Question about Bosch Axxis WFL 2060 Front Load Washer
Set machine to wash; Came home to discover machine flashing F18, with water still inside drum, smelling 'burning', and nothing seems to rectify.
    Brigadier General:
  • 6,277 Answers
Bosch F18 can indicate a drain filter/drain pump problem so I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside. The smell COULD be coming from a jammed drain motor.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
F18 ERROR ON WASHING MACHINE
have you CHECKED the filter is clean
leave feed back
Jan 09, 2014 | Washing Machines
My kitchenaid washer has a burning smell
Hi, a slipping or severed belt will produce a burned rubber smell. A belt supports the drum and ensures its smooth movement. If it wears, the drum's movements weaken and finally come to an abrupt halt. In addition, a slipped or severed belt usually produces a burned rubber smell. Refer to the washing machine manual to review how to locate the belt. If the belt is no longer around the drum's center, shift the belt back to its original position. If rubber fibers are discernible or cracks are apparent, change out the worn belt for a new one.
Thank you.
Jun 05, 2012 | Washing Machines
I was washing today and at the end of every wash tere was a code of f18 flashing on my screen .what should i do
F18 means pump is blocked or broken, clean filter first, no result change then you have to change the pump.
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins.
Jan 06, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
My beko washing machine smells of burning
i need a motor circuit to test the motor of a defy automaid it does not spin fast
Nov 24, 2009 | Washing Machines
Why is the fault F18 error code on my bosch washing machine flashing?
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Feb 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Water not draining completely after cycle ends
First of all, is your drain hose connected to a kitchen sink or into a standpipe? If its a sink make sure you form a loop or curve in the hose as high as possible above the sinks own waste(plug hole) ,to ensure water cannot travel from sink back into machine. If this is not the case then your water pump, or the rubber pipe coming to the pump has definately got some kind of obstruction inside. Your washing machine has not emptied properly since it filled up at the beginning of the cycle,and has not got rid of the soapy water enough to enable a true rinse.Hence the detergent smell on clothes... Turn off power at plug socket.Take drain hose out of stand-pipe (or connection to sink waste)and drop this hose into a washing up bowl or similar at floor level,to drain off as much water as possible before disconnecting hose to pump or checking the pumps impellar to discover the blockage..Lets know how u get on,good luck.
Sep 01, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Bosch Axxis WFL 2060 Front Load Washer Logo
403 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
