Question about Marantz SR-680
Hello How can I tape copy on my marantz sr-680 switch off?
Duncan
  • 218 Answers
SOURCE: Marantz SR 7200
Sounds like it is zapped (fried outputs). Time for a trip to the repair shop. Good luck.
Posted on Jan 29, 2007
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
  • 118 Answers
SOURCE: switching off after 15mts
in need of output replacement
Posted on Nov 04, 2009
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: I own a Marantz SR
Hook, yes. Use with NON-Bose 901 speakers, NO.
The 901's need a dedicated amplifier. Get one, then use the L/R Pre-Outs to feed it.
Posted on Jul 31, 2011
Testimonial: "Thank you very much. I have not unpacked the speakers yet. I'll take them back. Any suggestions for a quality pair of speakers for under $1200.00?"
Marantz a/v reciever sr-96 users manual i canot find it.
I found a partial copy, first 9 pages in pdf format. if you want it can email me here:
nasa.info@mail.com
Dec 17, 2014 | Marantz Sr-96,dp870, And Rc2000 Packa 5.1...
Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
Dec 23, 2007 | Marantz SR-18EX Receiver
Marantz st-48 wont pick up fm signal
If you are inclined to try to service this unit the first step is to download a service manual, this is a sight that has a copy of the manual for download for a price
http://www.marantz.owner-manuals.com/ST48-service-manual-MARANTZ.html
you will require some hand tools, soldering iron and desoldering brade and some solder, multi meter and some type of signal tracing device like and oscilloscope or and audio tracing amplifier.
Look for missing power supply's to your RF front-end circuits and FM discriminator , also track down the analog switching ic to varrifie that this unit is functioning and selecting the FM circuits
if you still kneed help contact me further with your findings and a copy of the service guide
Have a good day and good luck
Best regards Falco
Nov 04, 2013 | Marantz SR-48 Mark II Receiver
My marantz sr 5200 has stuck in "Mute on" situation
Your mute switch has been broken some how,End will have to be replaced.
Oct 11, 2012 | Marantz SR-5200 Receiver
Hello i have a marantz receiver sr7400 fuse
Unplug the unit. Carefully unscrew the screws for the case. Probably 4 screws, 2 on each side of the unit. Remove the cover. Look for the fuses, and replace with exact same type/specs of the faulty fuse. If the fuse, is on a printed circuit board, be careful dislodging the fuse. Hope this helps.
Apr 07, 2010 | Marantz SR-7400 Receiver
Do have an idiots guide as to how to wire up the SR-4200 to a TV
I will interperate this as:
"So you want to play sound through your Marantz SR-4200?"
You need to clarify what sort of system setup you have, however i will put down a few ways to wire this up to your TV.
If you have a Set-top-box that gets the TV Channels, that is where the sound comes from. If you have a TV that plugs straight into the wall, you will have to get the sound from the TV. Grab a RCA Stereo cable - (White and Red heads, if you don't know what they look like, Google it).
If you are unclear about this, i have tried to make a diagram down the bottom to explain how this is to work. What you will do is Take the sound from the Set-Top-Box or TV and reroute it into your fantastic Marantz SR-4200.
1. Plug Red Plug into the the Red Slot, and White into the White on the back of your set-top-box or TV Out (if you get it around the wrong way, the speakers will be reversed.)
2. Plug the other end of the cable into the back of your Marantz SR-4200 in the TAPE input or VHS input as they are analog signal inputs. Turn on Marantz SR-4200 and turn it onto Tape or Vhs (depending on where you plugged it in).
[Set-Top-Box or TV out] >-------> into >------> [Marantz SR-4200]
If you still don't get it, then try searching You-Tube for a guide "Plug Tv into Stereo". I myself couldn't turn up anything useful
Mar 09, 2010 | Marantz SR-4200 Receiver
What is the error POW 5 on a marantz sr 7500
I have a POW 5 failure on a marantz sr 7500. Anybody know how to fix?
Jun 02, 2009 | Marantz SR-7400 Receiver
57 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
