Question about Husqvarna Rose
Tension problem? When I try to embroider, the top thread keeps balling up under the fabric; I've tried different tension numbers (4 is recommended), but I can't get it right. The needle seems to stick, and the bobbin jumps a lot. This happens sometimes when I use the decorative stitches, but not a lot. I usually have the tension set at 2 for decorative stitches. Judy Cincinnati
  • 3 Answers
HI Judy
These may be obvious thoughts that you have already looked into but when I have these problems they are usually resolved by one of the following@
1. Clean out the area around the bobin
2. Put a good stabalixer under the fabric in the hoop.
3. Check I am using the correct emroidery needle
4. Use correct thread for fabric.
Sorry if you have done all of these
Stephanie
Posted on Sep 06, 2008
The bobbin keeps balling up?
Can you provide more information on what type of sewing machine you have? Brand and Model would help. Thanks.
Jun 02, 2016 | Sewing Machines
Loose bobbin tension
the bobbin tension is set by that small spring plate that you pull the thread under after you put the bobbin back in the carrier / holder
a very small turn of that screw makes a big difference ob the tension unlike the needle thread tension
mostly the problem ( you never bothered to mention the symptom ) is bird nesting under the fabric which is the needle thread tension not tight enough
Jul 06, 2017 | Brother SE-270D Computerized Sewing...
While embroidering the top thread gets wound around the bobbin and makes a nest on the bottom
have you tried changing the needle
rethread the machine top & bobbin
when embroidering make sure it good quality thread
clean under the needle plate & in the bobbin area for loose threads & lint
make sure the thread your using it not knotty
make sure the tension is set for the thread & needle & fabric your using
make sure the thread has not come off the thread take up lever
Mar 17, 2012 | Brother Sewing Machines
Husqvarna viking, scandinavia 400: bobbin issues
try decreasing the tension to 3, if that doesn't help I would suggest to have it checked if it's still under warrenty
also is the fabric & needle & thread compatable?
Feb 27, 2012 | Sewing Machines
The bobbin thread is loops on top of the fabric even when the top thread is loosened to 2
if you've taking the machine in 4 times to be fixed,,sounds like you need a different sewing machine repair shop.
have you tried changing needles?
have you tried rethread the top & bobbin thread
is it possible the bobbin thread in not correctly inserted in the bobbin case?
try a top thread tension of 5 & see what happens?
Jan 20, 2012 | Brother Sewing Machines
Thread is balling up and not allowing the fabric to move it isn't stitching right
This can be caused by several different things. Check the threading. Un-thread the machine and follow the guidance on the manual and re-thread the machine. The bobbin, if the bobbin thread that coming out of the bobbin case in a wrong direction, could cause this. Re-set the direction. When you pull thread from the bobbin case, bobbin should roll counter clockwise. The needle, if it is not the right size needle for the fabric or the needle is slightly bent, maybe replace the needle and try with different size of needle. Once its balling up, sometimes it's left some thread in the machine under the needle plate around the feed dog, clean them up. Thread tension, different fabric may need to be adjust the thread tension, try to check this one under the manuals/instruction. When ready, check and use a scrap of fabric/remnants!
Aug 02, 2010 | Riccar Sewing Machines
Top thread - not bobbin thread - bunches up under fabric where feed dogs are when I'm embroidering.
this is a top thread tension problem . make shure thread is between tension plates and spring is contacting the plate if the tension number is high
Apr 12, 2010 | Baby Lock Ellure
Singer ce350 bobbin thread on top
Be sure when you are threading the top thread that you ALWAYS RAISE the presser foot. This releases the tension disk and allows the thread to seat properly.
Have you gone back and re-tested on your test fabric? Does it work okay on the test fabric? If so, then there's a suspicion that it has something to do with the fabric, needle & thread of your project. Is your project fabric very dense, heavy... Are you using a stabilizer? A hoop--is it taut, not stretched? Make sure the fabric is not trampolining. Could be an incompatibility. The needle & thread may be having difficulty piercing the fabric. Try a different weight needle, perhaps a microtex or embroidery needle.
Mar 23, 2017 | Singer CE-100 Futura Computerized Sewing...
Thread breaks when embroidering
Try changing threads. If you're not using embroidery thread specifically, the "treatments" they use on different threads can really cause problems.
Jan 04, 2009 | Husqvarna Designer I
Tension problem
For Staight Stitch.
Ideal
When adjusting top thread the Higher the number (on the little wheel) the tighter the top thread.
Results depend on
Stiffness and thickness of the fabric, number of fabric layers and type of stitch.
Are you using paper or a plastic bag or pellon under the fabric? This gives a smoother surface for embroidery (on the reverse) and you can cut it away after the design is complete.
Susan
Mar 18, 2008 | Janome Memory Craft 3000
Sewing Machines Logo
77 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
