I want to know how to clean the drum of my samsung washinh machine. When I wash I get black residue on my white clothesi
    Sergeant:
  • 170 Answers
I put a post on here a while back for odor ploblem in a frigidaire check my post ( click on my name).If the black you are getting is greese then you are in to bearing problems lets hope not..try the cleaning process first and we will go from there.. Good luck thanks for voting
Posted on Mar 18, 2011
I have a top loading Samsung washing machine and after washing and water has drain and starts spinning I am hearing a strange whirring sound it is only happen while spin drying
maybe there is trapped residue or something in the drum,,,,u need a technician to detach the drum ,,,clean nd replace it back...
Nov 23, 2014 | Washing Machines
White Residue on black clothes after cycle
If the FILTER is not cleaned after each load was completed this will happen.
Mar 01, 2014 | GE Washing Machines
Samsung WA422 How do you know if it's not enough water?
The white residue you can see is undissolved soap powder, You need to first try reducing the quantity of powder you are using, there is also a good chance that the machine has built up residue between the inner and outer drum, I'd suggest buying a washing machine cleaner and running it through the machine following the instructions on the packaging, A hot empty wash with a cup of dishwasher powder and once it fills up pausing it to soak for a while will also do the same if you cannot find a washing machine cleaner.
May 14, 2017 | Samsung WA422PRHDWR
I have my LG Fuzzy Logic for 3 years now. Lately after washing my clothes I see that there is black particals stuck to my clothes after washing. I comes off when I shake the piece of clothing. I has a...
It's just a build up of residue. To clean out your drum, run a hot cycle (obviously with no clothes in the machine) with half a cup of vinegar then when the cycle is finished, wipe out all the residue, and trust me there will be alot. I do this every 3 months to give the drum a good clean out.
Oct 29, 2010 | LG WFT1071TP Top Load Washer
Black lint on white clothes after wash. have cleaned filter. is a front loader.
Check both the apron, located in front of the drum for lint residue, as well as the drum itself for sharp points (gouges) which may have snagged clothes and collected the lint to the inner side of the drum. Also try running a full cycle with no load to clear any lint which may remain in the outer (non visible) drum.
Mar 05, 2010 | Washing Machines
Black type residue being left on clothes
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution"
Oct 31, 2009 | Samsung SW62ASP Top Load Washer
My washing machine is leaving little residue on all my clothes after a complete wash, What are they? and how do you get rid of it, the washing machine is not yet a year old
Describe the residue. If it's oily (black, dk green) then the seal is out of the tranny and oil is getting into the tub. Dry cleaning is best for oil based stains. Liquid dish detergent is good also. On white it is tough to remove. Your washer will need a new transmission or replacing.
If it is powdery I'd guess a soap buildup, especially if you've recently changed detergents. The new detergent is breaking up the old soap scum in the outer drum and it is redepositing onto your clothes. This should wash out/off.
Tip: If it's a soap residue, fill washer full without clothes with hot water. Add 1 gallon white vinegar and more hot water until the unit if as full as possible. Agitate 15 minutes and drain. Rinse with a full level and drain.
Jan 24, 2009 | Samsung SW62ASP Top Load Washer
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Sep 28, 2007 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
