire and wheel assemblies.
  3. Inspect the battery state of charge.
  4. Install a scan tool.
  5. Turn ON the ignition, with the engine OFF.
  6. With the scan tool, establish communications with the ABS/TCS system. Select Special Functions from the ABS/TCS menu. Select Automated Bleed from the Special Functions menu.
  8. Follow the scan tool directions until the desired brake pedal height is achieved.
  9. If the bleed procedure is aborted, a malfunction exists. Perform the following steps before resuming the bleed procedure:
  10. If a DTC is detected, refer to Diagnostic Trouble Code (DTC) List and diagnose the appropriate DTC.
  11. If the brake pedal feels spongy, perform the conventional brake bleed procedure again.
  12. When the desired pedal height is achieved, press the brake pedal in order to inspect for firmness.
  13. Remove the scan tool.
  14. Install the tire and wheel assemblies.
  15. Inspect the brake fluid level.
  16. Road test the vehicle while inspecting that the pedal remains high and firm.
Bleeding ABS Automated Bleed Procedure NOTE: In most circumstances a base brake bleed is all that is required for most component replacements (such as wheel cylinders, calipers, brake tubes, and master cylinder) except for brake pressure modulator valve (BPMV) replacement.
The following automated antilock brake system (ABS) bleed procedure is required when one of the following occur:
  • Manual bleeding at the wheel cylinders does not achieve the desired pedal height or feel.
  • Replacement of the BPMV
  • Extreme loss of brake fluid has occurred.
  • Air ingestion is suspected.
NOTE: If none of the above conditions apply, use standard bleed procedures.
  1. Inspect the battery for a full charge.
  2. Repair the battery and charging system as necessary.
  3. Connect a scan tool to the data link connector (DLC) and select the current and history DTCs.
  4. Repair any DTCs prior to performing the ABS bleed procedure.
  5. Inspect for visual damage and leaks and repair as needed.
Preliminary Setup
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Raise and support the vehicle.
  3. Turn the ignition switch to the OFF position.
  4. Remove all 4 tires (if necessary)
  5. Connect the pressure bleeding tool.
  6. Turn the ignition switch to RUN position with the engine off.
  7. Connect a scan tool and establish communications with the ABS system.
  8. Pressurize the bleeding tool to 30-35 psi (206-241 kPa).
NOTE: The Auto Bleed Procedure may be terminated at any time during the process by pressing the EXIT button. No further Scan Tool prompts pertaining to the Auto Bleed procedure will be given.
CAUTION
  1. With the pressure bleeding tool set to 30-35 psi (206-241 kPa) and all bleeder screws in closed position, select Automated Bleed Procedure on the scan tool and follow the instructions.
  2. The first part of the automated bleed procedure will cycle the pump and front release valves for one minute.
  3. After the cycling has stopped the scan tool will enter a "cool down" mode and display a 3 minute timer. NOTE: The auto bleed will not continue until this timer expired, and cannot be overridden.
  4. During the next step, the scan tool will request the technician to open one of the bleeder screws. The scan tool will then cycle the respective release valve and pump motor for 1 minute.
  5. The scan tool will repeat step 3 for the remaining bleeder screws.
  6. With the bleeder tool still attached to the vehicle and maintaining 30-35 psi (206-241 kPa), the scan tool will instruct the technician to independently open each bleeder screw for approximately 20 seconds. This should allow any remaining air to be purged from the brake lines.
  7. When the automated bleed procedure is completed the scan tool will display the appropriate message.
  8. Install all 4 tires, if necessary.
  9. Remove the pressure from the pressure bleeding tool
  10. Disconnect the tool from the vehicle.
  11. Depress the brake pedal to gauge pedal height and feel.
  12. Repeat the procedure until the pedal is acceptable.
  13. Remove the scan tool from the DLC connector.
  14. Safely lower the vehicle.
  15. Inspect the brake fluid level in master cylinder.
  16. Road test the vehicle while ensuring the brake pedal remains high and firm.
  17. If the vehicle is equipped with a traction control system (TCS), the scan tool will cycle both the ABS and TCS solenoids valves. This bleed procedure is the same as above.
