Question about AEG Lavamat 88840 Front Load Washer
C6 error on oko lavamat 88830 - AEG Lavamat 88840 Front Load Washer
  • sdebrincat Mar 18, 2011
    Daniel
    Thanks for your help. How difficult is it to get these pressure sensors and were can you urchase them from?
    Daniel would this sensor be locaed behind the front panel or at the bottom of the unit?
  • 4,323 Answers
Hi
C6 is a pressure sensor error and to solve it should be replaced. This sensor is located on the right side of the machine looking from the front, just behind the centre strut. After replacing the sensor you can reset the washer by holding the prewash and soak buttons and then turning the knob to gentle spin. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 18, 2011
  • Daniel Scott
    Daniel Scott Mar 18, 2011
    Sorry for late reply...missed you comments...you can purchase it from a local repair shop and yes its located at the center bottom
Aeg lavamat error code c6
Found this on the following forum
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/aeg-lavamat-86741-error-t47666.html
C6 is caused by either a) defective mechanical pressure switch, b) defective pressure sensor or c) Defective wiring to either a or b.
You may want to just remove the hoses from the switch & sensor, noting what hose went where & blow down them to see if they are clear. If not, trace blockage & clear, refit hoses & test.
Before doing the above, please isolate the appliance from the mains electric supply.
Jan 13, 2015 | Garden
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Hi my AEG OKO-LAVAMAT 88830 is about 10n years old. Today I was cleaning my machine. I filled the machine up with water on the rinse cycle then turned it to pump. I did this a few times as I have had a...
According to my list for AEG Lavamat washers, 'C3' stands for 3 possible causes 1 'safety flood device operated' (I suspect it means that it has sensed some water in the bottom tray. Not an easy job to do but I would check for a leak underneath), 2 'pump fault' and 3 'module fault'. Sorry I can not be of more help ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 04, 2011 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 88830 Update Gives me the code C7. Whats wrong?
C7 error is th\at no heating of the water has happened. check the heater (most likeley) also can be faulty relay on electronic. ntc fault, pressure switch or wiring to any of them.
Nov 09, 2010 | AEG Lavamat 88840 Front Load Washer
Aeg oko lavamat 72600 update, ce error code showing any idea?
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Jul 09, 2010 | AEG Lavamat 72640 Front Load Washer
Oko lavamat 74640 update showing error E20 what does this mean?
its a draining error, check sump, pump and drain hose for blockage failing that it needs a new pump.
Mar 31, 2010 | AEG Lavamat 72640 Front Load Washer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
AEG Lavamat 88840 Front Load Washer Logo
1,472 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