Sep 18, 2010 | 1998 Oldsmobile Silhouette
2007 aveo misfire faults
gm has a problem with this from way back. double check your spark plugs and if they are not ac delcos, change them. ive seen this time and time again swearing, myself, that there is no way that the plugs would cause this issue. it always comes up with random misfire and usually another 1 or 2 codes misfire codes. put in ac delco, no more codes. let me know
Feb 22, 2010 | 2007 Chevrolet Aveo 5 Hatchback
How do i change the crank positioning sensor on a 8.1 liter chevy silvarado?
Crankshaft Position Sensor: Service and Repair
Crankshaft Position (CKP) Sensor Replacement
REMOVAL PROCEDURE
IMPORTANT: Care must be taken when removing the crankshaft position (CKP) sensor. Use penetrating oil and allow to soak around the CKP
sensor before removing the sensor. Twist the sensor to break the O-ring seals loose. When removing the sensor, pull the sensor straight out of the
engine block at the same angle the sensor was installed. Failure to be careful may result in sensor damage.
1. Raise the vehicle. Refer to Lifting and Jacking the Vehicle.
2. Disconnect the crankshaft position (CKP) sensor harness connector at the CKP sensor.
3. Remove the fuel line bracket and retaining bolt.
4. Use penetrating oil and allow to soak around the CKP sensor before removing the sensor.
5. Remove the CKP sensor retaining bolt.
6. Prior to removal of the CKP sensor, rotate the sensor back and forth.
7. Remove the CKP sensor at the same angle at which the CKP sensor was installed.
INSTALLATION PROCEDURE
IMPORTANT: Inspect the CKP sensor O-ring for wear or damage. If a problem is found, replace the O-ring. Lubricate the new O-ring with engine
oil before installing.
1. Install the CKP sensor at the same angle at which the CKP sensor was removed.
NOTE: Refer to Fastener Notice in Service Precautions.
2. Install the CKP sensor retaining bolt.
Tighten
Tighten the bolt to 12 N.m (106 lb in).
3. Connect the CKP sensor harness connector.
4. Install the fuel line bracket and retaining bolt.
5. Lower the vehicle.
6. Perform the CKP System Variation Learn Procedure. See: Testing and Inspection/Programming and Relearning
IMPORTANT: For additional diagnostic information, refer to DTC P1336.
2. With a scan tool, monitor the powertrain control module for DTCs. If other DTCs are set, except DTC P1336, refer to Diagnostic Trouble Code
(DTC) List for the applicable DTC that set.
3. Close the vehicle's hood.
4. With a scan tool, select the crankshaft position variation learn procedure.
5. Observe the fuel cut-off for the engine that you are performing the learn procedure on.
6. The scan tool instructs you to perform the following:
^ Apply the vehicles parking brake.
^ Block the drive wheels.
^ Cycle the ignition from OFF to ON.
^ Apply and hold the brake pedal.
^ Start and idle the engine.
^ Turn OFF the A/C.
^ Place the vehicle's transmission in Park (A/T) or Neutral (M/T).
^ The scan tool monitors certain component signals to determine if all the conditions are met to continue with the procedure. The scan tool only
- Crankshaft position (CKP) sensors activity - If there is a CKP sensor condition, refer to DTC P0335 or DTC P0336.
- Camshaft position (CMP) sensor activity- If there is a CMP sensor condition, refer to DTC P0341, DTC P0342 or DTC P0343.
- Engine coolant temperature (ECT) - If the engine coolant temperature is not warm enough, idle the engine until the engine coolant
7. With the scan tool, enable the crankshaft position system variation learn procedure.
IMPORTANT: While the learn procedure is in progress, release the throttle immediately when the engine starts to decelerate. The engine control is
8. Slowly increase the engine speed to the RPM that you observed.
9. Immediately release the throttle when fuel cut-off is reached.
10. The scan tool displays Learn Status: Learned this ignition. If the scan tool does NOT display this message and no additional DTCs set, refer to
Symptoms - Engine Mechanical. If a DTC set, refer to Diagnostic Trouble Code (DTC) List for the applicable DTC that set.
11. Turn OFF the ignition for 30 seconds after the learn procedure is completed successfully.
Sep 11, 2009 | 2001 Chevrolet Silverado 2500HD
62 people viewed this question
jasbo
jasbo
